Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Electric dryer (http://forum.appliancepartspros.com/dryer-repair/514613-electric-dryer.html)
mindy08 01-05-2013 09:44 AM
Electric dryer
My dryer makes a loud thumping, rumbling like noise, somewhat off balance. Clothes get stuck in back of tumbler, have cause small holes in clothes & getting black grease/oil spots on clothes. Felt seal or drum belt possibly?
denman 01-06-2013 01:49 AM
Here are your parts.
Parts for Maytag LDE8624ACE - AppliancePartsPros.com
If you click on a part's picture a new page will open often with additional helpful info.
Thumping is often a problem with the rear drum support rollers (item 21 in section 08).
Since you have to open the unit up ypu may as well also check the felt drum seals, the support roller shafts, the front glide, the belt etc. so that you will have an idea what it will cost to give the unit a bit of an overhaul.
It is also a good time to check/clean your vent system.
