Discuss
tom
 in
Dryer Repair
Dryer will not heat. Replaced heat element, no help. Ck'd continuity of thermo fuse, cks ok. Ck'd same across dryer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » tom
  #1 (permalink)
Old 01-04-2013, 10:23 AM
Junior Member
thomd2648 is on a distinguished road
Default tom
Model Number: ler463pqo   Brand: Whirlpool   Age: 1 - 5 years
Dryer will not heat. Replaced heat element, no help. Ck'd continuity of thermo fuse, cks ok. Ck'd same across dryer cycling thermostat. Continuity ok across two of the larger wire contacts but none across the two smaller wire contacts. When I shake the part I could hear some rattling going on inside! Bad thermostat?
Ads By Google
Related Models
Whirlpool LER5434AN0
Whirlpool LER5434AW0
Whirlpool LER5600HQ0
Whirlpool LER5600HZ0
Whirlpool LER5600JQ0
Whirlpool LER5600JT0
Whirlpool LER5620KQ0
Whirlpool LER5620KQ1
Whirlpool LER5620KQ2 29"electric Dryer
Whirlpool LER5624BN0
Whirlpool LER5624BN1
Whirlpool LER5624BN2
Whirlpool LER5624BW0
Whirlpool LER5624BW1
Whirlpool LER5624BW2
Whirlpool LER5624DQ0
Whirlpool LER5624DQ1
Whirlpool LER5624DW1
Whirlpool LER5624DZ0
Whirlpool LER5624DZ1
Whirlpool LER5634AN0
Whirlpool LER5634AQ0
Whirlpool LER5634AQ1
Whirlpool LER5634AQ2
Whirlpool LER5634AW0
Whirlpool LER5634DQ1
Whirlpool LER5634EQ0
Whirlpool LER5634EZ0
Whirlpool LER5634LG0
Whirlpool LER5634LQ0 29" Electric Dryer
Whirlpool LER5634LT0
Whirlpool LER5634LW0
Whirlpool LER5635LQ0 29"electric Dryer
Whirlpool LER5635LQ1 29"electric Dryer
Whirlpool LER5636DW0
Whirlpool LER5636DW1
Whirlpool LER5636EQ0
Whirlpool LER5636EQ1
Whirlpool LER5636EQ2
Whirlpool LER5636EQ3
Whirlpool LER5636EZ0
Whirlpool LER5636EZ1
Whirlpool LER5636EZ2
Whirlpool LER5636EZ3
Whirlpool LER5636JQ0
Whirlpool LER5636JT0
Whirlpool LER5636KQ0
Whirlpool LER5636KQ1
Whirlpool LER5636KT0
Whirlpool LER5636KT1
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"electric Dryer
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"electric Dryer
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
Whirlpool LER6620PQ0 29"electric Dryer
Whirlpool LER6620PQ1 29"electric Dryer
Whirlpool LER6620PT0 29"electric Dryer
Whirlpool LER6620PT1 29"electric Dryer
Whirlpool LER6621PQ0 29" Electric Dryer
Whirlpool LER6634BN0
Whirlpool LER6634BN1
Whirlpool LER6634BN2
Whirlpool LER6634BQ0
Whirlpool LER6634BQ1
Whirlpool LER6634BQ2
Whirlpool LER6634BW0
Whirlpool LER6634BW1
Whirlpool LER6634BW2
Whirlpool LER6634DQ0
Whirlpool LER6634DQ1
Whirlpool LER6634DW0
  #2 (permalink)
Old 01-04-2013, 10:47 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
The cycling thermostat is most likely good. Did you check the thermal cut off and hi-limit? Part number: 279769
Part number: 279769
Here are the breakdown diagrams and Bulkhead parts for Whirlpool LER4634BQ0 - AppliancePartsPros.com
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 01-04-2013, 12:31 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Parts for Whirlpool LER4634PQ0 Dryer - AppliancePartsPros.com
It is for a 4634. I could not find anything on a 463 so am assuming that is a typo.
Simon I am not sure but I do not think the cycling thermostat should rattle.
So I would recommend it be replaced even if it measures OK.
The small connections on the cycling thermostat may not have shown continuity because you were using to low of a meter scale. They are an internal heater and should measure 5600 to 8400 ohms.
Have you checked the power?
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
