| » Dryer no heat |
Model Number: ied4400sq0 Brand: Whirlpool Age: 1 - 5 years
Need help with Dryer.
No heat all of a sudden. Need to know what parts need to be checked. Can I get a possible list. Did not trip but shut off curcuit breaker and turned it back on. Changed out heat element, still doesn't work. Disconnected wires from list below and measured Ohms and this is what I got and need feedback. Heating element-10 ohms Thermal fuse (2 blue wires) .4 ohms Thermal cut off kit? top thermostat-no reading when unplugged -when plugged in 9.75 Ohms Bottom themostat-.8 ohms Cycling thermostat- (4 wires) red-red .4 ohms violet-violet 7.04 ohms As far as I know, I'm measuring correctly. Any comments would be helpful. Thank you Ads By Google Related Models Last edited by vvmac : 12-04-2012 at 10:57 AM. |
Hi.
Based on the information you provided you need to replace the thermal cut-off kit Part number: 279816 After replacing it check the dryer vent (internal and external) for restrictions. Here are the breakdown diagrams and 03-Bulkhead Parts, Optional Parts (not Included) parts for Whirlpool IED4400SQ0 - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
I will order the parts and let you know. I already checked the vents, all clear. |
Did you remove and clean the lint chute #1 on the diagram?
Simon.
__________________
Quote:
I got my parts this morning and installed them and I now have heat!! and yes, I cleaned out the chute. Thank you so much for your help. |
You are welcome.
Simon.
__________________
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| gas dryer only heats on perm press and low heat, but not on high heat? | GrandCanyonEngineer | Dryer Repair | 0 | 03-02-2011 02:23 PM |
| Dryer stops after a few minutes with heat on - will run continuously with heat off | somegeek | Dryer Repair | 0 | 05-27-2010 01:35 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
