Discuss
Need Source Special Spade Terminal
 in
Dryer Repair
In my Frigidaire stacker Washer / Electric Dryer, There is, in the back of the dryer cabinet, a Thermal Limiter
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Need Source Special Spade Terminal
  #1 (permalink)
Old 11-23-2012, 02:39 PM
Junior Member
TommyK is on a distinguished road
Default Need Source Special Spade Terminal
Model Number: 1fez831as1   Brand: Frigidaire   Age: 5 - 10 years
In my Frigidaire stacker Washer / Electric Dryer, There is, in the back of the dryer cabinet, a Thermal Limiter and A Thermal Controller. In addition to the wiring harnesses that plug into these thermostats is a wire that jumpers between the two. The wire is no longer than 6". This short wire shows up neither in the parts manual nor the drawings.
A few years ago, when I had the drum out for another repair, I noticed that this wire's insulation was burned to a crisp. I obtained some high temp stranded wire but could not find replacement terminals. These connectors look like the standard automotive spade connectors, in this case the female side. The male terminals on the thermostats are about 1/4" wide, while the automotive ones I have are about 3/16". I was unable to find a source of these special terminals. I tried to open up the smaller automotive terminals to fit the thermostats, but was unhappy with the result. Out of desperation I pried the old terminals off the old jumper wire, then installed them on the new wire.
This has been working or several years, but I've never been 'happy' with this repair. I am going to be taking the drum out to inspect and grease the bearing. I would like to replace this jumper wire with a new one with new terminals, or get new terminals to replace while I'm in there.
A number of years ago I contacted an internet appliance supplier who, after some investigation on their part, came up with a part number for this little wire assembly which was supposed to work. I never got around to ordering it. Since then we've changed computers and the file I saved the email to has vanished.
Can anyone help me find this terminal or this short jumper wire?
Related Models
Whirlpool 1LE4900XKW0 Residential Dryer
Whirlpool 1LE4930XKW0 Residential Dryer
Whirlpool 1LE5700XKW0 Residential Dryer
Whirlpool 1LE5800XKW0 DRYER
Whirlpool 1LE5920XKW0 Residential Dryer
Whirlpool 1LE7800XKW0 Residential Dryer
Whirlpool 1LG5701XKW0 Residential Dryer
Whirlpool 1LG5921XKW0 Residential Dryer
Whirlpool 1LG9801XKW1 Residential Dryer
Whirlpool 1SF014BEW0 Range (gas)*
Whirlpool 1SF014BEW1 Range (gas)*
Whirlpool 1SF014BEW2 Range (gas)*
Whirlpool 1SF034PEW0 Range (gas)*
Whirlpool 1SF034PEW1 Range (gas)*
Whirlpool 1SF034PEW2 Range (gas)*
Whirlpool 1VET27DKGW1 TOP-MOUNT REFRIGERATOR
Whirlpool 1VET27DKXGW0 REFRIGERATOR
Whirlpool 2-A Y REFRIGERATORS
Amana 20 FREEZER- VERTICAL
Amana 200.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 200.001 MWAVE - FAMILY SIZE (60 HZ)
Hoover 2000
Hoover 2001
Amana 2008.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2008.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2008.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2008.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2008.100 COMMERCIAL MICROWAVES
Amana 2008.101 COMMERCIAL MICROWAVES
Amana 2008.102 COMMERCIAL MICROWAVES
Amana 2008.112 COMMERCIAL MICROWAVES
Amana 2009.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2009.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2009.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2009.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 200A-30 ROOM AIR CONDITIONER
Amana 200A-30H ROOM AIR CONDITIONER
Amana 200A-3HN ROOM AIR CONDITIONER
Amana 200A-3M ROOM AIR CONDITIONER
Amana 200A-3N ROOM AIR CONDITIONER
Amana 200A-3P ROOM AIR CONDITIONER
Amana 200A-3PH ROOM AIR CONDITIONER
Amana 200A-3R ROOM AIR CONDITIONER
Amana 200A-3RH ROOM AIR CONDITIONER
Amana 200C-3P ROOM AIR CONDITIONER
Amana 200C-3PH ROOM AIR CONDITIONER
Amana 200C-3R ROOM AIR CONDITIONER
Amana 200C-3RH ROOM AIR CONDITIONER
Amana 200C-8P ROOM AIR CONDITIONER
Amana 200C-8RH ROOM AIR CONDITIONER
Amana 201.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 201.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 201.700 MWAVE - FAMILY SIZE (60 HZ)
Hoover 2010
Hoover 2011
Jenn-Air 20135 RANGE- S/C D/I DDRAFT ELE
Hoover 2017
Amana 2018.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2018.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2018.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2018.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2022.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2022.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2022.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2022.004 MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air 20236 RANGE- S/C S/I DDRAFT ELE
Jenn-Air 20237 RANGE- S/C S/I DDRAFT ELE
Jenn-Air 20239 RANGE- S/C S/I DDRAFT ELE
Roper 2025B0A Ranges, Electric*
Roper 2035B0A Ranges, Electric*
Roper 2035B1A Ranges, Electric*
Amana 2036.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2036.005 MWAVE - FAMILY SIZE (60 HZ)
Amana 2036.104 COMMERCIAL MICROWAVES
Amana 2036.105 COMMERCIAL MICROWAVES
Amana 2039.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2039.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2039.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2039.004 MWAVE - FAMILY SIZE (60 HZ)
Hoover 2040
Roper 2045B0A Ranges, Electric*
Roper 2045B1A Ranges, Electric*
Hoover 2048
Amana 2052.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2052.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2052.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2052.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2054.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2054.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2054.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2054.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 2055B0A Ranges, Electric*
Roper 2055B1A Ranges, Electric*
Roper 2055B2A Ranges, Electric*
Roper 2065B0A Ranges, Electric*
Roper 2065B1A Ranges, Electric*
Roper 2065B2A Ranges, Electric*
Amana 2070.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2070.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2070.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2070.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2071.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 2075B0A Ranges, Electric*
Roper 2075B1A Ranges, Electric*
Roper 2075B2A Ranges, Electric*
Amana 2085.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2085.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2085.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2085.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2089.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2090.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2090.001 MWAVE - FAMILY SIZE (60 HZ)
  #2 (permalink)
Old 11-24-2012, 04:55 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
The following may be what you need but I am nor sure.
It would be best to talk to the parts people.
Part number: AP4290706
I found it by going to the main AppliancePartsPros site.
Then scrolling down the Appliance Type to Dryer and opening that section
Then scrolling down to Wire, Harness, P and opening that section
The above seemed to match your description the best.
__________________
  #3 (permalink)
Old 11-25-2012, 07:39 PM
Junior Member
Default
That appears to be the critter. IF it fits the 'oversized' lug. Parts Guys?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Special Tool soft68top Dishwasher Repair 1 02-22-2011 06:40 AM
Oven Wire to Element - Conductor exposed by spade plug rickb68 Oven Repair (including Ranges and Cooktops) 2 08-15-2010 09:38 AM
electric wire spade connectors memlasv Dryer Repair 1 04-17-2010 04:49 AM
Right terminal on terminal block blown st3 Oven Repair (including Ranges and Cooktops) 1 03-19-2010 01:26 PM
