Finally hooking up my never been used 2008 Frigidaire Gallery gas dryer...converted from NG to LP with the proper conversion kit for the machine. We've never had a gas dryer so we're not sure how it's supposed to look/work. Our concern is a sputtering of the lp gas... I put the machine on high temp and to run for 60 min with nothing in the dryer just to test the machine since it was the first start up...we get a blue/orange flame but it sputters yellow & flashes. Runs for about 2 minutes and then the gas shuts off for a bit and then the ignitor glows, lights and the same thing happens again. Is the sputtering/flashing normal? Here's a link to a video I made...
http://youtu.be/UarA-tpDxrM you can see it sputter a few times...the best example is @ 1:08 of the video...any help? Thanks in advance
Related Models
