Estate gas dryer . . . Replaced the thermal fuse a few months ago because there was no heat, and that did the trick. Now, the flame lasts for only about 30 seconds, then is gone. Any suggestions?
If the flame relights every time when the igniter comes "on", but does not stays "on" long enough then the problem is obstructed air flow somewhere inside and/or outside the dryer.
