| » Switching to a 4 prong cord |
A model number would help me find the actual install sheet.
Normally you would do the following but it would be a good idea to confirm this with a install sheet. Black from the power cord goes to the left terminal strip connector. The white attached to the frame gets disconnected and attached to the center terminal strip connector, also the white from the power cord goes to the center terminal. The red from the power cord goes to the right terminal strip connector. The green from the power cord gets connected to the place where the original white wire was connected to the frame.
__________________
| Display Modes | |
| Changing from a Four Prong cord to a Three Prong Cord | KimMerc | Dryer Repair | 3 | 10-23-2012 09:11 AM |
| Converting from a 3-prong cord to a 4-prong dryer cord | VLHastings | Dryer Repair | 1 | 11-17-2011 06:23 AM |
| changing 3 prong dryer cord to 4 prong | russb | Dryer Repair | 1 | 08-12-2011 11:14 AM |
| 4 prong power cord - 3 prong wall outlet??? | BradleyT | Dryer Repair | 0 | 08-09-2011 04:45 PM |
| Washer machine power cord 3 prong missing ground prong REplace? Is it ok? | maddy | Washer Repair | 1 | 06-17-2011 04:36 PM |
