Discuss
No heat
 in
Dryer Repair
My dryer will not flame up. Thermal fuse tested open replaced fuse. Igniter glows now still no flame. Replaced Igniter
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No heat
  #1 (permalink)
Old 12-14-2012, 05:25 AM
Junior Member
zippo is on a distinguished road
Default No heat
Model Number: LGR5636EQ3   Brand: Whirlpool   Age: 5 - 10 years
My dryer will not flame up. Thermal fuse tested open replaced fuse. Igniter glows now still no flame. Replaced Igniter and both Gas Valve Coils still no flame. Flame Sensor test closed. High Limit Thermostat test closed. Cycling Thermostat larg prongs test closed small prongs test 7 ohms resitance. Im thinking gas valve but just don't wont to keep throwing parts at it. If it is the gas valve should I replace the LP conversion kit or can I use the old one? Any help with this would be greatly appreciated.
Thank You
zippo
Ads By Google
Related Models
Whirlpool LGR5636EQ3
Whirlpool LGR5636EZ0
Whirlpool LGR5636EZ1
Whirlpool LGR5636EZ2
Whirlpool LGR5636EZ3
Whirlpool LGR5636JQ0
Whirlpool LGR5636JQ1
Whirlpool LGR5636JT0
Whirlpool LGR5636JT1
Whirlpool LGR5636KQ0
Whirlpool LGR5636KQ1
Whirlpool LGR5636KT0
Whirlpool LGR5636KT1
Whirlpool LGR5636LG0
Whirlpool LGR5636LQ0
Whirlpool LGR5636LQ1 29"gas Dryer
Whirlpool LGR5636LT0
Whirlpool LGR5636LT1 29"gas Dryer
Whirlpool LGR5636LW0
Whirlpool LGR5636PQ0 29"gas Dryer
Whirlpool LGR5636PQ1 29"gas Dryer
Whirlpool LGR5636PT0 29"gas Dryer
Whirlpool LGR5636PT1 29"gas Dryer
Whirlpool LGR5638AN0
Whirlpool LGR5638AN1
Whirlpool LGR5638AN2
Whirlpool LGR5638AN3
Whirlpool LGR5638AW0
Whirlpool LGR5638AW1
Whirlpool LGR5638AW2
Whirlpool LGR5638AW3
Whirlpool LGR5644AN0
Whirlpool LGR5644AN1
Whirlpool LGR5644AN2
Whirlpool LGR5644AW0
Whirlpool LGR5644AW1
Whirlpool LGR5644AW2
Whirlpool LGR5644EQ0
Whirlpool LGR5644EQ1
Whirlpool LGR5644EQ2
Whirlpool LGR5644EQ3
Whirlpool LGR5644EZ0
Whirlpool LGR5644EZ1
Whirlpool LGR5644EZ2
Whirlpool LGR5644EZ3
Whirlpool LGR5644JQ0
Whirlpool LGR5644JQ1
Whirlpool LGR5644JQ2
Whirlpool LGR5644JQ3 29" Gas Dryer
Whirlpool LGR5644JT0
Whirlpool LGR5644JT1
Whirlpool LGR5644JT2
Whirlpool LGR5644JT3 29" Gas Dryer
Whirlpool LGR5644PQ0 29" Gas Dryer
Whirlpool LGR5644PQ1 29" Gas Dryer
Whirlpool LGR5700KQ0
Whirlpool LGR5700KQ1
Whirlpool LGR5700KT0
Whirlpool LGR5700KT1
Whirlpool LGR5848EQ0
Whirlpool LGR5848EQ1
Whirlpool LGR5848EQ2
Whirlpool LGR5848EQ3
Whirlpool LGR5848EQ4
Whirlpool LGR5848EQ5
Whirlpool LGR5848EQ6
Whirlpool LGR6611LQ0
Whirlpool LGR6611LQ1 29"gas Dryer
Whirlpool LGR6611PQ0 29" Gas Dryer
Whirlpool LGR6620PQ0 29"gas Dryer
Whirlpool LGR6620PQ1 29"gas Dryer
Whirlpool LGR6620PT0 29"gas Dryer
Whirlpool LGR6620PT1 29"gas Dryer
Whirlpool LGR6621PQ0 29" Gas Dryer
Whirlpool LGR6634BN0
Whirlpool LGR6634BN1
Whirlpool LGR6634BN2
Whirlpool LGR6634BQ0
Whirlpool LGR6634BQ1
Whirlpool LGR6634BQ2
Whirlpool LGR6634BW0
Whirlpool LGR6634BW1
Whirlpool LGR6634BW2
Whirlpool LGR6634DQ0
Whirlpool LGR6634DQ1
Whirlpool LGR6634DW0
Whirlpool LGR6634DW1
Whirlpool LGR6634DZ0
Whirlpool LGR6634DZ1
Whirlpool LGR6636PW0 29" Gas Dryer
Whirlpool LGR6636PW1 29" Gas Dryer
Whirlpool LGR6638DQ0
Whirlpool LGR6638DQ1
Whirlpool LGR6638DW0
Whirlpool LGR6638DW1
Whirlpool LGR6638DZ0
Whirlpool LGR6638DZ1
Whirlpool LGR6644DQ0
Whirlpool LGR6644DQ1
Whirlpool LGR6644DZ0
Whirlpool LGR6644DZ1
Whirlpool LGR6646BN0
Whirlpool LGR6646BN1
Whirlpool LGR6646BN2
Whirlpool LGR6646BW0
Whirlpool LGR6646BW1
Whirlpool LGR6646BW2
Whirlpool LGR6646DN1
Whirlpool LGR6646DW1
Whirlpool LGR6646PW0 29" Gas Dryer
Whirlpool LGR6646PW1 29" Gas Dryer
Whirlpool LGR6848AN0
Whirlpool LGR6848AN1
Whirlpool LGR6848AN2
Whirlpool LGR6848AQ2
Whirlpool LGR6848AW0
Whirlpool LGR6848AW1
Whirlpool LGR6848AW2
Whirlpool LGR6848AZ2
Whirlpool LGR7620KQ0
  #2 (permalink)
Old 12-14-2012, 01:04 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
The flame sensor should open at 1500F allowing the current to go to the control coils.
With power disconnected remove both wires from the sensor, shorten them, restore the power and after the ignitor will glow - disconnect them.
If the gas ignites - replace the flame sensor.
If not - gas valve (assuming the gas is open).
Here are the breakdown diagrams and http://www.appliancepartspros.com/34...gr5636eq3.html
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
No heat and leads to oven heat element only showing 110volts nobull1466 Oven Repair (including Ranges and Cooktops) 7 06-07-2012 11:23 AM
Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat dsumption Oven Repair (including Ranges and Cooktops) 3 04-04-2011 05:03 PM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 02:23 PM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 09:33 PM
