| » DryerRuns butNo HEAT |
Model Number: WED8300SW2 Brand: Whirlpool Age: 1 - 5 years
A friends dryer runs, but will not heat. I can use a DMM and I have one. I looked on the inside of the dryer and found a blown light bulb. Can that light bulb break the circuit to the heat. I have never worked on a dryer before. I have worked on central heat in homes. Any ideas where to start looking for the problem will be very helpful to me. Please help and thank you.
Parts for Whirlpool WED8300SW2 Dryer - AppliancePartsPros.com Often clicking on a part's picture will bring up a new page with more info on it. See the attachment for the tech sheet. Can that light bulb break the circuit to the heat. No. Unless it blew in a way that created a spark and that spark blew the control board. The heating element requires 240 volts, everything else runs off of 120 so I would start by checking the power. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. Be careful as 240 volts is lethal !!! Next unplug the unit and check the heating element, should be 8 to 12 ohms. Then the thermal cut-off, should be 0 ohms. Then the hi-limit thermostat, should be 0 ohms. If the thermal cut-off is blown there are other things you have to check before replacing it.
__________________
Quote:
The F28 is probably OK.
The way it works is that the unit applies a voltage to one of the sensor strips, the other strip is attached to ground. When the clothes are wet there is a current path between the strips due to the moisture, a small current flows. The board senses this and holds the timer off. When the clothes are dry, no moisture, no current path and the timer advances. So I would think that if the sensor is clean it should be an open circuit.
__________________
| Display Modes | |
| No heat and leads to oven heat element only showing 110volts | nobull1466 | Oven Repair (including Ranges and Cooktops) | 7 | 06-07-2012 11:23 AM |
| Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat | dsumption | Oven Repair (including Ranges and Cooktops) | 3 | 04-04-2011 05:03 PM |
| gas dryer only heats on perm press and low heat, but not on high heat? | GrandCanyonEngineer | Dryer Repair | 0 | 03-02-2011 02:23 PM |
| Dryer stops after a few minutes with heat on - will run continuously with heat off | somegeek | Dryer Repair | 0 | 05-27-2010 01:35 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
