| » dryer won't stop running |
Model Number: ler5636eq3 Brand: Whirlpool Age: More than 10 years
my whirlpool dryer won't stop running I all ready replaced a timer switch and it still does the same thing
please reply soon Ads By Google Related Models |
__________________
I don't think so but I don't have a wiring diagram for your model, but you should replace it first before you do anything else.
Part number: AP3094277
__________________
Here is a wiring diagram for an EQ2, it is probably the same as an EQ3.
http://www.servicematters.com/docs/w...%203406688.pdf The resistor can cause your problem in Auto Dry modes. Note that in timed dry modes it should advance and shut off. In Timed Dry you get power (120 volts) directly from the line. In auto mode you get power (240 volts) when the heater shuts off (Cycles) and the resistor reduces this to 120 volts so the timer motor does not burn out.
__________________
| Display Modes | |
| Dryer stop running | superglide31 | Dryer Repair | 11 | 03-12-2009 08:11 AM |
| My dryer quite heating and won't stop running ?? | harley.davidson.fatboy | Dryer Repair | 5 | 12-19-2008 12:32 PM |
| dryer won't stop running! | raycharn | Dryer Repair | 2 | 11-25-2008 06:37 AM |
| Dryer won't stop running | manderson | Dryer Repair | 0 | 08-04-2008 06:46 AM |
| Dryer won't heat up and doesn't stop running | vbandpb | Dryer Repair | 3 | 01-28-2008 07:54 PM |
