Discuss
Gas Dryer - Intermittent heat, checked coils and igniter
 in
Dryer Repair
I'm experiencing intermittent heat with a slight smell of gas. I've done a bit of research and was prepared to
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas Dryer - Intermittent heat, checked coils and igniter
  #1 (permalink)
Old 11-18-2012, 07:14 PM
Junior Member
nevets is on a distinguished road
Default Gas Dryer - Intermittent heat, checked coils and igniter
Model Number: rgd4400sq   Brand: Roper   Age: 5 - 10 years
I'm experiencing intermittent heat with a slight smell of gas. I've done a bit of research and was prepared to replace either the igniter or the coils. I opened everything up and ran continuity tests with my meter. The coils worked out fine and registered as anticipated. The igniter didn't register properly at first. I decided to test again and it worked. I put it back together with original parts. It worked for a load, and now intermittent heat with slight smell of gas again. I would appreciate any suggestions. Thanks!
Ads By Google
Related Models
Roper RGD4400SQ0 29" GAS DRYER
Roper RGD4400TQ0 29" GAS DRYER
Roper RGD4400VQ0 29" GAS DRYER
Roper RGD4400VQ1 29" GAS DRYER
Roper RGD4440SQ0 29" GAS DRYER
Roper RGD4440VQ0 29" GAS DRYER
Roper RGD4440VQ1 29" GAS DRYER
Whirlpool RGE1700P2 Ranges, Electric*
Roper RGE23001 24" FREESTANDING RANGE E-Z Clean Oven Coil Cooktop
Roper RGE23081 24" FREESTANDING RANGE E-Z Clean Oven Coil Cooktop
Roper RGE23301 24" FREESTANDING RANGE E-Z Clean Oven Coil Cooktop
Whirlpool RGE3010W1 Ranges, Electric
Whirlpool RGE3010W2 Ranges, Electric
Whirlpool RGE3210W0 Ranges, Electric*
Roper RGE33001 30" ELECTRIC RANGE COIL COOKTOP Self-Clean Oven
Roper RGE33081 30" ELECTRIC RANGE COIL COOKTOP Self-Clean Oven
Roper RGE33301 30" ELECTRIC RANGE COIL COOKTOP Self-Clean Oven
Roper RGE34301 30" ELECTRIC RANGE COIL COOKTOP Self-Clean Oven
Whirlpool RGE4900W1 Ranges, Electric*
Whirlpool RGE8300H Ranges, Electric*
Whirlpool RGE8800H Ranges, Electric*
General Electric RGH558U01 Gas range
General Electric RGH646G1F0 Gas range
General Electric RGH647GEH1 Gas range
General Electric RGH647GEH2 Gas range
General Electric RGH647GEH3 Gas range
General Electric RGH647GEJ1 Gas range
General Electric RGH647GEJ2 Gas range
General Electric RGH647GEJ3 Gas range
General Electric RGH647GEJ4 Gas range
Whirlpool RGH83301 Range Hood
Whirlpool RGH83361 Range Hood
Whirlpool RGH83481 Range Hood
General Electric RGH846GEH1 Gas range
General Electric RGH846GEH2 Gas range
General Electric RGH846GEH3 Gas range
General Electric RGH846GEJ1 Hi-low range
General Electric RGH846GEJ2 Gas range
General Electric RGH846GEJ3 Gas range
General Electric RGH846GEJ4 Gas range
General Electric RGH846GEJ5 Gas range
General Electric RGH946GEH1 Gas range
General Electric RGH946GEH2 Gas range
General Electric RGH946GEH3 Gas range
General Electric RGH946GEJ1 Hi-low range
General Electric RGH946GEJ2 Gas range
General Electric RGH946GEJ3 Gas range
General Electric RGH946GEJ4 Gas range
General Electric RGH946GEJ5 Gas range
General Electric RGH946GEJ6 Gas range
General Electric RGH946GEJ7 Gas range
General Electric RGH946GEJ8 Gas range
General Electric RGJ515GEH1 Gas range
General Electric RGJ515GEH2 Gas range
General Electric RGJ515GEH3 Gas range
General Electric RGJ515GEL1 Gas range
General Electric RGJ515GEL2 Gas range
General Electric RGJ515GEL3 Gas range
General Electric RGJ515GEL4 Gas range
General Electric RGJ534GEP1 Gas range
General Electric RGJ534GEP2BG Gas range
General Electric RGJ616GEH1 Gas range
General Electric RGJ616GEH2 Gas range
General Electric RGJ616GEH3 Gas range
General Electric RGJ616GEL1 Gas range
General Electric RGJ616GEL2 Gas range
General Electric RGJ616GEL3 Gas range
General Electric RGJ616GEL4 Gas range
General Electric RGJ736GEP1 Gas range
Roper RGK2951KQ0 COMMERCIAL DRYER
Roper RGK2951KQ1 COMMERCIAL DRYER
Roper RGK2951KQ2 For Model: RGK2951KQ2 (White)
Whirlpool RGL3422AL0
Roper RGL3422AW0 Residential Dryer
Roper RGL3612BW0 GAS DRYER
Roper RGL3612BW1 GAS DRYER
Roper RGL3612BW2 GAS DRYER
Roper RGL3612BW3 GAS DRYER
Roper RGL3636AW0 Residential Dryer
Roper RGL4422AW0 Residential Dryer
Roper RGL4432AW0 Residential Dryer
Roper RGL4434AW0 Residential Dryer
Roper RGL4622BL0 GAS DRYER
Roper RGL4622BL1 GAS DRYER
Roper RGL4622BL2 GAS DRYER
Roper RGL4622BW0 GAS DRYER
Roper RGL4622BW1 GAS DRYER
Roper RGL4622BW2 GAS DRYER
Roper RGL4622DL0 GAS DRYER
Roper RGL4622DL1 GAS DRYER
Roper RGL4622DW0 GAS DRYER
Roper RGL4622DW1 GAS DRYER
Roper RGL4632BL0 DRYER
Roper RGL4632BL1 GAS DRYER
Roper RGL4632BL2 GAS DRYER
Roper RGL4632BL3 GAS DRYER
Roper RGL4632BQ0 DRYER
Roper RGL4632BQ1 GAS DRYER
Roper RGL4632BQ2 GAS DRYER
Roper RGL4632BQ3 GAS DRYER
Roper RGL4632BW0 DRYER
Roper RGL4632BW1 GAS DRYER
Roper RGL4632BW2 GAS DRYER
Roper RGL4632BW3 GAS DRYER
Roper RGL4632DL0 GAS DRYER
Roper RGL4632DL1 GAS DRYER
Roper RGL4632DW0 GAS DRYER
Roper RGL4632DW1 GAS DRYER
Roper RGL4634BL0 GAS DRYER
Roper RGL4634BL1 GAS DRYER
Roper RGL4634BL2 GAS DRYER
Roper RGL4634BL3 GAS DRYER
Roper RGL4634BW0 GAS DRYER
Roper RGL4634BW1 GAS DRYER
Roper RGL4634BW2 GAS DRYER
Roper RGL4634BW3 GAS DRYER
Roper RGL4636BL0 GAS DRYER
Roper RGL4636BL1 GAS DRYER
Roper RGL4636BL2 GAS DRYER
Roper RGL4636BL3 GAS DRYER
  #2 (permalink)
Old 11-18-2012, 07:27 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
The coils often do check fine even when they are the problem.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 11-18-2012, 07:51 PM
Junior Member
Default possible igniter? or most likely coils?
Thanks for the reply - Just to follow up - first check on continuity with the igniter didn't register, so I assumed it was bad. Checked it again later and it tested fine. Is it possible that the igniter could work intermittently? Or is it pretty safe to assume that the coils are bad, even though the continuity measurements checked out fine?
  #4 (permalink)
Old 11-19-2012, 01:10 PM
Junior Member
Default Igniter or Coils?
Just to follow up on my previous question - Is it possible for the igniter to work intermittently? or should I assume that the coils are causing the problem?
  #5 (permalink)
Old 11-20-2012, 06:35 PM
Junior Member
Default Solution - Coils
I followed the advice and changed out the coils, even though they passed the continuity test. This seems to work - the heat is much hotter and it no longer seems to be intermittent.
THANK YOU!
  #6 (permalink)
Old 11-20-2012, 06:37 PM
Senior Expert
APP Volunteer
Default
Awesome, good job!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas dryer wont heat (new coils, igniter glows) ajpa Dryer Repair 6 06-01-2012 12:28 PM
Gas dryer: new coils, new igniter...still no heat cherrie_echon Dryer Repair 0 05-10-2012 03:54 PM
Replaced Glow Igniter, Sensor and coils yet no heat in dryer Camann Dryer Repair 0 12-17-2009 08:19 AM
Igniter Glows Replaced Coils Still no Heat Friar Dryer Dryer Repair 1 12-05-2008 01:53 PM
Gas dryer still won't heat after new igniter & coils Carl Baltensperger Dryer Repair 8 09-04-2007 09:47 AM
