Discuss
dryer whont heat
 in
Dryer Repair
the other one i put up was my washer thats ok this is my dryer wont heat clothing it runs
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer whont heat
  #1 (permalink)
Old 09-26-2009, 01:22 PM
Junior Member
fernando jr is on a distinguished road
Unhappy dryer whont heat
Model Number: ler5636pq   Brand: Whirlpool   Age: 1 - 5 years
the other one i put up was my washer thats ok this is my dryer wont heat clothing it runs good but just whont heat nead help on what part to change on it if you can help me that be cool ty
Ads By Google
Related Models
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
Whirlpool LER6620PQ0 29"electric Dryer
Whirlpool LER6620PQ1 29"electric Dryer
Whirlpool LER6620PT0 29"electric Dryer
Whirlpool LER6620PT1 29"electric Dryer
Whirlpool LER6621PQ0 29" Electric Dryer
Whirlpool LER6634BN0
Whirlpool LER6634BN1
Whirlpool LER6634BN2
Whirlpool LER6634BQ0
Whirlpool LER6634BQ1
Whirlpool LER6634BQ2
Whirlpool LER6634BW0
Whirlpool LER6634BW1
Whirlpool LER6634BW2
Whirlpool LER6634DQ0
Whirlpool LER6634DQ1
Whirlpool LER6634DW0
Whirlpool LER6634DW1
Whirlpool LER6634DZ0
Whirlpool LER6634DZ1
Whirlpool LER6636PW0 29" Electric Dryer
Whirlpool LER6636PW1 29" Electric Dryer
Whirlpool LER6638DQ0
Whirlpool LER6638DQ1
Whirlpool LER6638DW0
Whirlpool LER6638DW1
Whirlpool LER6638DZ0
Whirlpool LER6638DZ1
Whirlpool LER6644DQ0
Whirlpool LER6644DQ1
Whirlpool LER6644DZ0
Whirlpool LER6644DZ1
Whirlpool LER6646BN0
Whirlpool LER6646BN1
Whirlpool LER6646BN2
Whirlpool LER6646BW0
Whirlpool LER6646BW1
Whirlpool LER6646BW2
Whirlpool LER6646DN1
Whirlpool LER6646DW1
Whirlpool LER6646PW0 29" Electric Dryer
Whirlpool LER6646PW1 29" Electric Dryer
Whirlpool LER6848AN0
Whirlpool LER6848AN1
Whirlpool LER6848AN2
Whirlpool LER6848AQ2
Whirlpool LER6848AW0
Whirlpool LER6848AW1
Whirlpool LER6848AW2
Whirlpool LER6848AZ2
Whirlpool LER7620KQ0
Whirlpool LER7620KQ1
Whirlpool LER7620KT0
Whirlpool LER7620KT1
Whirlpool LER7620LG0
Whirlpool LER7620LG1 29"electric Dryer
Whirlpool LER7620LQ0
Whirlpool LER7620LW0
Whirlpool LER7620LW1 29"electric Dryer
Whirlpool LER7646AN0
Whirlpool LER7646AN1
Whirlpool LER7646AN2
Whirlpool LER7646AQ0
Whirlpool LER7646AQ1
Whirlpool LER7646AQ2
Whirlpool LER7646AW0
Whirlpool LER7646AW1
Whirlpool LER7646AW2
Whirlpool LER7646AZ0
Whirlpool LER7646AZ1
Whirlpool LER7646AZ2
Whirlpool LER7646DQ0
Whirlpool LER7646DQ1
  #2 (permalink)
Old 09-27-2009, 04:33 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Your Model Number was not complete so the following info is for a PQ0
Replacement parts for WHIRLPOOL LER5636PQ0 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/w...%208528187.pdf
Could be a number of things at the top of the list are.
1. Power, turn the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heater requires the full 240 volts. Better yet check/measure the voltage with a meter.
2. Heater could be burned out often you can see the broken element. Also can be checked with a meter.
3. Heater fuse is blown. This is the one on the heater itself. Again can be checked with a meter.
Here is agood site with basic dryer repair info.
http://www.applianceaid.com/dryers.html
Always unplug the unit when working on it. 240 volts is lethal.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 03:50 PM
