Discuss
Roper Dryer no heat
 in
Dryer Repair
I have a Roper dryer model number REX4634JQ0 with no heat. I purchased a heating element from appliancepartspros.com. I installed
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Roper Dryer no heat
  #1 (permalink)
Old 12-27-2012, 04:18 PM
Junior Member
rogerd1961 is on a distinguished road
Default Roper Dryer no heat
Brand: Roper   Age: More than 10 years
I have a Roper dryer model number REX4634JQ0 with no heat. I purchased a heating element from appliancepartspros.com. I installed it, still no heat. I then purchased a thermal fuse and cycling thermostat. It heated really well for one load, then no heat again. I then purchased the high temp thermostat that mounts to the heating element, and the thermal cut off, and still no heat. All parts were purchased from appliancepartspros.com, and the last two parts were purchased at the recommendation of a live chat expert. Any ideas? Thank you.
Ads By Google
  #2 (permalink)
Old 12-27-2012, 06:18 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
HI.
Does the motor run?
Is there a 240VAC to the dryer?
I really suggest you to get a simple multimeter so you'll be able to check the parts before replacing them.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 12-28-2012, 06:06 AM
Junior Member
Bernie Bernal is on a distinguished road
Default Roper Gas Dryer RGX4634KQ2
Dryer heats on intial start but then will shut off and not heat anymore, will continue to run and dial will not time out. So far replaced dryer timer dial, thermal fuse & dryer cycling thermostat, I also vacumed out exhaust vent! What next? I should have purchased a continuity tester!
  #4 (permalink)
Old 12-28-2012, 06:26 AM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
HI.
Does the motor run?
Simon.
Yes the motor runs and the blower is working fine!
  #5 (permalink)
Old 12-28-2012, 11:11 AM
Expert
Default
Hi, Bernie.
The questions I'd posted were not addressed to you.
You have a gas dryer and it sounds like the control coils should be replaced Part number: 279834
Part number: 279834
Here are the breakdown diagrams and 8318272 Burner Assembly parts for Roper RGX4634KQ2 - AppliancePartsPros.com
Post the results.
Simon.
__________________
  #6 (permalink)
Old 12-30-2012, 06:39 AM
Junior Member
Default Finally!
Hi, Bernie.
Part number: 279834
Post the results.
Simon.
Many thanks Simon! Replaced the control coils and now the dryer works perfectly!
  #7 (permalink)
Old 12-31-2012, 03:16 PM
Expert
Default
You are welcome.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Roper Gas Dryer won't heat mamabear001 Dryer Repair 0 09-26-2009 06:06 PM
Roper Gas Dryer, No Heat, All else ok teemade Dryer Repair 0 09-22-2009 06:20 PM
Roper Gas Dryer won't heat up rgawthrop Dryer Repair 1 08-19-2009 03:34 PM
no heat to roper dryer Ernie Shipley Dryer Repair 1 04-05-2009 07:33 AM
