| » Dryer works fine for 5 minutes, then heat quits. |
Model Number: FG0332ES0 Brand: Frigidaire Age: 1 - 5 years
Have a gas dryer that will heat for about 5 minutes, then the heat quits. It was working fine until it possibly got some water damage from Hurricane Sandy. It was on top of the washing machine so the water line was about 4 inches up from the dryer bottom. Any suggestions? I'm trying to fix this for a couple with children that are living in a shelter right now until their house gets power back to it. Thanks in advance.
Hi.
Based on the info you provided you should replace the control coils Part number: 5303931775 Here are the breakdown diagrams and Burner parts for Frigidaire FGQ332ES0 - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
On the top of the gas valve. The double coil has an insert, when replacing make sure it's on the shaft. Simon.
__________________
How do you access the Gas Valve? Do you have to remove the drum? I took the rear access cover off and couldn't see anything that looked like the part. I took the top off also. Tight quarters in there. I can look from the back down the gas inlet pipe but I can't access anything in there. Thanks again for your help.
Hi.
You need to remove the top cover and front panel to get to the gas valve.Take three screws at the back out and slide the top back an inch and lift it off. Controls / Rop Panel parts for Frigidaire FGQ332ES0 - AppliancePartsPros.com Front Panel / Lint Filter parts for Frigidaire FGQ332ES0 - AppliancePartsPros.com Simon.
__________________
You are welcome.
Simon.
__________________
| Display Modes | |
| Dryer runs 2-3 minutes and quits | tjmnwl | Dryer Repair | 4 | 09-10-2012 04:21 PM |
| roper dryer quits after a few minutes | royel | Dryer Repair | 0 | 02-26-2012 06:08 AM |
| Dryer works fine no heat | dhillonx | Dryer Repair | 0 | 07-16-2011 03:45 PM |
| dryer works fine but no heat and wont shut off | misty_mikie | Dryer Repair | 0 | 08-23-2009 02:37 PM |
| Dryer Runs for 10 minutes then buzzes and quits | Paul_R | Dryer Repair | 1 | 03-19-2008 02:57 PM |
