| » Dryer won't heat |
Model Number: GLER341A52 Brand: Frigidaire Age: 5 - 10 years
Hello there,
My electric dryer turns but there is no heat; clothes do not dry. I called a handyman to look at it. He brought out some type of a reading device and says heating "element" is okay. He wants to replace the DOOR SWITCH; he says that it looks like it may not be connected properly. I believe this part sits behind the rectangular opening located in the upper right hand side of the opened front door. He also says that there is a bottom switch located on the inside panel of the front door that he wants to replace. Other than that, he doesn't know what else could be the problem b/c everything else checks out. What do you think? Any suggestions? I already appreciate your attention and feedback. Ads By Google Related Models |
Hi.
I do not think that your handyman is an experienced repairman. Get another one. Check if there is 240VAC to the dryer first of all. Then there are control and hi milt thermostats to be checked. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 12-06-2012 at 01:19 PM. |
| Display Modes | |
| gas dryer only heats on perm press and low heat, but not on high heat? | GrandCanyonEngineer | Dryer Repair | 0 | 03-02-2011 02:23 PM |
| Kenmore dryer heats on low heat but not on high heat | Mrhollywood334 | Dryer Repair | 0 | 09-11-2010 09:33 PM |
| Dryer stops after a few minutes with heat on - will run continuously with heat off | somegeek | Dryer Repair | 0 | 05-27-2010 01:35 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
