Discuss
Gas Dryer Only Heats Once
 in
Dryer Repair
I have a Frigidaire FGR231AS1 gas dryer that will only light after sitting until cold. The burner will light normally
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas Dryer Only Heats Once
  #1 (permalink)
Old 11-18-2012, 01:01 PM
Junior Member
jmann1 is on a distinguished road
Default Gas Dryer Only Heats Once
Model Number: FGR231AS1   Brand: Frigidaire   Age: 5 - 10 years
I have a Frigidaire FGR231AS1 gas dryer that will only light after sitting until cold. The burner will light normally only one time. After the dryer heats, it will turn off the burner, but it will not light again. I can see that the igniter is heating every minute or so after it cools a bit, but the gas doesn't seem to be coming on after it shuts off the first time. If I let the dryer sit for 40 minutes or so, the cycle repeats.
Here are some tests I have tried:
Manually heated both the temp sensor (the one on the duct, near the fan) and the over-temp sensor (near the back of the drum).
Both of these sensors audibly clicked and continuity was broken.
I did a similar test on the flame sensor.
It does not matter whether timed dry or automatic dry is selected. The symptoms exist for all settings.
Any help would be appreciated.
Ads By Google
Related Models
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
Whirlpool FGS337GW1
Whirlpool FGS337GW5
Whirlpool FGS337GW6
Whirlpool FGS337GW7
Whirlpool FGS337KN0
Whirlpool FGS337KN1
Whirlpool FGS337KQ0
Whirlpool FGS337KQ1
Whirlpool FGS337KQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS337KW0
Whirlpool FGS337KW1
Whirlpool FGS337KW2 30" Gas Freestanding Self Clean Range
Frigidaire FGS365EBA Frigidaire/gas Range
Frigidaire FGS365EBB Frigidaire/gas Range
Frigidaire FGS365EBC Frigidaire/range
Frigidaire FGS365ECA Frigidaire/gas Range
Frigidaire FGS365ECB Frigidaire/gas Range
Frigidaire FGS365ECC Frigidaire/range
Frigidaire FGS365ECD Frigidaire/range
Frigidaire FGS365ECE Frigidaire/gas Range
Frigidaire FGS365EQA Frigidaire/gas Range
Frigidaire FGS365EQB Frigidaire/gas Range
Frigidaire FGS365EQC Frigidaire/range
Frigidaire FGS365ESA Frigidaire/gas Range
Frigidaire FGS365ESB Frigidaire/gas Range
Frigidaire FGS365ESC Frigidaire/range
Frigidaire FGS366EBA Frigidaire/gas Range
Frigidaire FGS366EBB Frigidaire/gas Range
Frigidaire FGS366EBC Frigidaire/range
Frigidaire FGS366EBD Frigidaire/gas Range
Frigidaire FGS366ECA Frigidaire/gas Range
Frigidaire FGS366ECB Frigidaire/gas Range
Frigidaire FGS366ECC Frigidaire/gas Range
Frigidaire FGS366ECD Frigidaire/gas Range
Frigidaire FGS366EQA Frigidaire/gas Range
Frigidaire FGS366EQB Frigidaire/gas Range
Frigidaire FGS366EQC Frigidaire/range
Frigidaire FGS366EQD Frigidaire/gas Range
Frigidaire FGS366ESA Frigidaire/gas Range
Frigidaire FGS366ESB Frigidaire/gas Range
Frigidaire FGS366ESC Frigidaire/range
Frigidaire FGS366ESD Frigidaire/gas Range
Frigidaire FGS367DBA Frigidaire/gas Range
Frigidaire FGS367DSA Frigidaire/gas Range
Frigidaire FGS367EBA Frigidaire/gas Range
Frigidaire FGS367ECA Frigidaire/gas Range
Frigidaire FGS367ECB Frigidaire/gas Range
Frigidaire FGS367ECC Frigidaire/range
Frigidaire FGS367ESA Frigidaire/gas Range
Frigidaire FGS367FCA Frigidaire/gas Range
Frigidaire FGS367FCB Frigidaire/gas Range
Frigidaire FGS379DBA Frigidaire/gas Range
Frigidaire FGS379DCA Frigidaire/gas Range
Frigidaire FGS379DQA Frigidaire/gas Range
Frigidaire FGS379DSA Frigidaire/gas Range
Frigidaire FGS379EBA Frigidaire/gas Range
Frigidaire FGS379ECB Frigidaire/gas Range
Frigidaire FGS379ECC Frigidaire/gas Range
Frigidaire FGS379EQA Frigidaire/gas Range
Frigidaire FGS379ESA Frigidaire/gas Range
Whirlpool FGS385BL0
Whirlpool FGS385BL1
Whirlpool FGS385BL2
Whirlpool FGS385BL3
Whirlpool FGS385BL4
Whirlpool FGS385BL5
Whirlpool FGS385BQ1
Whirlpool FGS385BQ2
Whirlpool FGS385BQ3
Whirlpool FGS385BW0
Whirlpool FGS385BW1
Whirlpool FGS385BW2
Whirlpool FGS385BW3
Whirlpool FGS385BW4
Whirlpool FGS385BW5
Whirlpool FGS385VL0
Whirlpool FGS385VL1
Whirlpool FGS385VL2
Whirlpool FGS385VW0
Whirlpool FGS385VW1
Whirlpool FGS385VW2
  #2 (permalink)
Old 11-18-2012, 03:30 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
You need to replace the control coils located on the top of the gas valve Part number: 5303931775
Here are the breakdown diagrams and Burner,valve parts for Frigidaire FGR231AS1 - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 11-18-2012, 03:39 PM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Post the results.
Simon.
Thanks. I just ordered those based on posts/replies from others. I probably should have searched more thoroughly before posting.
I'll post the results once they're installed.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer heats, but doesn't dry tia_m Dryer Repair 2 06-20-2012 03:25 PM
Dryer only heats once lesmcguinn Dryer Repair 5 08-25-2011 08:23 PM
Dryer Heats then stops heating. After rest, heats then stops heating Jim WA Dryer Repair 0 07-07-2011 12:53 PM
Dryer heats some tim mdh6677 Dryer Repair 0 07-03-2009 07:02 PM
Dryer heats a little but thats all garocker Dryer Repair 3 12-01-2007 09:36 AM
