Discuss
No Heat - Checked everything?
 in
Dryer Repair
Ok hoping someone has some insight. I've read the basic troubleshooting of an electric dryer, and it seems everything i've
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat - Checked everything?
  #1 (permalink)
Old 01-07-2013, 04:23 PM
Junior Member
kc2mre is on a distinguished road
Default No Heat - Checked everything?
Model Number: 110.86870100   Brand: Kenmore   Age: More than 10 years
Ok hoping someone has some insight. I've read the basic troubleshooting of an electric dryer, and it seems everything i've come across is ok.. Here is what i've done: Checked the outlet to the dryer-244vAc..heating element has roughly 11ohms resistance so it's good. The two sensors in the heating element housing have low resistance (.2 ohms i believe) so they are good (hi limit and thermostat i think?) the other switch (cycling thermostat maybe?) shows good with low resistance too. thermal fuse is good, again about .2 ohms. Now i've gotten two answers on what i'm refering to as a thermostat pre-heater. its a little black ring around what is i believe the cycling thermostat. I read about 3600ohms.. is that ok? one answer says yes one says no.. any ideas??
Ads By Google
Related Models
Kenmore 110.87405140  GAS DRYER
Kenmore 110.87405160  COMMERCIAL GAS DRYER
Kenmore 110.87405840  GAS DRYER
Kenmore 110.87405860  COMMERCIAL GAS DRYER
Kenmore 110.87407140  GAS DRYER
Kenmore 110.87407840  GAS DRYER
Kenmore 110.92490100  GAS DRYER
Kenmore 110.92822100  GAS DRYER
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
Kenmore 110.96110100  ELECTRIC DRYER
Kenmore 110.96121100  ELECTRIC DRYER
Kenmore 110.96195100  ELECTRIC DRYER
Kenmore 110.96195110  DRYER FEATURE SHEET
Kenmore 110.96407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
  #2 (permalink)
Old 01-08-2013, 02:12 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Yes it sounds OK. It is as you suspected a hater and is turned on when lower heat settings are selected. It then adds heat to the cycling thermostat so it cycles more often resulting in a lower heat output.
Have you checked for 240 at the terminal strip in the unit? Could be you have a bad line cord.
Do you have the wiring diagram?
If not check inside the control console they often put it in there.
I cannot find one for this unit.
Your next step would be to check the continuity of the heater circuit.
The way you do this is to attach and leave it there, one meter lead to the L1 prong of the line cord.
Put the timer at mid cycle timed dry.
The usual path for the hearer circuit is a set of timer contacts, the hi-limit thermostat (on the heater), the thermal-cutout (fuse) (on the heater), the operating thermostat (on the blower), the heater element, the centrifugal switch on the motor and then L1.
If it checks out OK to both sides of the heating element then there is probably a problem with the centrifugal switch on the motor.
This switch closes when the motor gets close to operating speed. It is there so that the heater does not come on until there is air flow.
Note that the thermal fuse on the blower kills power to the motor and is not part of the heater circuit.
__________________
  #3 (permalink)
Old 01-08-2013, 03:08 AM
Junior Member
Default
Ok i'm missing something here... one meter lead on L1.. which side of the line cord is that? I know the center is my ground/neutral.. and where is the other meter lead? on the heating element? if so i assume it doesnt matter which terminal? thanks
  #4 (permalink)
Old 01-08-2013, 04:17 AM
Senior Expert
APP Volunteer
Default
Not sure as it depends on the plug end. It is the black on the terminal strip so just measure from the strip to the plug prongs to figure out which is the correct prong.
Not sure I understand the above.
One lead goes onto L1 and stays there. The other lead is used to check the heater circuit in total. Component by component till you find the open in the circuit.
Since I do not have a wiring diagram I have to do some guessing so do not take the following as gospel.
First measurement to the Black on the timer (should be L1). It should measure 0 ohms.
Next the red on the timer. Should be a fairly heavy gauge wire as it carries the heater current. Should measure 0 ohms.
Next the high limit thermostat on the heater assembly. Both sides 0 ohms
Then the thermal cut-off on the heater assembly. Both sides 0 ohms
Then the operating thermostat on the blower. Both sides 0 ohms
Then the heater itself. One side should be 0 ohms. The other side should be 8 to 12 ohms (the heater resistance).
If all the above are OK then all that is left is the wire that runs from one side of the heater to the centrifugal switch, the centrifugal switch itself and the wire that runs from the centrifugal switch to L2 prong on the line cord.
Note: the motor has 2 centrifugal switches.
One is for the heater. it usually has 2 fairly heavy red wires.
The other is for the start switch by-pass and start winding disconnect. You do not have to worry about this one.
Attached is an example wiring diagram that might help you visualize how a dryer is wired. It is a total guess on my part so is just an example, your unit may be very different.
__________________
  #5 (permalink)
Old 01-08-2013, 06:21 PM
Junior Member
Default
OK - so i did all the checks as you mentioned. After setting the timer to an active area all checks seem good.. L1 to black (.2ohms) L1 to red (.2ohms) L1 to high limit (.2 ohms both) L1 to thermal (.2 to both) L1 to operating tstat (.2) L1 to heater (.2 ohms) L1 to heater out (10 ohms) ...
so it seems i'm into this centrifugal switch assembley. I'm guessing this is on the motor and i need to remove the drum? What sort of testing goes on here? Also if you are able to post a link to the switch if i do need to purchase that would be great. thanks!!
  #6 (permalink)
Old 01-09-2013, 01:56 AM
Senior Expert
APP Volunteer
Default
Yes tat i the easiest way to get at it.
Check that the motor/switch area is clean.
Check that the 10 ohm side of the heater to one of the wires on the switch is 0 ohms. Check that the other wire on the switch to the L2 prong on the plug is 0 ohms.
If OK then the switch is toast.
Your centrifugal mechanism on the switch is OK as it keeps running after you release the start button so we know the other switch is being activated.
The switch itself cannot be replaced, you have to replace the motor.
Click on the below for more info on it.
I would also check for wear/slop the rear support rollers, the front support glides, the belt, the idler wheel, the seals so you get an idea of what a basic overhaul will cost you.
Also sometimes the blower wheel will not come off the motor so you have to destroy it.
It may not be worth fixing.
Part number: AP3094245
__________________
  #7 (permalink)
Old 01-10-2013, 04:15 PM
Junior Member
Default
boy, not looking good. i will tear into it probably over the weekend. the cost of a motor and wheel are kinda making it not worth it. if it needs more i doubt i'll do it for sure. If i were to buy a new one, do you have any pros/cons about brands? I see lowe's is selling fisher & paykel.. i was once told that is one of the best washers/dryers you can buy, but that was also by a salesman.. thanks so much for all the help!! maybe i get lucky and find a burnt wire!
  #8 (permalink)
Old 01-11-2013, 01:49 AM
Senior Expert
APP Volunteer
Default
Sorry but I do not give recommendations on replacement units.
If I did they would probably quit a week after the warranty ran out.
The only issue I have with fisher & paykel is the lack of technical info available for them. Also parts can be a problem.
I would recommend that you get a unit with as little electronics in it as possible. Simple is better than fancy as they have fewer things that can go wrong.
Also get one that uses rear drum rollers for support.
The units that use a single centered bearing are less reliable and also a pain to work on down the road.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Dryer - Intermittent heat, checked coils and igniter nevets Dryer Repair 5 11-20-2012 06:37 PM
Whirlpool thin-twin dryer no heat checked everything ! jp1234 Dryer Repair 1 03-03-2012 05:44 AM
AMANA gas dryer NO HEAT/ checked all skalesplitur Dryer Repair 0 06-24-2011 01:59 PM
NO HEAT - checked AL parts TheDragon Dryer Repair 6 12-16-2009 12:06 PM
Tub won't drain - already checked hoses LSett01 Dishwasher Repair 0 07-14-2009 02:04 PM
