Discuss
Dryer will not start.
 in
Dryer Repair
I have a Whirlpool LER8648PWO dryer that we have had for a few years now and it now will not
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer will not start.
  #1 (permalink)
Old 12-29-2012, 09:48 PM
Junior Member
Humility is on a distinguished road
Default Dryer will not start.
Model Number: LER8648PWO   Brand: Whirlpool   Age: 1 - 5 years
I have a Whirlpool LER8648PWO dryer that we have had for a few years now and it now will not start.
It has power, when I set the timer it starts spinning down. The heat element works fine (Bypassed the thermostat to manually turn it on and check). I picked up a new switch and tried replacing that, but it had no effect. The door switch is properly registering that the door is closed.
I do not have an ohm/multimeter on hand, but have most basic tools I just do not know dryers at all so I don't know what would be my next step to look at.
Thanks in advance for any insight you guys are able to offer!
Ads By Google
Related Models
Whirlpool LER8857EQ0
Whirlpool LER8857EQ1
Whirlpool LER8857EQ2
Whirlpool LER8857EZ0
Whirlpool LER8857EZ1
Whirlpool LER8857EZ2
Whirlpool LER8858DQ0
Whirlpool LER8858DQ1
Whirlpool LER8858DZ0
Whirlpool LER8858DZ1
Whirlpool LER8858EQ0
Whirlpool LER8858EQ1
Whirlpool LER8858EQ2
Whirlpool LER8858EZ0
Whirlpool LER8858EZ1
Whirlpool LER8858EZ2
Amana LES10AW Washer - Top Loading
Amana LES19AW Dryer - Gas
Amana LES33AW Dryer - Gas
Amana LES34AW Washer - Top Loading
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Amana LET-480 Range - S/c S/i Ddraft Gas
Amana LET-480A Range - S/c S/i Ddraft Gas
Amana LET-480B Range - S/c S/i Ddraft Gas
Amana LET-480C Range - S/c S/i Ddraft Gas
Whirlpool LET5434AN0
Whirlpool LET5434AQ0
Whirlpool LET5434AW0
Whirlpool LET5436AN0
Whirlpool LET5436AW0
Whirlpool LET5624BN0
Whirlpool LET5624BN1
Whirlpool LET5624BN2
Whirlpool LET5624BQ0
Whirlpool LET5624BQ1
Whirlpool LET5624BQ2
Whirlpool LET5624BW0
Whirlpool LET5624BW1
Whirlpool LET5624BW2
Whirlpool LET5624DQ0
Whirlpool LET5624DQ1
Whirlpool LET6634AN0
Whirlpool LET6634AN1
Whirlpool LET6634AN2
Whirlpool LET6634AQ0
Whirlpool LET6634AQ1
Whirlpool LET6634AQ2
Whirlpool LET6634AW0
Whirlpool LET6634AW1
Whirlpool LET6634AW2
Whirlpool LET6634DQ0
Whirlpool LET6634DQ1
Whirlpool LET6634DZ0
Whirlpool LET6634DZ1
Whirlpool LET6638AN0
Whirlpool LET6638AN1
Whirlpool LET6638AN2
Whirlpool LET6638AQ2
Whirlpool LET6638AW0
Whirlpool LET6638AW1
Whirlpool LET6638AW2
Whirlpool LET6638DQ0
Whirlpool LET6638DQ1
Whirlpool LET6638DZ0
Whirlpool LET6638DZ1
Whirlpool LET7646AN0
Whirlpool LET7646AQ0
Whirlpool LET7646AQ1
Whirlpool LET7646AQ2
Whirlpool LET7646AW0
Whirlpool LET7646AZ0
Whirlpool LET7646AZ1
Whirlpool LET7646AZ2
Whirlpool LET7646DQ0
Whirlpool LET7646DQ1
Whirlpool LET7646DZ0
Whirlpool LET7646DZ1
Whirlpool LET7646EQ0
Whirlpool LET7646EQ1
Whirlpool LET7646EQ2
Whirlpool LET7646EZ0
Whirlpool LET7646EZ1
Whirlpool LET7646EZ2
Whirlpool LET7848AN0
Whirlpool LET7848AQ0
Whirlpool LET7848AQ1
Whirlpool LET7848AQ2
Whirlpool LET7848AW0
Whirlpool LET7848AZ0
Whirlpool LET7848AZ1
Whirlpool LET7848AZ2
Whirlpool LET7848DQ0
Whirlpool LET7848DQ1
Whirlpool LET7848DZ0
Whirlpool LET7848DZ1
Whirlpool LET8858AN0
Whirlpool LET8858AN1
Whirlpool LET8858AN2
Whirlpool LET8858AQ0
Whirlpool LET8858AQ1
Whirlpool LET8858AQ2
Whirlpool LET8858AW0
Whirlpool LET8858AW1
Whirlpool LET8858AW2
Whirlpool LET8858AZ0
Whirlpool LET8858AZ1
Whirlpool LET8858AZ2
Whirlpool LET8858DQ0
Whirlpool LET8858DQ1
Whirlpool LET8858DZ0
Whirlpool LET8858DZ1
Amana LEU-516 Range - S/c S/i Ddraft Gas
Amana LEU-516D Range - S/c S/i Ddraft Gas
Amana LEU-516E Range - S/c S/i Ddraft Gas
Amana LEU-516G Range - S/c S/i Ddraft Gas
Amana LEU108 Range - S/c S/i Ddraft Gas
Whirlpool LEV4434AN0
Whirlpool LEV4434AW0
Whirlpool LEV4436AN0
  #2 (permalink)
Old 01-01-2013, 03:42 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Parts for Whirlpool LER8648PW0 Dryer - AppliancePartsPros.com
See the attachment for your wiring diagram.
Most like likely part is the thermal fuse (item 7 in the Bulkhead Parts section).
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
  #3 (permalink)
Old 01-01-2013, 04:21 PM
Junior Member
Default
Bypassing the thermal fuse did the trick, I'm placing an order for one from this site now. Thanks a bunch for your help!
  #4 (permalink)
Old 01-02-2013, 02:41 AM
Senior Expert
APP Volunteer
Default
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HOT POINT DRYER has power but start button doesn't start the dryer. HOT POINT Dryer Repair 2 08-01-2011 06:47 PM
Dryer wont start, sensing light just flashes when i hold down the start button! crsteilen Dryer Repair 0 03-28-2011 03:21 PM
Dryer wont start, sensing light just flashes when i hold down the start button! crsteilen Dishwasher Repair 0 03-28-2011 12:13 PM
Dryer will not start - will power up, but when push the start button, will not start perduena Dryer Repair 0 07-12-2010 07:14 PM
dryer start button flashing and not clicking to start dryer lawfamily Dryer Repair 0 06-21-2010 07:43 PM
