Discuss
Dryer wont start
 in
Dryer Repair
HI I have a kenmore gas dryer that does not work anymore. During sandy I got an electric surge into
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer wont start
  #1 (permalink)
Old 11-19-2012, 12:57 PM
Junior Member
kevgle4587 is on a distinguished road
Default Dryer wont start
Model Number: 41798042701   Brand: Kenmore   Age: 1 - 5 years
HI I have a kenmore gas dryer that does not work anymore. During sandy I got an electric surge into my house and now my dryer does not work. When i open the door the light inside the dryer turns on but nothing on the front panel works at all. What does it sound like it might be?
Ads By Google
Related Models
Kenmore 41798042701 DRYER
Kenmore 41798052700 GAS DRYER
Kenmore 41798052701 GAS DRYER
Kenmore 41798056700 DRYER
Kenmore 41798056701 DRYER
Kenmore 41798076700 DRYER
Kenmore 41798076701 DRYER
Kenmore 41798702890 LAUNDRY CENTER
Kenmore 41798702891 LAUNDRY CENTER
Kenmore 41798702892 LAUNDRY CENTER
Kenmore 41798802890 LAUNDRY CENTER
Kenmore 41798802891 LAUNDRY CENTER
Kenmore 41798804890 LAUNDRY CENTER
Kenmore 41798804891 LAUNDRY CENTER
Kenmore 41798862890 LAUNDRY CENTER
Kenmore 41798862891 LAUNDRY CENTER
Kenmore 41798864890 LAUNDRY CENTER
Kenmore 41798864891 LAUNDRY CENTER
Kenmore 41798988100 ELECTRIC DRYER
Kenmore 41798988110 ELECTRIC DRYER
Kenmore 41798988120 ELECTRIC DRYER
Kenmore 41798988130 ELECTRIC DRYER
Kenmore 41798988140 ELECTRIC DRYER
Kenmore 41798988150 ELECTRIC DRYER
Kenmore 41798988800 ELECTRIC DRYER
Kenmore 41798988810 ELECTRIC DRYER
Kenmore 41798988820 ELECTRIC DRYER
Kenmore 41798988830 ELECTRIC DRYER
Kenmore 41798988840 ELECTRIC DRYER
Kenmore 41798988850 ELECTRIC DRYER
Kenmore 41798989100 GAS DRYER
Kenmore 41798989110 GAS DRYER
Kenmore 41798989120 GAS DRYER
Kenmore 41798989130 GAS DRYER
Kenmore 41798989140 GAS DRYER
Kenmore 41798989150 GAS DRYER
Kenmore 41798989800 GAS DRYER
Kenmore 41798989810 GAS DRYER
Kenmore 41798989820 GAS DRYER
Kenmore 41798989830 GAS DRYER
Kenmore 41798989840 GAS DRYER
Kenmore 41798989850 GAS DRYER
Kenmore 41799160100 LAUNDRY CENTER
Kenmore 41799160110 LAUNDRY CENTER
Kenmore 41799160120 LAUNDRY CENTER
Kenmore 41799160130 LAUNDRY CENTER
Kenmore 41799160800 LAUNDRY CENTER
Kenmore 41799160810 LAUNDRY CENTER
Kenmore 41799160820 LAUNDRY CENTER
Kenmore 41799160830 LAUNDRY CENTER
Kenmore 41799165100 LAUNDRY CENTER
Kenmore 41799165110 LAUNDRY CENTER
Kenmore 41799165120 LAUNDRY CENTER
Kenmore 41799165130 LAUNDRY CENTER
Kenmore 41799165800 LAUNDRY CENTER
Kenmore 41799165810 LAUNDRY CENTER
Kenmore 41799165820 LAUNDRY CENTER
Kenmore 41799165830 LAUNDRY CENTER
Kenmore 41799170100 LAUNDRY CENTER
Kenmore 41799170110 LAUNDRY CENTER
Kenmore 41799170120 LAUNDRY CENTER
Kenmore 41799170800 LAUNDRY CENTER
Kenmore 41799170810 LAUNDRY CENTER
Kenmore 41799170820 LAUNDRY CENTER
Kenmore 41799175100 LAUNDRY CENTER
Kenmore 41799175110 LAUNDRY CENTER
Kenmore 41799175120 LAUNDRY CENTER
Kenmore 41799175800 LAUNDRY CENTER
Kenmore 41799175810 LAUNDRY CENTER
Kenmore 41799175820 LAUNDRY CENTER
Kenmore 41799180100 GAS AND ELECTRIC LAUNDRY CENTER
Kenmore 41799180110 LAUNDRY CENTER
Kenmore 41799180120 LAUNDRY CENTER
Kenmore 41799180800 GAS AND ELECTRIC LAUNDRY CENTER
Kenmore 41799180810 LAUNDRY CENTER
Kenmore 41799180820 LAUNDRY CENTER
Kenmore 41799185100 LAUNDRY CENTER
Kenmore 41799185110 27" LAUNDRY CENTER
Kenmore 41799185120 LAUNDRY CENTER
Kenmore 41799185800 LAUNDRY CENTER
Kenmore 41799185810 27" LAUNDRY CENTER
Kenmore 41799185820 LAUNDRY CENTER
Kenmore 41799190100 LAUNDRY CENTER
Kenmore 41799190110 27" LAUNDRY CENTER
Kenmore 41799190120 LAUNDRY CENTER
Kenmore 41799190800 LAUNDRY CENTER
Kenmore 41799190810 27" LAUNDRY CENTER
Kenmore 41799190820 LAUNDRY CENTER
Kenmore 41799195100 LAUNDRY CENTER
Kenmore 41799195110 LAUNDRY CENTER
Kenmore 41799195120 LAUNDRY CENTER
Kenmore 41799195800 LAUNDRY CENTER
Kenmore 41799195810 LAUNDRY CENTER
Kenmore 41799195820 LAUNDRY CENTER
Kenmore 41799370100 LAUNDRY CENTER
Kenmore 41799370110 LAUNDRY CENTER
Kenmore 41799370120 LAUNDRY CENTER
Kenmore 41799370130 LAUNDRY CENTER
Kenmore 41799370800 LAUNDRY CENTER
Kenmore 41799370810 LAUNDRY CENTER
Kenmore 41799370820 LAUNDRY CENTER
Kenmore 41799370830 LAUNDRY CENTER
Kenmore 41799375100 LAUNDRY CENTER
Kenmore 41799375110 27" LAUNDRY CENTER
Kenmore 41799375120 LAUNDRY CENTER
Kenmore 41799375800 LAUNDRY CENTER
Kenmore 41799375810 27" LAUNDRY CENTER
Kenmore 41799375820 LAUNDRY CENTER
Kenmore 41799390100 LAUNDRY CENTER
Kenmore 41799390110 LAUNDRY CENTER
Kenmore 41799390120 27" LAUNDRY CENTER
Kenmore 41799390130 LAUNDRY CENTER
Kenmore 41799390800 LAUNDRY CENTER
Kenmore 41799390810 LAUNDRY CENTER
Kenmore 41799390820 27" LAUNDRY CENTER
Kenmore 41799390830 LAUNDRY CENTER
Kenmore 41799395100 LAUNDRY CENTER
Kenmore 41799395110 LAUNDRY CENTER
Kenmore 41799395120 LAUNDRY CENTER
Kenmore 41799395800 LAUNDRY CENTER
  #2 (permalink)
Old 11-21-2012, 09:56 PM
Expert
APP Volunteer
rickgburton is on a distinguished road
Default
Do any of the LED's on the control panel turn on? If not check all the wire connections and check for supply voltage at the control board. If the indicator lights do turn on check the door switch with an ohmmeter for continuity when the switch is pressed in.
__________________
Ricks Appliance Repair
  #3 (permalink)
Old 11-21-2012, 10:12 PM
Junior Member
Default
Yes none of the led come on. Am I wrong to assume there is power to the machine due to the fact the light bulb inside turns on when I open the door?
  #4 (permalink)
Old 11-22-2012, 12:35 AM
Expert
APP Volunteer
Default
Quote:
Well, there's power to parts of the machine, so you need to figure out where you're losing it. Let's take the door switch for instance. There's three wires on the door switch. One wire is COMMON and is on the common terminal on the switch. The wire for the light is on the terminal marked NC or Normally Closed. That means power for the light can go from the COM to to the NC and the light is on. The wire for the start switch is on the terminal marked NO or Normally Open so power can't go to the start switch with the door open. Now we close the door. The part of the switch that was closed for the light, is now open, no light. and the part of the switch that was open, is now closed, power to start switch. Just because part of the switch is good (LIGHT) doesn't automatically mean the other part of the switch (START) is also good. Now do you get it?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer wont start higdon1 Dryer Repair 0 05-04-2011 08:44 AM
Dryer wont start, sensing light just flashes when i hold down the start button! crsteilen Dryer Repair 0 03-28-2011 03:21 PM
dryer wont start shawnls Dryer Repair 0 03-28-2011 01:51 PM
Dryer wont start, sensing light just flashes when i hold down the start button! crsteilen Dishwasher Repair 0 03-28-2011 12:13 PM
dryer wont start strat123@aol.com Dryer Repair 0 10-28-2009 01:01 AM
