Discuss
roper
 in
Dryer Repair
dryer works ok on timed dry but runs forever on autosense dry vent new no clogges plenty of flow whats
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » roper
  #1 (permalink)
Old 01-03-2013, 01:53 PM
Junior Member
messi is on a distinguished road
Default roper
Model Number: red4440vq1   Brand: Roper   Age: 1 - 5 years
dryer works ok on timed dry but runs forever on autosense dry vent new no clogges plenty of flow whats up thanks
Ads By Google
Related Models
Whirlpool REE1600P
Whirlpool REE1600P1
Whirlpool REE1600P2
Whirlpool REE1600P3
Whirlpool REE1700P
Whirlpool REE1700P1
Whirlpool REE1700P2
Whirlpool REE1700P3
Whirlpool REE22303 24" Freestanding Range Easy - Clean Oven Coil Cooktop
Whirlpool REE23000
Whirlpool REE31300
Whirlpool REE32302 30" Electric Range Coil Cooktop E - Z Clean Oven
Whirlpool REE33000
Whirlpool REE34001
Whirlpool REE6700P
Whirlpool REE6700P1
Whirlpool REE6700P2
Whirlpool REE6700P3
Whirlpool REE6700P4
Whirlpool REE6700W
Whirlpool REE6700W2
Whirlpool REE6700W3
Whirlpool REE6700W4
Whirlpool REE950PW
Whirlpool REE9600W
Whirlpool REE970PW
Whirlpool REE970PW1
Amana REF120905C5E Room Air Conditioner
Amana REF120905C5E RE Room Air Conditioner
Amana REF120905C5ER Room Air Conditioner
Amana REF120905C5ER R Room Air Conditioner
Amana REF18090C5E Room Air Conditioner
Amana REF18090C5E REV Room Air Conditioner
Amana REF18090C5ER Room Air Conditioner
Amana REF18090C5ER RE Room Air Conditioner
Amana REF24080C5E Room Air Conditioner
Amana REF24080C5E REV Room Air Conditioner
Amana REF24080C5ER Room Air Conditioner
Amana REF24080C5ER RE Room Air Conditioner
Thermador REF30
Thermador REF30QB PRIOR TO S/N 9708
Thermador REF30QB S/N 9708 & UP
Thermador REF30QW PRIOR TO S/N 9708
Thermador REF30QW S/N 9708 & UP
Thermador REF30RS PRIOR TO S/N 9707
Thermador REF30RS S/N 9707 & UP
Frigidaire REG34NL1 Frg(v2) / Electric Range
Frigidaire REG34NL2 Frg(v4) / Electric Range
Frigidaire REG34NW1 Frg(v1) / Electric Range
Frigidaire REG34NW2 Frg(v3) / Electric Range
Frigidaire REG36AA2 Frg(v4) / Free Standing Electric Range
Frigidaire REG36AA3 Frg(v4) / Electric Range
Frigidaire REG36AA4 Frg(v9) / Electric Range
Frigidaire REG36AA5 Frg(v3) / Electric Range
Frigidaire REG36AA6 Frg(v8) / Electric Range
Frigidaire REG36AF2 Frg(v5) / Free Standing Electric Range
Frigidaire REG36AF3 Frg(v3) / Electric Range
Frigidaire REG36AF4 Frg(v8) / Electric Range
Frigidaire REG36AF5 Frg(v2) / Electric Range
Frigidaire REG36AF6 Frg(v7) / Electric Range
Frigidaire REG36AH2 Frg(v6) / Free Standing Electric Range
Frigidaire REG36AH3 Frg(v5) / Electric Range
Frigidaire REG36AH4 Frg(v10) / Electric Range
Frigidaire REG36AH5 Frg(v4) / Electric Range
Frigidaire REG36AH6 Frg(v9) / Electric Range
Frigidaire REG36AL2 Frg(v7) / Free Standing Electric Range
Frigidaire REG36AL3 Frg(v2) / Electric Range
Frigidaire REG36AL4 Frg(v7) / Electric Range
Frigidaire REG36AL5 Frg(v5) / Electric Range
Frigidaire REG36AL6 Frg(v10) / Electric Range
Frigidaire REG36AW2 Frg(v8) / Free Standing Electric Range
Frigidaire REG36AW3 Frg(v1) / Electric Range
Frigidaire REG36AW4 Frg(v6) / Electric Range
Frigidaire REG36AW5 Frg(v1) / Electric Range
Frigidaire REG36AW6 Frg(v6) / Electric Range
Frigidaire REG36CAA2 Frg(v9) / Free Standing Electric Range
Frigidaire REG36CAA3 Frg(v3) / Electric Range
Frigidaire REG36CAA4 Frg(v8) / Electric Range
Frigidaire REG36CAA5 Frg(v3) / Electric Range
Frigidaire REG36CAA6 Frg(v8) / Electric Range
Frigidaire REG36CAF2 Frg(v10) / Free Standing Electric Range
Frigidaire REG36CAF3 Frg(v2) / Electric Range
Frigidaire REG36CAF4 Frg(v7) / Electric Range
Frigidaire REG36CAF5 Frg(v2) / Electric Range
Frigidaire REG36CAF6 Frg(v7) / Electric Range
Frigidaire REG36CAH2 Frg(v11) / Free Standing Electric Range
Frigidaire REG36CAH3 Frg(v4) / Electric Range
Frigidaire REG36CAH4 Frg(v9) / Electric Range
Frigidaire REG36CAH5 Frg(v4) / Electric Range
Frigidaire REG36CAH6 Frg(v9) / Electric Range
Frigidaire REG36CAL2 Frg(v12) / Free Standing Electric Range
Frigidaire REG36CAL3 Frg(v5) / Electric Range
Frigidaire REG36CAL4 Frg(v10) / Electric Range
Frigidaire REG36CAL5 Frg(v5) / Electric Range
Frigidaire REG36CAL6 Frg(v10) / Electric Range
Frigidaire REG36CAW2 Frg(v13) / Free Standing Electric Range
Frigidaire REG36CAW3 Frg(v1) / Electric Range
Frigidaire REG36CAW4 Frg(v6) / Electric Range
Frigidaire REG36CAW5 Frg(v1) / Electric Range
Frigidaire REG36CAW6 Frg(v6) / Electric Range
Frigidaire REG38BLL1 Frg(v2) / Electric Range
Frigidaire REG38BLW1 Frg(v1) / Electric Range
  #2 (permalink)
Old 01-04-2013, 03:45 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Parts for Roper RED4440VQ1 Dryer - AppliancePartsPros.com
See the attachment for your tech sheet.
In timed dry the timer motor gets power all the time through the timer's contacts T to F
In auto modes the timer motor gets power through the heating coil when it is turned off via timer contacts T to X.
First I would unplug the unit.
Disconnect the wires at the heater and measure it with a meter, should be around 8 to 12 ohms. Also check each heater connector to the frame, both should be infinite ohms.
Sometimes a heating coil can break and short to the frame in such a way that it still seems to run OK but is actually running off of 120 volts. Your timer motor need the full 240 volts.
If the heater is OK then reconnect it and set the timer to a mid-scale auto cycle. Remove the wires at T and X on the timer and measure across the contacts, should be 0 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
roper help elliotspapa Washer Repair 1 03-08-2011 03:40 PM
roper brayson Refrigerator & Freezer Repair 1 01-25-2010 02:02 AM
roper preacher Washer Repair 1 11-30-2008 04:05 PM
Roper help swbdd Dryer Repair 1 09-28-2008 03:42 PM
roper maximum destruction Washer Repair 2 01-07-2008 03:37 PM
