| » Frigidare dryer won't turn off |
Model Number: FDE847GCS0 Brand: Frigidaire Age: More than 10 years
The dryer will not stop running. I have tried all cycles and they all do the same thing. I assumed it was the timer but did not know how to test it. This dryer also has the "auto reversing" feature I would like to eliminate. It is noisy and I believe it may be responsible for catching the clothes between the drum and housing leaving burn type marks on our clothes. Can I easily wire around that circuit board?
I would try changing out the push to start switch, as it is inexpensive and if it is not the problem it can be ruled out.
Part number: AP4358840 Given the age of the dryer and your problem with clothes catch and burning I would say that if the push to start switch change does not fix things then you should consider replacing the dryer. I don't think it is an economical decision to invest in a new timer. As far as re-wiring circuits, I would leave it alone. If the situation is unacceptable I would replace the machine.
__________________
| Display Modes | |
| frigidare gas dryer won't heat | smokey | Dryer Repair | 1 | 07-16-2009 07:03 PM |
| Frigidare Dryer | Lisa Minor | Dryer Repair | 1 | 07-16-2009 06:18 PM |
| Kenmore/frigidare dryer no heat | johny | Dryer Repair | 8 | 02-27-2009 04:20 AM |
| coin op dryer timer starts but dryer doesn't turn on | Mike Craw | Dryer Repair | 4 | 01-10-2008 07:26 PM |
| Frigidare dryer with no heat | bit1001001 | Dryer Repair | 1 | 11-02-2007 02:34 PM |
