| » Frigidaire Affinity dryer power |
Model Number: Aeq7000eg0 Brand: Frigidaire Age: 1 - 5 years
Wired my dryer wrong and it tripped breaker and burnt out thermal limiter. Replaced thermal limiter, wired cord correctly and still no power to dryer. What else could be wrong?
Parts for Frigidaire AEQ7000EG0 Dryer - AppliancePartsPros.com See the attachment for the tech sheet. I would start by checking the power. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. Be careful as 240 volts is lethal !!! I am not sure why the thermal limiter blew but even with it blown I think you should get some indication of power on the display. As far as I can see the limiter just kills power yo the motor and drum light but I am not 100% sure about this. Could be you blew the control board.
__________________
| Display Modes | |
| Frigidaire Affinity Gas dryer | Suresh Sikka | Dryer Repair | 0 | 03-10-2012 08:13 AM |
| Frigidaire Affinity dryer error code E61 | napclan6 | Dryer Repair | 4 | 02-12-2012 06:23 PM |
| Disassemble Frigidaire Affinity Dryer | PIXZAN | Dryer Repair | 0 | 12-26-2011 02:23 PM |
| frigidaire affinity dryer | dbrown1@ctc.net | Dryer Repair | 2 | 12-26-2011 02:13 PM |
| Error Code E04 on Frigidaire Affinity Dryer | Soarer | Dryer Repair | 3 | 02-23-2011 05:18 AM |
