| » Whirpool dryer won't heat |
Model Number: LGT7646EQ2 Brand: Whirlpool Age: 5 - 10 years
I'm working on a Whirpool dryer that runs but doesn't heat. Removed the burner assembly and everything on it checks out Ok. What should I check next? Thanks
here's the parts manual: http://shared.whirlpoolcorp.com/asse...%204377829.pdf |
I think I should next test the thermal fuse. Can anyone look at the manual ( http://shared.whirlpoolcorp.com/asse...%204377829.pdf ) and tell me how to get to it. I'm a novice and I don't know whether if it's in the front or back! I guess you have to remove the blower housing . I just bought a multi-tester. I guess I should just test whether the fuse has continuity or not ( If I figure how to get to it!
| Display Modes | |
| whirpool won't drain | Markks | Dishwasher Repair | 1 | 02-02-2008 04:16 PM |
| Whirpool Ultimate Care II | pauleyg | Washer Repair | 0 | 02-02-2008 03:39 PM |
| Whirpool Dryer heating issues | dbreg | Dryer Repair | 1 | 01-04-2008 03:24 PM |
| Whirpool gas dryer will not heat | smsgtweber | Dryer Repair | 0 | 12-08-2007 09:48 PM |
| Whirpool Dryer will not heat up | GaryA | Dryer Repair | 1 | 12-06-2007 04:21 PM |
