Discuss
dryer blows cold air won't advance through cycle
 in
Dryer Repair
My Dryer Won't Advance Through The Cycle And It Blows Cold Air Only, Could The Element Cause This? Or
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer blows cold air won't advance through cycle
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-03-2008, 04:04 PM
sandra626 sandra626 is offline
Junior Member
sandra626 is on a distinguished road
Default dryer blows cold air won't advance through cycle
Model Number: LER4634JQ1   Brand: Whirlpool   Age: 5 - 10 years
My Dryer Won't Advance Through The Cycle And It Blows Cold Air Only, Could The Element Cause This? Or Could It Be The Timer Too?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-03-2008, 04:06 PM
Junior Member
Default
Its A Whirlpool Electric Dryer That Won't Advance And It Blows Cold Air
  #3 (permalink)
Old 02-04-2008, 09:53 AM
MISTYLE MISTYLE is offline
Junior Member
MISTYLE is on a distinguished road
Default
My Whirlpool Dryer is doing the same thing, It doesn't cool and the Timer / Cycle button stays in the same position. I'm checking around the internet today and if i find out anything I'll let ya know.
Good luck!
  #4 (permalink)
Old 02-04-2008, 10:21 AM
Junior Member
Lightbulb This may help you.
I found this site and it helped me out a lot. Maybe your problem is listed here .
http://www.appliance411.com/links/jump.cgi?ID=457
I found www.appliance411.com , (the link above) from Home Improvement - Do It Yourself - Home Remodeling | BobVila.com .
Thanks and good luck to you.
Misty
  #5 (permalink)
Old 02-05-2008, 10:49 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Sandra,
Most likely there is a problem with the heating circuit.
It consists of four major parts:
1. Thermal cut off (#6 on the bulkhead parts break down diagram)
2. Operating (cycling) thermostat (#20 on the bulkhead parts break down diagram)
3. Hi limit thermostat (#15 on the bulkhead parts break down diagram)
4. Heating element (#17 on the bulkhead parts break down diagram)
To find out which part caused the problem you have to check them for continuity in the above sequence.
If any of them is open - it has to be replaced.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
- The part number for the thermal cut off is AP3094244
- The part number for the cycling thermostat is AP3131939
- The part number for the hi limit thermostat is AP3131941
- The part number for the heating element is AP3094254
Here are the break down diagrams for the Whirlpool dryer Model LER4634JQ1
Good luck.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Atlantis won't go automatically advance to rinse cycle rmjz12 Washer Repair 1 11-15-2007 08:56 AM
freezer blows cold then hot tambo Refrigerator & Freezer Repair 0 11-12-2007 03:59 AM
Fridge & Freezer Cycle Cold To Warm Back To Cold terkel Refrigerator & Freezer Repair 1 09-25-2007 02:58 AM
Cycle won't advance dbarnard Washer Repair 0 09-24-2007 09:37 AM
My dryer blows hot air but doesn't turn. staceyo Dryer Repair 1 07-26-2007 07:45 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
