Discuss
Dryer begins to heat and then flame goes out
 in
Dryer Repair
My Frigidaire clothes dryer (Model FSG447GHS0) does the following: - Console settings: High temp, timed dry, dryer not run for
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer begins to heat and then flame goes out
  #1 (permalink)
Old 01-06-2013, 05:17 PM
Junior Member
wchesbro is on a distinguished road
Default Dryer begins to heat and then flame goes out
Model Number: FSG447GHS0   Brand: Frigidaire   Age: 5 - 10 years
- Console settings: High temp, timed dry, dryer not run for at least 10 minutes
  • On start up the igniter heats for about 5 seconds and then the gas ignites.
  • The gas flame burns for 2-3 minutes and then goes out.
  • Neither the igniter or the gas flame will come on again if I re-start the dryer immediately. After 2-3 minutes when I start up the dryer again the igniter goes on but the gas flame doesn't and then the igniter goes off.
  • After about 10-15 minutes, when the dryer appears to have 'cooled' down it will work okay for another 2-3 minutes.
I have reviewed the other Frigidaire clothes dryer heating problem posts and have tested the continuity of the following components. All tested as working correctly based on the continuity checks (see values in list below):
  • Igniter (#74 on the burner break down diagram) - 64.5 Ohms
  • Flame sensor (#79 on the burner break down diagram) - .1 Ohms
  • Safety thermostat (#33 on the cabinet break down diagram) - .1 Ohms
  • Heat control thermostat (#15 on the motor break down diagram) - .1 Ohms across the two main leads
I've also successfully tested the continuity for all three leads on the temperature selection switch (high, medium and low heat) and both the Timed Dry and Auto Dry leads on the timer switch.
Although the gas line solenoids work initially (gas flows successfully) I can't determine if they're defective since they can't be tested.
Am I missing anything?
My sense is that this is either a thermostat problem or a solenoid problem but don't know how to definitively test for the actual problem beyond what I've done. Is there a safe way to 'bypass' the various switches, thermostats and solenoids and see if it runs correctly for more than the 2-3 minutes I've been getting?
Thanks for your help with this.
Related Models
Frigidaire FSG447GHS0 Frg(v0) / Dryer
Frigidaire FSG447GHS1 Dryer - Frig Gallery
Frigidaire FSG747GC DRYER
Frigidaire FSG747GCS0 Frg(v0) / Gas Dryer
Frigidaire FSG747GES0 Frg(v0) / Gas Dryer
Frigidaire FSG747GES1 Frg(v0) / Gas Dryer
Frigidaire FSG748GFS0 Frg(v0) / Dryer
Frigidaire FSG748GFS1 Frg(v0) / Stack Dryer
Frigidaire FSG848RHQ0 Frg(v1) / Dryer
Frigidaire FSG848RHS0 Frg(v2) / Dryer
Frigidaire FSG849GHQ1 Dryer - Frigidaire Gallery
Frigidaire FSG849GHS1 Dryer - Frigidaire Gallery
Frigidaire FSGB39RGS0 Frg(v0) / Dryer
Frigidaire FSK190AN5D Kel(v5) / Side By Side Refrigerator
Frigidaire FSK190AN5F Kel(v4) / Side By Side Refrigerator
Frigidaire FSK190AN5T Kel(v3) / Side By Side Refrigerator
Frigidaire FSK190AN5V Kel(v2) / Side By Side Refrigerator
Frigidaire FSK190AN5W Kel(v1) / Side By Side Refrigerator
Frigidaire FSK190EN0D Kel(v5) / Side By Side Refrigerator
Frigidaire FSK190EN0F Kel(v4) / Side By Side Refrigerator
Frigidaire FSK190EN0T Kel(v3) / Side By Side Refrigerator
Frigidaire FSK190EN0V Kel(v2) / Side By Side Refrigerator
Frigidaire FSK190EN0W Kel(v1) / Side By Side Refrigerator
Frigidaire FSK190EN1D Kel(v10) / Side By Side Refrigerator
Frigidaire FSK190EN1F Kel(v9) / Side By Side Refrigerator
Frigidaire FSK190EN1T Kel(v8) / Side By Side Refrigerator
Frigidaire FSK190EN1V Kel(v7) / Side By Side Refrigerator
Frigidaire FSK190EN1W Kel(v6) / Side By Side Refrigerator
Frigidaire FSK190EN2D Kel(v5) / Side By Side Refrigerator
Frigidaire FSK190EN2F Kel(v4) / Side By Side Refrigerator
Frigidaire FSK190EN2T Kel(v3) / Side By Side Refrigerator
Frigidaire FSK190EN2V Kel(v2) / Side By Side Refrigerator
Frigidaire FSK190EN2W Kel(v1) / Side By Side Refrigerator
Frigidaire FSK190EN3D Kel(v5) / Side By Side Refrigerator
Frigidaire FSK190EN3F Kel(v4) / Side By Side Refrigerator
Frigidaire FSK190EN3T Kel(v3) / Side By Side Refrigerator
Frigidaire FSK190EN3V Kel(v2) / Side By Side Refrigerator
Frigidaire FSK190EN3W Kel(v1) / Side By Side Refrigerator
Frigidaire FSK190JN0D Kel(v1) / Side By Side Refrigerator
Frigidaire FSK190JN0W Kel(v2) / Side By Side Refrigerator
Frigidaire FSK190JN1D Kel(v1) / Side By Side Refrigerator
Frigidaire FSK190JN1W Kel(v2) / Side By Side Refrigerator
Amana FSP-10.A COMMERCIAL MICROWAVES
Amana FSP-10.B COMMERCIAL MICROWAVES
Amana FSP-10.C COMMERCIAL MICROWAVES
Amana FSP-10.D COMMERCIAL MICROWAVES
Amana FSP10 COMMERCIAL MICROWAVES
Amana FSP10SS COMMERCIAL MICROWAVES
Amana FSP11 COMMERCIAL MICROWAVES
Menu Master FSP11 COMMERCIAL MICROWAVES
Amana FSP11LW COMMERCIAL MICROWAVES
Amana FSP11SS COMMERCIAL MICROWAVES
Amana FSP700 COMMERCIAL MICROWAVES
Amana FSP8LW COMMERCIAL MICROWAVES
Amana FST130-2D RANGE- S/C S/I DDRAFT GAS
Amana FST136-2D RANGE- S/C S/I DDRAFT GAS
Bosch FT100-060
Frigidaire FTF1040AS0 Frtld Washer - Frigidaire
Frigidaire FTF1240FS0 WASHER
Frigidaire FTF1240FS1 WASHER
Frigidaire FTF1240FS2 WASHER
Frigidaire FTF2140ES0 Frigidaire/washer
Frigidaire FTF2140ES1 Frigidaire/washer
Frigidaire FTF2140ES2 Frigidaire/washer
Frigidaire FTF2140ES3 Frigidaire/washer
Frigidaire FTF2140FE0 WASHER
Frigidaire FTF2140FE1 WASHER
Frigidaire FTF2140FS0 Frigidaire/washer
Frigidaire FTF2140FS1 WASHER
Frigidaire FTF2140FS2 WASHER
Frigidaire FTF5000HS0 WASHER
Frigidaire FTF530ES0 Frigidaire/washer
Frigidaire FTF530ES1 Frigidaire/washer
Frigidaire FTF530FS0 Frigidaire/washer
Frigidaire FTF530FS1 WASHER
Frigidaire FTF530FS2 WASHER
Frigidaire FTF530FS3 WASHER
Frigidaire FTF530FS4 WASHER
Frigidaire FTF630AS0 Frtld Washer - Frigidaire
Frigidaire FTFB2940FE0 Frigidaire/washer
Frigidaire FTFB2940FE1 WASHER
Frigidaire FTFB4000FS0 Frigidaire/washer
Frigidaire FTFB4000FS1 Frigidaire/washer
Frigidaire FTFB4000GS0 Frigidaire/washer
Frigidaire FTFB4000GS1 WASHER
Frigidaire FTHD18P4KB0 REFRIGERATOR
Frigidaire FTHD18P4KB1 REFRIGERATOR
Frigidaire FTHD18P4KB3 REFRIGERATOR
Frigidaire FTHD18P4KB4 REFRIGERATOR
Frigidaire FTHD18P4KW0 REFRIGERATOR
Frigidaire FTHD18P4KW1 REFRIGERATOR
Frigidaire FTHD18P4KW3 REFRIGERATOR
Frigidaire FTHD18P4KW4 REFRIGERATOR
Frigidaire FTMD18P4KB0 REFRIGERATOR
Frigidaire FTMD18P4KB1 REFRIGERATOR
Frigidaire FTMD18P4KB2 REFRIGERATOR
Frigidaire FTMD18P4KB3 REFRIGERATOR
Frigidaire FTMD18P4KB4 REFRIGERATOR
Frigidaire FTMD18P4KB5 REFRIGERATOR
Frigidaire FTMD18P4KB6 REFRIGERATOR
Frigidaire FTMD18P4KW0 REFRIGERATOR
Frigidaire FTMD18P4KW1 REFRIGERATOR
Frigidaire FTMD18P4KW2 REFRIGERATOR
Frigidaire FTMD18P4KW3 REFRIGERATOR
Frigidaire FTMD18P4KW4 REFRIGERATOR
Frigidaire FTMD18P4KW5 REFRIGERATOR
Frigidaire FTMD18P4KW6 REFRIGERATOR
Frigidaire FTMI21P5KB0 REFRIGERATOR
Frigidaire FTMI21P5KW0 REFRIGERATOR
Frigidaire FTR630AS0 Frtld Washer - Frigidaire
Frigidaire FTW3011KW0 WASHER
Frigidaire FTW3014KW0 WASHER
Frigidaire FU017RRW1 Wwh(v2) / Upright Freezer
Frigidaire FU018TRW1 Wwh(v3) / Upright Freezer
Frigidaire FU019ARW5 Wwh(v3) / Upright Freezer
Frigidaire FU054ERD1 Wwh(v1) / Upright Freezer
Frigidaire FU054ERD2 Wwh(v2) / Upright Freezer
Frigidaire FU054ERD3 Wwh(v3) / Upright Freezer
Frigidaire FU054ERW1 Wwh(v4) / Upright Freezer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Dryer starts. No Ignitor, No flame no heat jmrec100 Dryer Repair 1 12-12-2012 03:32 PM
Gas Dryer won't heat up (flame for only a few seconds) edsison1648 Dryer Repair 0 05-19-2010 02:31 PM
Gas dryer ran but not heat. After testing and replacing the flame sensor, the proble yzhong Dryer Repair 0 08-26-2009 03:33 PM
No Heat And Flame dman1966 Dryer Repair 1 12-30-2008 02:45 PM
Gas dryer with low heat and large hot flame cmgonz Dryer Repair 1 04-07-2008 04:58 AM
