Discuss
Dryer runs and gets hot but doesn not dry
 in
Dryer Repair
This is a less than 2 year old gas dryer on the 3rd of 4 floors in a condo complex.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer runs and gets hot but doesn not dry
  #1 (permalink)
Old 11-25-2012, 01:15 PM
Junior Member
spidervebb is on a distinguished road
Default Dryer runs and gets hot but doesn not dry
Brand: GE   Age: 1 - 5 years
This is a less than 2 year old gas dryer on the 3rd of 4 floors in a condo complex. Had Sears out and he said the dryer was OK so it must be a vent issue and recommended using an indoor vent kit. I was fortunate to discover that that would have been very dangerous on a gas dryer. So we had professional vent cleaning and it is no better. Husband says the competence of the first guy is seriously doubtful and he doesn't understand why the cleaner didn't test the back pressure to see if that was really the problem. I don't know what to try next.
Ads By Google
  #2 (permalink)
Old 11-25-2012, 02:27 PM
Junior Member
JCnBOYS is on a distinguished road
Default
Check the thermal switch at the intake. It's right above the flame.
It's quite possible that it's cutting out the flame prior to it getting hot enough to dry.
That's what happened to mine.
My problem was that the flame would come on for about 7 seconds then go out.
Then after 2 minutes it would come on again for 7 seconds. Repeat, repeat etc.
It took forever to dry. After I replaced the thermal switch, it's all better.
__________________
If I can't fix it. I'll make sure nobody else can.
  #3 (permalink)
Old 11-26-2012, 11:40 AM
Junior Member
Default
I just tried timing the burner and after 11 cycles, I got an average on time of 13 and off of 59 seconds I am drying a load on Easy Care/Medium. Maybe that's not the best cycle for a good test, but I know my other dryer would do this load in about 30 minutes, not an hour plus! Does this sound like the thermal switch/fuse to you? Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Light Doesn’t Work - Everything Else Does aguyfromhere Refrigerator & Freezer Repair 4 10-02-2012 04:11 PM
Microware doesn;t heat John1521 Microwave Repair 0 05-13-2011 09:30 AM
Water dispenser doesn’t. LastRanger Refrigerator & Freezer Repair 0 04-11-2010 01:39 PM
Oven doesn,t heat up. BamaJud Oven Repair (including Ranges and Cooktops) 2 11-30-2009 09:18 AM
Dryer Doesn DALE R Dryer Repair 3 10-26-2009 05:53 PM
