Discuss
2003 whirlpool gold electric dryer
 in
Dryer Repair
dryer takes to too long too dry---vent is clear ...question is this. COIL: 1--should it be orange (HOT) all the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » 2003 whirlpool gold electric dryer
  #1 (permalink)
Old 12-01-2012, 11:58 AM
Junior Member
drremlap is on a distinguished road
Default 2003 whirlpool gold electric dryer
Brand: Whirlpool   Age: 5 - 10 years
COIL:
1--should it be orange (HOT) all the way - the entire coil (it is not )
2--during drying time, should the coil be going off (not orange) and on (orange) every minute or two (it does)
Ads By Google
  #2 (permalink)
Old 12-03-2012, 01:53 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Normally yes it should, other than a little bit at each end.
Yes they should. This is the thermostat regulating the temperature.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to heat only part of the coil. Also depending where it breaks it can cause a low heat output.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool gold 2003 not getting cold killerponey Refrigerator & Freezer Repair 0 01-16-2012 08:47 PM
whirlpool gold electric oven in loc and wont come out papaayo Oven Repair (including Ranges and Cooktops) 0 03-19-2011 12:15 PM
Whirlpool gold electric range joansmith Oven Repair (including Ranges and Cooktops) 8 01-19-2011 12:29 PM
whirlpool gold electric dryer jazzman46 Dryer Repair 1 11-10-2009 03:46 AM
2003 Kenmore Dryer : Intermittent Heat jeffsuwanee Dryer Repair 1 07-24-2009 07:22 AM
