| » Converted a dryer from LP to gas, Question |
Model Number: 110 Brand: Kenmore Age: 5 - 10 years
I'd like to make sure I did this conversion properly. This is a Kenmore dryer model starting 110. The appliance store sold me a new orifice (#42) and new regulator spring and rubber stopper piece that threads in over the spring, and a new brass cap that goes over the stopper and spring. The spring and rubber piece look identical to the old ones, I'm wondering if I really needed replacements. The brass cap however, no longer has the long white plastic stem that the old propane version had. Also there is no real indication of how far that rubber piece was supposed to be screwed in, it will just keep going if you want to. I eyeballed it to go into the regulator just enough so that the brass cap would thread all the way in behind it. I realize this all sounds confusing, I don't know how else to explain it. The orifice replacement was simple and straightforward I have no issue there. The dryer is working, but I wanted to run this by someone who knows, to let me know if there is something I may have done improperly.
| Display Modes | |
| Partially converted Nat to LP | gmbdinc | Oven Repair (including Ranges and Cooktops) | 0 | 09-12-2011 09:18 AM |
| Can a gas hvac be converted over to electric? | justonelaw | Heating, Ventilation, and Air Conditioning (HVAC) | 1 | 06-30-2010 07:38 PM |
| Can this dryer be converted to LP? | Kylebrockschmidt | Dryer Repair | 1 | 04-26-2010 06:10 PM |
| Converted back to Ng | tnfitz2003 | Oven Repair (including Ranges and Cooktops) | 1 | 04-07-2009 06:25 PM |
| Converted to LP, now need to convert back to NG | hermioneulster | Dryer Repair | 5 | 03-25-2009 07:18 PM |
