Discuss
Maytag Dryer won't start when hot
 in
Dryer Repair
I have a Maytag Electric dryer M# PYET444AYW that sometimes will not start when it is hot. It will start
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Dryer won't start when hot
  #1 (permalink)
Old 12-09-2012, 06:58 PM
Junior Member
MrFrisco is on a distinguished road
Default Maytag Dryer won't start when hot
Model Number: PYET444AYW   Brand: Maytag   Age: More than 10 years
I have a Maytag Electric dryer M# PYET444AYW that sometimes will not start when it is hot. It will start and run after it sits for a while.
Does this unit have a self resetting thermostat or fuse? If not I assume the motor is the likely culprit?
p.s. I installed a new Timer assy about 3 months ago
Ads By Google
Related Models
Maytag PYET444AYW Dryer - Ele
Maytag PYET444AZW Dryer - Ele
Maytag PYG1000AWW Dryer - Gas
Maytag PYG2000AWW Dryer - Gas
Maytag PYG2200AWW Dryer - Gas
International PYG2300AGW Dryer - Gas
Maytag PYG2300AWW Dryer - Gas
Maytag PYG3200AWW Dryer - Gas
Maytag PYG3250AWW Dryer - Gas
Maytag PYG3300AWW Dryer - Gas
Maytag PYG3360AWW Dryer - Gas
Maytag PYG4500AWQ Dryer - Gas
Maytag PYG4500AWW Dryer - Gas
Maytag PYG4557AWW Dryer - Gas
Maytag PYG4558AWW Dryer - Gas
International PYGS244AWW Dryer - Gas
Maytag PYGT244AWW Dryer - Gas
Maytag PYGT344AWW Dryer - Gas
Maytag PYGT444AWQ Dryer - Gas
Maytag PYGT444AWW Dryer - Gas
Amana QDO-695 Range - S/c S/i Ddraft Gas
Amana QDO-695D Range - S/c S/i Ddraft Gas
Amana QDO-695E Range - S/c S/i Ddraft Gas
Amana QDO-695F Range - S/c S/i Ddraft Gas
Amana QDO-695G Range - S/c S/i Ddraft Gas
Amana QDO-695H Range - S/c S/i Ddraft Gas
Amana QDU-838 Range - S/c S/i Ddraft Gas
Amana QDU-838A Range - S/c S/i Ddraft Gas
Amana QDU-838B Range - S/c S/i Ddraft Gas
Amana QDU-838C Range - S/c S/i Ddraft Gas
Amana QDU-838D Range - S/c S/i Ddraft Gas
Amana QDU-838G Range - S/c S/i Ddraft Gas
Amana QDU-858 Range - S/c S/i Ddraft Gas
Amana QDU-858A Range - S/c S/i Ddraft Gas
Amana QDU-858B Range - S/c S/i Ddraft Gas
Amana QDU-858C Range - S/c S/i Ddraft Gas
Amana QDU-858D Range - S/c S/i Ddraft Gas
Amana QDU-858E Range - S/c S/i Ddraft Gas
Amana QDU-858G Range - S/c S/i Ddraft Gas
Amana QDU-878 Range - S/c S/i Ddraft Gas
Amana QDU-878A Range - S/c S/i Ddraft Gas
Amana QDU-878B Range - S/c S/i Ddraft Gas
Amana QDU-966 Range - S/c S/i Ddraft Gas
Amana QDU-976 Range - S/c S/i Ddraft Gas
Amana QDU-976A Range - S/c S/i Ddraft Gas
Amana QKO-661 Range - S/c S/i Ddraft Gas
Amana QKO-661B Range - S/c S/i Ddraft Gas
Amana QKO-661C Range - S/c S/i Ddraft Gas
Amana QKO-661D Range - S/c S/i Ddraft Gas
Amana QKO-661E Range - S/c S/i Ddraft Gas
Amana QKO-751 Range - S/c S/i Ddraft Gas
Amana QKO-751A Range - S/c S/i Ddraft Gas
Amana QKU-647 Range - S/c S/i Ddraft Gas
Amana QKU-647A Range - S/c S/i Ddraft Gas
Amana QMC811 Walloven - Std Mwave Ele
Amana QMD-800 Mwave - Family Size (60 Hz)
Amana QMD-800A Mwave - Family Size (60 Hz)
Amana QMD-800B Mwave - Family Size (60 Hz)
Amana QMD-800C Mwave - Family Size (60 Hz)
Amana QMD-800D Mwave - Family Size (60 Hz)
Amana QMD-800E Mwave - Family Size (60 Hz)
Amana QMD-800G Mwave - Family Size (60 Hz)
Amana QMD-810 Mwave - Family Size (60 Hz)
Amana QMD-810A Mwave - Family Size (60 Hz)
Amana QMD800 Walloven - Std Mwave Ele
Amana QMD800D Mwave - Family Size (60 Hz)
Amana QMD810 Walloven - Std Mwave Ele
Amana R-1 Range - S/c S/i Ddraft Gas
Amana R-1H Range - S/c S/i Ddraft Gas
Amana R-1J Mwave - Family Size (60 Hz)
Amana R-2 Range - S/c S/i Ddraft Gas
Amana R-3 Mwave - Family Size (60 Hz)
Amana R0-24-8 Mwave - Mounted Over Range/wo
Whirlpool R101
Whirlpool R1011
Whirlpool R1012
Whirlpool R1013
Whirlpool R1014
Whirlpool R121
Whirlpool R1211
Whirlpool R1212
Whirlpool R1213
Whirlpool R1231
Whirlpool R141A
Whirlpool R141A1
Whirlpool R141F0
Whirlpool R141G0
Amana R15 Misc / Accessory
Whirlpool R153
Amana R15A Misc / Accessory
Amana R15L Misc / Accessory
Amana R15LA Misc / Accessory
Whirlpool R183
Whirlpool R183A
Whirlpool R183A1
Whirlpool R183A2
Whirlpool R183A3
Whirlpool R183F0
Whirlpool R183G0
Whirlpool R183G1
Amana R1E Mwave - Family Size (60 Hz)
Jenn-Air R200 Surface Unit - Ddraft Ele
Frigidaire R2000DL0 Frg(v1) / Electric Range
Frigidaire R2000DW0 Frg(v2) / Electric Range
Frigidaire R2000LL1 Frg(v1) / Electric Range
Frigidaire R2000LW1 Frg(v2) / Electric Range
Jenn-Air R201 Surface Unit - Ddraft Ele
Jenn-Air R201-C Surface Unit - Ddraft Ele
Frigidaire R21CL0 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL1 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL2 Frg(v2) / Electric Range
Frigidaire R21CL3 Frg(v4) / Electric Range
Frigidaire R21CL4 Frg(v6) / Electric Range
  #2 (permalink)
Old 12-10-2012, 11:58 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts, includes a wiring diagram.
Parts for Maytag PYET444AYW Dryer - AppliancePartsPros.com
No there is nothing like that in the start circuit except for the thermal protect in the motor. Your assumption is correct.
It could be that the motor is on it's last legs or there may be another cause for the motor overheating.
Try rotating the drum in the correct direction. It should turn fairly easily. If not perhaps there is a problem with the drum supports etc. that is putting too much drag on the moor causing it to overheat. You may want to try this on a couple other units just to get a feel for it.
TTry running the unit in a no heat cycle. If the unit does not show your problem, it could be that hot air is blowing back onto the motor causing it to overheat. Clean your vent system and the blower wheel.
Check the seals in the unit.
Also clean/check the motor could be it is clogged solid with lint.
__________________
  #3 (permalink)
Old 12-10-2012, 02:58 PM
Junior Member
Default
Thanks, will check it out
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
MAytag gas dryer won't start doma135 Dryer Repair 1 08-24-2012 02:46 PM
Maytag dryer won't start crmullins Dryer Repair 3 07-18-2012 12:56 PM
Maytag dryer won't start isak Dryer Repair 0 02-05-2012 01:23 PM
Maytag dryer won't start cah14522 Dryer Repair 8 02-14-2011 09:01 AM
maytag dryer will not start Kevin B Dryer Repair 2 10-14-2009 02:28 PM
