| » No heat - PLEASE help!!!! |
Model Number: GLER341AS2 Brand: Frigidaire Age: 5 - 10 years
Need help! Our dryer is spinning when turned on, but no heat. There is no electric boards or panel on this unit.
After reading online, we (my husband) changed out the Heating Assembly Unit (large round unit with coil). Put the dryer back together and still no heat. Read that turning the breaker on/off could possibly solve the problem. That did not work. Still no heat. FRUSTRATED and he wants to just get a new dryer. Ummm...no. Not sure how to check if the fuse is blown. Looks perfetly normal, not black/brown/discolored. Everything else is functioning. ANY help would be greatly appreciated. THANK YOU in advance! Jen Ads By Google Related Models |
Hi.
First check if there is 240VAC at the dryer connector block. If it is next check the control and hi-limit thermostats. Control thermostat Part number: 131298300 Located on the blower housing. Hi-limit Part number: 3204267 Located on the top right of the heater housing. You need to have a multimeter to run the continuity tests or otherwise you will continue buying unnecessary parts. Here are the breakdown diagrams and Cabinet / Drum parts for Frigidaire GLER341AS2 - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 12-14-2012 at 05:01 PM. |
Thanks for your reply! My husband took those 2 parts to the appliance store. They tested them and said they were functioning properly. So he came home with a voltage tester and despite turning on/off the breaker, the breaker was bad.
So, we have a new/spare heating element and breaker - most important - proper functioning dryer. Thank you for taking time to help us out!! |
You are welcome.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| No heat and leads to oven heat element only showing 110volts | nobull1466 | Oven Repair (including Ranges and Cooktops) | 7 | 06-07-2012 11:23 AM |
| Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat | dsumption | Oven Repair (including Ranges and Cooktops) | 3 | 04-04-2011 05:03 PM |
| gas dryer only heats on perm press and low heat, but not on high heat? | GrandCanyonEngineer | Dryer Repair | 0 | 03-02-2011 02:23 PM |
| No High Heat, Medium heat work fine! | Scubadude | Dryer Repair | 0 | 09-07-2010 05:39 PM |
| Normal Heat Empty, Heat Shuts Off Full | BigDaddyG | Dryer Repair | 4 | 08-06-2009 03:17 PM |
