Discuss
Dryer doesn't start
 in
Dryer Repair
I think this dryer is actually made by Whirlpool. Door switch okay. Thermal fuse okay. Can hear timer running, as
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer doesn't start
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-03-2008, 03:29 PM
footsie footsie is offline
Junior Member
footsie is on a distinguished road
Default Dryer doesn't start
Model Number: KEYE700TAL0   Brand: Kitchen Aid   Age: More than 10 years
I think this dryer is actually made by Whirlpool. Door switch okay. Thermal fuse okay. Can hear timer running, as well as voltage okay. Using schematic, voltages and resistance specs seem okay, except push-to-start, which has no specs, and seems suspect to me.
Push-to-start switch has 110V coming in and out of R1 & R2, after starting, but zero voltage coming out of CT1 at all times. Resistance across R1/CT1 is 0 at rest, 1600 (160?) when pushing-to-start. Resistance across R2/CT1 is 1600 in both modes. What should specs be, & are these in range?
I've heard that the the centrifugal switch on the motor could also be the problem, but I don't know how to check voltages or resistances on it, except that I've confirmed there is 110V supply coming in on both sides thru 1M & 2M.
Thanks, footsie
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-04-2008, 01:21 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the timer switches. Check them for continuity according to the table in the tech sheet. Replace the timer if any switch is open (∞ resistance).
If there is nothing wrong then replace the motor.
- The part number for the timer is AP2911172
- The part number for the motor is AP3094245
Here are the break down diagrams for the Kitchen Aid dryer Model KEYE700TAL0
P.S. Kitchen Aid is a division of Whirlpool.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer doesn't start doug7as Dryer Repair 1 01-20-2008 11:48 AM
Dryer won't start shangki Dryer Repair 1 12-17-2007 08:16 PM
Dryer will not start - sometimes stripe5 Dryer Repair 1 11-26-2007 06:45 PM
Dryer Won't Start mdcorbell Dryer Repair 0 11-21-2007 12:17 AM
Dryer will not start bob38 Dryer Repair 2 09-19-2007 07:59 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
