Discuss
Burning out Thermal Cut Out
 in
Dryer Repair
I ran this dryer (Maytag, Model; MDE9700AYW) for several years and my grandaughter has it now. She just moved into
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Burning out Thermal Cut Out
  #1 (permalink)
Old 11-18-2012, 08:00 PM
Junior Member
Foghorn is on a distinguished road
Default Burning out Thermal Cut Out
Model Number: MDE9700AYW   Brand: Maytag   Age: 5 - 10 years
I ran this dryer (Maytag, Model; MDE9700AYW) for several years and my grandaughter has it now. She just moved into a new place and it quit heating. I checked it out and the Thermal Cut Out was open so I replaced it. She dried two loads and it happened again. I assumed it was a venting problem so I cleaned everything, replaced the part and had her try it venting straight out. Two loads later it happened again. While cleaning and checking everything I noticed that the plate between the heating coils is cracked clear through. Could that be the cause? It is the only anomoly I can find. I have also tried to find a replacement heating element on your site but cannot locate a compatible unit. Any help you can provide to solve this problem would be greatly appreciated.
Ads By Google
Related Models
Maytag MDE9700AYW Dryer - Ele
Maytag MDE9700AZM Dryer - Ele
Maytag MDE9700AZW Dryer - Ele
Maytag MDE9706AYA Dryer - Ele
Maytag MDE9706AYW Dryer - Ele
Maytag MDE9706AZW Dryer - Ele
Maytag MDE9766AYW Dryer - Ele
Maytag MDE9766AZW Dryer - Ele
Maytag MDE9800AYQ Dryer - Ele
Maytag MDE9800AYW Dryer - Ele
Maytag MDE9800AZQ Dryer - Ele
Maytag MDE9800AZW Dryer - Ele
Maytag MDE9806AYA Dryer - Ele
Maytag MDE9806AYW Dryer - Ele
Maytag MDE9806AZW Dryer - Ele
Maytag MDE9876AYW Dryer - Ele
Maytag MDET236AYW Dryer - Ele
Maytag MDET236AZW Dryer - Ele
Maytag MDET336AYW Dryer - Ele
Maytag MDET336AZW Dryer - Ele
Maytag MDET446AYW Dryer - Ele
Maytag MDET446AZW Dryer - Ele
Maytag MDG100PN1 Dryer - Gas
Maytag MDG100PN1L Dryer - Gas
Maytag MDG100PN1W Dryer - Gas
Maytag MDG10CSAAL Dryer - Gas
Maytag MDG10CSAAW Dryer - Gas
Maytag MDG10CSABL Dryer - Gas
Maytag MDG10CSABW Dryer - Gas
Maytag MDG10CSAGL Dryer - Gas
Maytag MDG10CSAGW Dryer - Gas
Maytag MDG10CSAKL Dryer - Gas
Maytag MDG10CSEGL Dryer - Gas
Maytag MDG10CSEGW Dryer - Gas
Maytag MDG10DAAAL Dryer - Gas
Maytag MDG10DAAAW Dryer - Gas
Maytag MDG10DAABL Dryer - Gas
Maytag MDG10DAABW Dryer - Gas
Maytag MDG10MNAAW Dryer - Gas
International MDG10MNAGW Dryer - Gas
Maytag MDG10MNEGW Dryer - Gas
Maytag MDG10PDAAL Dryer - Gas
Maytag MDG10PDAAW Dryer - Gas
Maytag MDG10PDABL Dryer - Gas
Maytag MDG10PDABW Dryer - Gas
Maytag MDG10PDEGL Dryer - Gas
Maytag MDG10PDEGW Dryer - Gas
Maytag MDG10PRAAW Dryer - Gas
Maytag MDG10PSABW Dryer - Gas
Maytag MDG10PSAGL Dryer - Ele
Maytag MDG10PSAGW Dryer - Ele
Frigidaire MDG116RBW0 Frg(v1) / 27 " Gas Dryer
Frigidaire MDG116RBW1 Frg(v0) / Gas Dryer
Maytag MDG11CSAAL Dryer - Gas
Maytag MDG11CSAAW Dryer - Gas
Maytag MDG11CSABW Dryer - Gas
Maytag MDG11CSAGL Dryer - Gas
Maytag MDG11CSAGW Dryer - Gas
Maytag MDG11CSEGL Dryer - Gas
Maytag MDG11CSEGW Dryer - Gas
Maytag MDG11MNAAW Dryer - Gas
Maytag MDG11MNAGW Dryer - Gas
Maytag MDG11MNEGW Dryer - Gas
Maytag MDG11PDAAL Dryer - Gas
Maytag MDG11PDAAW Dryer - Gas
Maytag MDG11PDABL Dryer - Gas
Maytag MDG11PDABW Dryer - Gas
Maytag MDG11PDAGL Dryer - Gas
Maytag MDG11PDAGW Dryer - Gas
Maytag MDG11PDEGL Dryer - Gas
Maytag MDG11PDEGW Dryer - Gas
Maytag MDG120P1HW Dryer - Gas
Maytag MDG120PHVW Dryer - Gas
Maytag MDG12CSAAL Dryer - Gas
Maytag MDG12CSAAW Dryer - Gas
Maytag MDG12CSABL Dryer - Gas
Maytag MDG12CSABW Dryer - Gas
Maytag MDG12CSAGW Dryer - Gas
Maytag MDG12CSEGW Dryer - Gas
Maytag MDG12MNAAW Dryer - Gas
Maytag MDG12MNAGW Dryer - Gas
Maytag MDG12MNEGW Dryer - Gas
Maytag MDG12PDAAL Dryer - Gas
Maytag MDG12PDAAW Dryer - Gas
Maytag MDG12PDABL Dryer - Gas
Maytag MDG12PDABW Dryer - Gas
Maytag MDG12PDBAL Dryer - Gas
Maytag MDG12PDBAW Dryer - Gas
Maytag MDG12PDBBL Dryer - Gas
Maytag MDG12PDBBW Dryer - Gas
Maytag MDG12PRAAW Dryer - Gas
Maytag MDG12PRBAW Dryer - Gas
Maytag MDG12PRBBW Dryer - Gas
Maytag MDG12PSABW Dryer - Gas
Maytag MDG12PSAGW Dryer - Gas
Maytag MDG12PSBAW Dryer - Gas
Maytag MDG12PSBBW Dryer - Gas
Maytag MDG13CSAAL Dryer - Gas
Maytag MDG13CSAAW Dryer - Gas
Maytag MDG13CSABW Dryer - Gas
Maytag MDG13CSAGW Dryer - Gas
Maytag MDG13CSAKL Dryer - Gas
Maytag MDG13CSEGW Dryer - Gas
Maytag MDG13MNAAW Dryer - Gas
Maytag MDG13PDAAL Dryer - Gas
Maytag MDG13PDAAW Dryer - Gas
Maytag MDG13PDABL Dryer - Gas
Maytag MDG13PDABW Dryer - Gas
Maytag MDG13PDAGW Dryer - Gas
Maytag MDG13PDBAL Dryer - Gas
Maytag MDG13PDBAW Dryer - Gas
Maytag MDG13PDBBL Dryer - Gas
Maytag MDG13PDBBW Dryer - Gas
Maytag MDG13PDEGW Dryer - Gas
Maytag MDG13PRAAW Dryer - Gas
Maytag MDG13PRBAW Dryer - Gas
Maytag MDG14PDAAL Dryer - Gas
Maytag MDG14PDAAQ Dryer - Gas
Maytag MDG14PDAAW Dryer - Gas
Maytag MDG14PDAEW Dryer - Gas
  #2 (permalink)
Old 11-19-2012, 01:28 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Parts for Maytag MDE9700AYW Dryer - AppliancePartsPros.com
Yes.
Below is some info on blown thermal cut-offs.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
Heater should be Item 8 in Section 01 of the parts.
But double check with the parts people.
__________________
  #3 (permalink)
Old 11-21-2012, 12:26 PM
Junior Member
Default
Quote:
Originally Posted by denman View Post
Yes.
Thanks for the information, however it is not solving the problem. I checked the heating element and got 10-12 ohms just like you said and open readings to the case. The coil appears to be in good shape and all insulators are in good condition. I rechecked the plate that goes between the coils. Only a small necked down section is cracked but the plate still has continuity and prevents any contact between the coil or case. The end of the plate farthest from the connectors is discolored from the rest of the plate, kind of grayish. Any other checks I can make to try to chase this problem down?
  #4 (permalink)
Old 11-21-2012, 12:51 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Sorry for cutting in. It's possible that the heat relay in the control board is stuck closed. Check if the heater cycling on and off.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #5 (permalink)
Old 11-21-2012, 01:18 PM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Sorry for cutting in. It's possible that the heat relay in the control board is stock closed. Check if the heater cycling on and off.
Simon.
No need to apologize, I'll take all the help I can get. How do I go about checking that?
  #6 (permalink)
Old 11-21-2012, 01:29 PM
Expert
Default
Visually or placing the thermostat at the dryer's vent opening.
Also by using an amp probe.
Simon.
__________________
  #7 (permalink)
Old 11-21-2012, 01:55 PM
Junior Member
Default
Simon.
Sorry, I'm not following you on this one. Do you mean a thermometer at the vent opening? If so, what kind of fluctiations should I get? Where do I check with an amp probe?
  #8 (permalink)
Old 11-21-2012, 05:03 PM
Expert
Default
Sorry, my fault. Thermometer is what I meant.The heater cycles between about 155F and 125F.
You may clamp on the amp meter over the L2 at the connector block or the easiest would be just look at the dryer's back in the dark room. You should be able to see the element glowing.
Simon.
__________________
  #9 (permalink)
Old 11-22-2012, 12:27 AM
Senior Expert
APP Volunteer
Default
No need for a sorry with me either.
The more info and suggestions we can give a poster the more likely that we can help get a unit up and running.
If you run the unit on a high and then a low heat setting you should be able to feel the difference in heat output, though Simon's method is more exact.
Also the heating coil should cycle on low heat.
You may also want to check the thermistor, see the tech sheet.
Be sure to unplug at keast one side of it. This ensures that you do not read an alternate/parallel circuit path.
__________________
  #10 (permalink)
Old 11-24-2012, 12:35 PM
Junior Member
Default
Ok guys, I went to check the cycling of the heating element but before I did I checked the the Thermistor--it is open. I have one on order and will let you know what happens when I get it replaced.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermal fuses keep burning out perch43 Dryer Repair 5 02-06-2012 04:45 PM
Frequent Burning of Thermal Fuse JBorcillo Dryer Repair 0 02-01-2012 05:34 PM
keeps burning out thermal fuse comglaze Dryer Repair 1 01-11-2012 03:44 AM
Kenmore dryer -no heat and burning thermal cutt off msteinson Dryer Repair 0 09-29-2011 07:16 PM
Dryer's Thermal cutt off keeps burning nfusmani Dryer Repair 7 09-29-2010 04:56 PM
