Discuss
Dryer with no heat
 in
Dryer Repair
This dryer will not make heat. 240 volts to the dryer, element test okay (9.8 ohm), continuity on the cut
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer with no heat
  #1 (permalink)
Old 12-07-2012, 05:23 AM
Junior Member
teb02 is on a distinguished road
Default Dryer with no heat
Model Number: 11085862400   Brand: Kenmore   Age: 1 - 5 years
This dryer will not make heat. 240 volts to the dryer, element test okay (9.8 ohm), continuity on the cut out, high limit, thermal fuse, and the thermistor test 15k at 60 degrees. A test on the control showed a reading higher than what KM's tech sheet said to replace the control. I put in a new control and no heat. What else could it be, a motor switch. I put an new motor in, and no heat. All the wiring and connectors look good. What would you try to do?
Ads By Google
Related Models
Kenmore 11086070200 ELECTRIC DRYER
Kenmore 11086070210 ELECTRIC DRYER
Kenmore 11086070400 ELECTRIC DRYER
Kenmore 11086070410 ELECTRIC DRYER
Kenmore 11086070600 ELECTRIC DRYER
Kenmore 11086070610 ELECTRIC DRYER
Kenmore 11086070800 ELECTRIC DRYER
Kenmore 11086070810 ELECTRIC DRYER
Kenmore 11086071100 ELECTRIC DRYER
Kenmore 11086071110 ELECTRIC DRYER
Kenmore 11086071120 ELECTRIC DRYER
Kenmore 11086071130 ELECTRIC DRYER
Kenmore 11086071200 ELECTRIC DRYER
Kenmore 11086071210 ELECTRIC DRYER
Kenmore 11086071220 ELECTRIC DRYER
Kenmore 11086071230 ELECTRIC DRYER
Kenmore 11086071400 ELECTRIC DRYER
Kenmore 11086071410 ELECTRIC DRYER
Kenmore 11086071420 ELECTRIC DRYER
Kenmore 11086071430 ELECTRIC DRYER
Kenmore 11086071600 ELECTRIC DRYER
Kenmore 11086071610 ELECTRIC DRYER
Kenmore 11086071620 ELECTRIC DRYER
Kenmore 11086071630 ELECTRIC DRYER
Kenmore 11086071800 ELECTRIC DRYER
Kenmore 11086071810 ELECTRIC DRYER
Kenmore 11086071820 ELECTRIC DRYER
Kenmore 11086071830 ELECTRIC DRYER
Kenmore 11086082100 ELECTRIC DRYER
Kenmore 11086082110 ELECTRIC DRYER
Kenmore 11086082120 ELECTRIC DRYER
Kenmore 11086082200 ELECTRIC DRYER
Kenmore 11086082210 ELECTRIC DRYER
Kenmore 11086082220 ELECTRIC DRYER
Kenmore 11086082400 ELECTRIC DRYER
Kenmore 11086082410 ELECTRIC DRYER
Kenmore 11087070100 AUTOMATIC DRYER
Kenmore 11087070200 AUTOMATIC DRYER
Kenmore 11087070400 AUTOMATIC DRYER
Kenmore 11087070600 AUTOMATIC DRYER
Kenmore 11087070800 AUTOMATIC DRYER
Kenmore 11087273100 GAS DRYER
Kenmore 11087273200 GAS DRYER
Kenmore 11087273400 GAS DRYER
Kenmore 11087273600 GAS DRYER
Kenmore 11087273800 GAS DRYER
Kenmore 11087274100 GAS DRYER
Kenmore 11087274200 GAS DRYER
Kenmore 11087274400 GAS DRYER
Kenmore 11087274600 GAS DRYER
Kenmore 11087274800 GAS DRYER
Kenmore 11087294130 GAS DRYER
Kenmore 11087294140 GAS DRYER
Kenmore 11087294150 GAS DRYER
Kenmore 11087294330 GAS DRYER
Kenmore 11087294340 GAS DRYER
Kenmore 11087294350 GAS DRYER
Kenmore 11087294530 GAS DRYER
Kenmore 11087294540 GAS DRYER
Kenmore 11087294550 GAS DRYER
Kenmore 11087294730 GAS DRYER
Kenmore 11087294740 GAS DRYER
Kenmore 11087294750 GAS DRYER
Kenmore 11087294830 GAS DRYER
Kenmore 11087294840 GAS DRYER
Kenmore 11087294850 GAS DRYER
Kenmore 11087370210 ELECTRIC DRYER
Kenmore 11087379100 GAS DRYER
Kenmore 11087379120 GAS DRYER
Kenmore 11087379130 GAS DRYER
Kenmore 11087379200 GAS DRYER
Kenmore 11087379320 GAS DRYER
Kenmore 11087379330 GAS DRYER
Kenmore 11087379400 GAS DRYER
Kenmore 11087379600 GAS DRYER
Kenmore 11087379620 GAS DRYER
Kenmore 11087379630 GAS DRYER
Kenmore 11087379720 GAS DRYER
Kenmore 11088090100 ELECTRIC DRYER
Kenmore 11088090200 ELECTRIC DRYER
Kenmore 11088090400 ELECTRIC DRYER
Kenmore 11088090600 ELECTRIC DRYER
Kenmore 11088090800 ELECTRIC DRYER
Kenmore 11088182890 ELECTRIC DRYER
Kenmore 11088182891 COMPACT ELECTRIC DRYER
Kenmore 11088184890 ELECTRIC DRYER
Kenmore 11088184891 COMPACT ELECTRIC DRYER
Kenmore 11088390100 ELECTRIC DRYER
Kenmore 11088390110 ELECTRIC DRYER
Kenmore 11088390120 ELECTRIC DRYER
Kenmore 11088390130 ELECTRIC DRYER
Kenmore 11088390200 ELECTRIC DRYER
Kenmore 11088390210 ELECTRIC DRYER
Kenmore 11088390300 ELECTRIC DRYER
Kenmore 11088390310 ELECTRIC DRYER
Kenmore 11088390320 ELECTRIC DRYER
Kenmore 11088390330 ELECTRIC DRYER
Kenmore 11088390400 ELECTRIC DRYER
Kenmore 11088390410 ELECTRIC DRYER
Kenmore 11088390600 ELECTRIC DRYER
Kenmore 11088390610 ELECTRIC DRYER
Kenmore 11088390620 ELECTRIC DRYER
Kenmore 11088390630 ELECTRIC DRYER
Kenmore 11088390700 ELECTRIC DRYER
Kenmore 11088390710 ELECTRIC DRYER
Kenmore 11088390720 ELECTRIC DRYER
Kenmore 11088390730 ELECTRIC DRYER
Kenmore 11088390800 ELECTRIC DRYER
Kenmore 11088390810 ELECTRIC DRYER
Kenmore 11088390820 ELECTRIC DRYER
Kenmore 11088390830 ELECTRIC DRYER
Kenmore 11088416100 ELECTRIC DRYER
Kenmore 11088416110 ELECTRIC DRYER
Kenmore 11088416120 ELECTRIC DRYER
Kenmore 11088416130 ELECTRIC DRYER
Kenmore 11088416200 ELECTRIC DRYER
Kenmore 11088416210 ELECTRIC DRYER
Kenmore 11088416300 ELECTRIC DRYER
Kenmore 11088416310 ELECTRIC DRYER
Kenmore 11088416320 ELECTRIC DRYER
  #2 (permalink)
Old 12-07-2012, 12:32 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Check if there is 240VAC at the terminal block.
Remove one leg(wire) from the heater and check which leg doesn't have 120VAC. Trace that wire up.
Did you replace the control board or the user interface control?
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 12-07-2012, 12:54 PM
Junior Member
Default
There is 240 to the terminal. I replaced the control board, I did not replace the touch pad or user interface.
I will check the voltage as you suggested. Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 02:23 PM
Dryer stops after a few minutes with heat on - will run continuously with heat off somegeek Dryer Repair 0 05-27-2010 01:35 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
