| » Dryer Belt Tensioning/Placement Issue |
Model Number: LDE8506ACE Brand: Maytag Age: More than 10 years
Replaced the two (rear) drum rollers, two (front) drum slides, and the belt. I did reverse the drum, which the manual says shouldn't make a difference. I didn't like the way the belt positioned/tensioned - the return side of the belt was awfully close to the belt passing over the drive pulley, but I went ahead and returned the dryer to service. Sure enough, after a few weeks, the drum stopped turning and the belt is shredded and broken.
I had kept the old belt, which was operating fine before the above work was done. I have installed the old belt and the belt position/tension is even worse than what I describe above - the return side of the belt is up against the pulley and also is running against the cutout in the metal guard - it will start to shred immediately if I start running this way. What is wrong? Could the rollers (non-OEM) have been undersize and allowed the drum to take a lower position, thus screwing up the belt tensioning? Now that the non-OEM rollers have been running, could they have worn and dropped the drum even more? Please help! Thanks, Rick Ads By Google Related Models |
Parts for Maytag LDE8506ACE - AppliancePartsPros.com Could the rollers (non-OEM) have been undersize and allowed the drum to take a lower position, thus screwing up the belt tensioning? I doubt it. Take a look inside the drum, if it is low you should be able to see that the bottom has a gap and the drum is not centered on the rear wall. Sounds like you may just have the belt on wrong. There is a good sticky with belt diagrams at the start of this section. Also if you click on the belt's picture in the parts a new page will open witha Q&A about it. As far as I know the belt ridges should face the motor pulley. The flat side of the belt should ride against the idler/tension wheel.
__________________
denman - Have looked at the 'correct' roller part on web sites, with a picture of the roller overlaid on a 1" grid, and my rollers appear to be very close (if not the same) to the same diameter. I will check the centering of the drum on the back wall, good idea. Have also checked the belt routing per the manual and the on-line diagrams here and all is correct. Thanks.
| Display Modes | |
| Belt Placement | andynh | Dryer Repair | 1 | 11-23-2010 12:46 PM |
| Maytag washer belt tensioning doesn't work | wjrook | Washer Repair | 1 | 10-14-2009 05:26 PM |
| Tensioning Drive Belt | Phillip R Lehrfeld | Washer Repair | 3 | 09-25-2009 05:34 PM |
| Whirlpool dryer will not tumble. Belt issue? | marc127 | Dryer Repair | 3 | 08-31-2009 03:18 PM |
| Dryer overheated - belt issue? How to replace? | crussell01 | Dryer Repair | 1 | 05-29-2009 08:17 AM |
