| » has power and good fuse but will not start |
Model Number: ler4634eq0 Brand: Whirlpool Age: Less than 1 year
my dryer has power and a good fuse but will not start
Parts for Whirlpool LER4634EQ0 Dryer - AppliancePartsPros.com See the attachment for the wiring diagram Could be a number of things bad start switch, bad door switch, blown motor, bad timer contacts or a bad wire/connection. All of theses can be checked using a meter and resistance. How do you know it has power? Did you measure it at the terminal strip with a meter. Neutral to L1 (120 volts) is what runs the motor. If you put the timer at mid-cycle timed dry, door closed the timer should advance even with the motor off.
__________________
| Display Modes | |
| has power and good fuse but will not start | jake4458 | Dryer Repair | 1 | 11-20-2012 04:24 AM |
| No Heat, No Timer, New Cycling Thermostat, New Fuse, Good Continuity | Alakshak | Dryer Repair | 0 | 08-31-2012 06:56 PM |
| Whirpool Electric Oven Wont Heat - Thermal Fuse Good | Hunt9876 | Oven Repair (including Ranges and Cooktops) | 0 | 08-23-2012 07:32 PM |
| Whirlpool gas dryer won't start. Fuse is good | jeffmaaske | Dryer Repair | 8 | 08-23-2012 09:38 AM |
| Maytag Microwave died, fuse is good | TimTN | Microwave Repair | 1 | 09-03-2010 05:27 AM |
