Discuss
Gas Dryer No Heat
 in
Dryer Repair
I have an older high efficiency Kenmore Gas dryer that has been giving me issues. I have read all over
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas Dryer No Heat
  #1 (permalink)
Old 11-29-2012, 05:14 AM
Junior Member
AkZipper is on a distinguished road
Default Gas Dryer No Heat
Brand: Kenmore   Age: More than 10 years
I have an older high efficiency Kenmore Gas dryer that has been giving me issues. I have read all over this forum to try to find the solution, but haven't had any luck.
I've replaced the solenoids, the flame sensor, and the ignitor already.
The dryer will start up fine, rotate without issues, and the ignitor will glow red, however the gas does not ever ignite (I don't know if it ever even starts coming out).
At times I do "think" I hear a gurgling noise (whether this has to do with it or not) towards the end of the ignition cycle.
Is it possible I received bad solenoids? I bought them for 10 bucks off of amazon. Do I need to check them? Any other thoughts of what could be wrong? Thanks so much for the help!
Ads By Google
  #2 (permalink)
Old 11-29-2012, 02:24 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Check the coils continuity and see if you didn't forget to put back on the double coil shaft the metal insert.
If everything looks OK - you need a new gas valve.
Provide the model number for the correct part number.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 12-03-2012, 05:57 PM
Junior Member
Default
The model is 110.94832201 . I'll check the continuity tomorrow. Thanks a lot for the help!!
  #4 (permalink)
Old 12-04-2012, 02:05 PM
Expert
Default
Hi.
Here is the gas valve assembly for your dryer
Part number: 280119
Part number: 280119
Post the results.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 02:23 PM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 09:33 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
