Discuss
Wires Burned at Timer - Frigidaire Electirc Dryer
 in
Dryer Repair
Hello and thank you in advance for any help/insight that can be given. Dryer suddenly stopped working mid-cycle (was set
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Wires Burned at Timer - Frigidaire Electirc Dryer
  #1 (permalink)
Old 12-28-2012, 12:38 AM
Junior Member
kcrisler is on a distinguished road
Default Wires Burned at Timer - Frigidaire Electirc Dryer
Model Number: fer641fso   Brand: Frigidaire   Age: 5 - 10 years
Dryer suddenly stopped working mid-cycle (was set for 60 Minutes, stopped with 40 remaining) earlier today/yesterday, 12/27/12. Chassis seemed unusually warm even for having been on High Temperature setting. Turned off breaker(which had not tripped), unplugged the dryer, turned breaker back on, and checked the outlet which was fine. I let the dryer cool down then inspected internally, first the door switch which tested fine for continuity. Opened the control panel to check the wiring and found the Red Hot wire from the terminal to the timer scorched, and the corresponding Red Hot from the timer completely burned and frayed. Terminal checked out fine, so I stripped the wires back and reconnected them, plugged the dryer back in... nothing. Any ideas on cause and solution? Thanks!
Related Models
Frigidaire FER6600ES0 Frigidaire/dryer
Frigidaire FER6600FS0 Frigidaire/dryer
Frigidaire FERB5700DS0 Frigidaire/dryer
Frigidaire FERB6600ES0 Frigidaire/dryer
Frigidaire FERB6600FS0 Frigidaire/dryer
Frigidaire FERB7800DS0 Frigidaire/dryer
Frigidaire FES300ASA Frigidaire/electric Range
Frigidaire FES300ASB Frigidaire/electric Range
Frigidaire FES300ASC Frigidaire/electric Range
Frigidaire FES300ASD Frigidaire/electric Range
Frigidaire FES300ASE Frigidaire/electric Range
Frigidaire FES300ASF Frigidaire/electric Range
Frigidaire FES300BEBA Frg(v0) / Electric Range
Frigidaire FES300BEBB Frg(v0) / Electric Range
Frigidaire FES300BEBC Frg(v0) / Electric Range
Frigidaire FES300DSA Frigidaire/electric Range
Frigidaire FES300DSB Frigidaire/electric Range
Frigidaire FES300EBA Frigidaire/electric Range
Frigidaire FES300EBB Frigidaire/electric Range
Frigidaire FES300EBC Frigidaire/range
Frigidaire FES300EBD Frigidaire/electric Range
Frigidaire FES300EBE ELECTRIC RANGE
Frigidaire FES300ESA Frigidaire/electric Range
Frigidaire FES300ESB Frigidaire/electric Range
Frigidaire FES300ESC Frigidaire/range
Frigidaire FES300ESD Frigidaire/electric Range
Frigidaire FES300WAB1 Frg(v6) / Electric Range
Frigidaire FES300WAB3 Frg(v1) / Electric Range
Frigidaire FES300WABA Frg(v3) / Electric Range
Frigidaire FES300WABC Frg(v2) / Electric Range
Frigidaire FES300WAD1 Frg(v5) / Electric Range
Frigidaire FES300WAD3 Frg(v3) / Electric Range
Frigidaire FES300WADA Frg(v2) / Electric Range
Frigidaire FES300WADC Frg(v4) / Electric Range
Frigidaire FES300WAW1 Frg(v4) / Electric Range
Frigidaire FES300WAW3 Frg(v5) / Electric Range
Frigidaire FES300WAWA Frg(v1) / Electric Range
Frigidaire FES300WAWC Frg(v6) / Electric Range
Frigidaire FES300WCD1 Frg/electric Range
Frigidaire FES300WCD2 Frg/electric Range
Frigidaire FES300WCDA Frg/electric Range
Frigidaire FES300WCDB Frg/electric Range
Frigidaire FES300WCDC Frg/electric Range
Frigidaire FES300WCDD Frg(v1) / Electric Range
Frigidaire FES300WCDE Frg/electric Range
Frigidaire FES300WCDF Frg/electric Range
Frigidaire FES300WCDG Frg(v1) / Electric Range
Frigidaire FES300WCDH Frg(v1) / Electric Range
Frigidaire FES300WCDI Frg(v1) / Electric Range
Frigidaire FES300WCW1 Frg/electric Range
Frigidaire FES300WCW2 Frg/electric Range
Frigidaire FES300WCWA Frg/electric Range
Frigidaire FES300WCWB Frg/electric Range
Frigidaire FES300WCWC Frg/electric Range
Frigidaire FES300WCWD Frg(v2) / Electric Range
Frigidaire FES300WCWE Frg/electric Range
Frigidaire FES300WCWF Frg/electric Range
Frigidaire FES300WCWG Frg(v2) / Electric Range
Frigidaire FES300WCWH Frg(v2) / Electric Range
Frigidaire FES300WCWI Frg(v2) / Electric Range
Frigidaire FES300WCWJ El Slide - in Fes300wcwj Frigidaire
Roper FES310BL0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES310BL1 30" ELECTRIC FREESTANDING SELF-CLEAN RANGE
Roper FES310BQ0 30" ELECTRIC FREE STANDING SELF CLEAN RANGE
Roper FES310BQ1 30" ELECTRIC FREESTANDING SELF-CLEAN RANGE
Roper FES310BW0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES310BW1 30" ELECTRIC FREESTANDING SELF-CLEAN RANGE
Roper FES310YW0 ELECTRIC RANGE
Roper FES310YW1 ELECTRIC RANGE
Roper FES310YW2 ELECTRIC RANGE
Roper FES325RQ0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES325RQ1 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES325RQ2 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES326RD0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES330EN0 ELECTRIC RANGES AND OVENS
Roper FES330EQ0 ELECTRIC RANGES AND OVENS
Roper FES330EW0 ELECTRIC RANGES AND OVENS
Roper FES330GN0 30" ELECTRIC FREESTANDING SELF-CLEAN RANGE
Roper FES330GN1 ELECTRIC RANGE
Roper FES330GQ0 30" ELECTRIC FREESTANDING SELF-CLEAN RANGE
Roper FES330GQ1 ELECTRIC RANGE
Roper FES330GW0 30" ELECTRIC FREESTANDING SELF-CLEAN RANGE
Roper FES330GW1 ELECTRIC RANGE
Roper FES330KN0 ELECTRIC RANGE
Roper FES330KN1 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES330KQ0 ELECTRIC RANGE
Roper FES330KQ1 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES330KW0 ELECTRIC RANGE
Roper FES330KW1 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Roper FES340VL0 ELECTRIC SELF-CLEANING OVEN
Roper FES340VW0 ELECTRIC SELF-CLEANING OVEN
Roper FES340VW1 Ranges, Electric*
Roper FES340VX0 ELECTRIC SELF-CLEANING OVEN
Roper FES340YW0 Ranges, Electric*
Roper FES340YW1 Ranges, Electric*
Roper FES340YW2 Ranges, Electric*
 FES350BL0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
 FES350BL1 30" ELECTRIC FREE-STANDING SELF-CLEAN RANGE
 FES350BW0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
 FES350BW1 30" ELECTRIC FREE-STANDING SELF-CLEAN RANGE
Frigidaire FES353CCD1 Frg/electric Wall Oven
Frigidaire FES353CCD2 Frg(v1) / Electric Range
Frigidaire FES353CCDA Frg/electric Range
Frigidaire FES353CCDB Frg(v2) / Electric Range
Frigidaire FES353CCDC Frg(v1) / Electric Range
Frigidaire FES353CCDD Frg(v1) / Electric Range
Frigidaire FES353CCDG Frg(v1) / Electric Range
Frigidaire FES353CCW1 Frg/electric Wall Oven
Frigidaire FES353CCW2 Frg(v3) / Electric Range
Frigidaire FES353CCWA Frg/electric Wall Oven
Frigidaire FES353CCWB Frg(v4) / Electric Range
Frigidaire FES353CCWC Frg(v2) / Electric Range
Frigidaire FES353CCWD Frg(v2) / Electric Range
Frigidaire FES353CCWG Frg(v2) / Electric Range
Frigidaire FES354BAB1 Frg(v2) / Electric Range
Frigidaire FES354BAB3 Frg(v0) / Electric Range
Frigidaire FES354BABA Frg(v1) / Electric Range
Frigidaire FES354BABC Frg(v0) / Electric Range
Frigidaire FES355ABA Frigidaire/electric Range
Frigidaire FES355ABB Frigidaire/electric Range
  #2 (permalink)
Old 12-28-2012, 06:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
Very likely the timer is the culprit. It can be caused by a loose connection.
- The timer Part number: 131719100
Here are the breakdown diagrams and Parts for Frigidaire FER641FS0 Dryer - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-29-2012, 08:39 AM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Hello,
Gene,
Thanks for the quick reply and help, both are very much appreciated. Happy New Year and thanks again!
Kenneth
  #4 (permalink)
Old 12-30-2012, 05:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Kenneth. Happy New year to you and your loved ones!
Keep us posted.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burned insulation on igniter wires - GE gas range pbillow Oven Repair (including Ranges and Cooktops) 1 08-20-2013 04:52 PM
Maytag dryer not heating, burned wires cmorgand Dryer Repair 1 01-06-2010 01:00 PM
Dryer Wires Where Does The Wires Go On The Timer 0425NENE Dryer Repair 1 11-18-2009 05:36 PM
burned timer(?) wires mral Dryer Repair 2 09-19-2009 08:43 PM
