| » Whirpool dryer won't heat |
Model Number: LGT7646EQ2 Brand: Whirlpool Age: 5 - 10 years
I'm working on a Whirpool dryer that runs but doesn't heat. Removed the burner assembly and everything on it checks out Ok. What should I check next? Thanks
here's the parts manual: http://shared.whirlpoolcorp.com/asse...%204377829.pdf Ads By Google Related Models |
I think I should next test the thermal fuse. Can anyone look at the manual ( http://shared.whirlpoolcorp.com/asse...%204377829.pdf ) and tell me how to get to it. I'm a novice and I don't know whether if it's in the front or back! I guess you have to remove the blower housing . I just bought a multi-tester. I guess I should just test whether the fuse has continuity or not ( If I figure how to get to it!
| Display Modes | |
| whirpool gas dryer, no heat at all | john houghton | Dryer Repair | 0 | 10-18-2009 10:53 AM |
| low heat on whirpool dryer | burl cooper | Dryer Repair | 1 | 07-19-2009 02:50 AM |
| low heat on whirpool dryer | burl cooper | Dryer Repair | 1 | 07-18-2009 07:35 AM |
| Whirpool gas dryer will not heat | smsgtweber | Dryer Repair | 0 | 12-08-2007 08:48 PM |
| Whirpool Dryer will not heat up | GaryA | Dryer Repair | 1 | 12-06-2007 03:21 PM |
