Discuss
Whirlpool Electric Dryer Not Staying Hot
 in
Dryer Repair
We own an older Whirlpool Electric dryer, LE5800XSN3, that does not stay hot. I disconnected it from the wall ventilation
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Electric Dryer Not Staying Hot
  #1 (permalink)
Old 11-17-2012, 09:04 AM
Junior Member
hermes is on a distinguished road
Default Whirlpool Electric Dryer Not Staying Hot
Model Number: LE5800XSN3   Brand: -brand-   Age: More than 10 years
I disconnected it from the wall ventilation outlet to the outside then vacuumed the vent and the back interior of the dryer.
Still not staying hot. It does not stay hot when I run it when not connected to the wall vent. I then installed a replacement heater element.
I watch the bottom element glow a nice cherry red then a mechanical sound and the element turns off and may some minutes later turn back on. It doesn't matter if the drum is full of wet clothes or just a test run. Heater Element shuts down.
What should I replace next. I think I have a voltmeter around here someplace.
Related Models
Whirlpool LE5800XSN3 ELECTRIC DRYER
Whirlpool LE5800XSW0 Residential Dryer
Whirlpool LE5800XSW1 Residential Dryer
Whirlpool LE5800XSW2 Residential Dryer
Whirlpool LE5800XSW3 Residential Dryer
Whirlpool LE5805XPW0 Residential Dryer
Whirlpool LE5810XPW0 Residential Dryer
Whirlpool LE5900XSW0 Residential Dryer
Whirlpool LE5920XKW0 Residential Dryer
Whirlpool LE5920XKW1 Residential Dryer
Whirlpool LE5920XMW0 Residential Dryer
Whirlpool LE5920XMW1 Residential Dryer
Whirlpool LE5920XMW2 Residential Dryer
Whirlpool LE5950XSW0 Residential Dryer
Frigidaire LE600AXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600AXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600AXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600AXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXD3 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600MXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600MXW3 Wwh(v1) / 27 " Laundry Center
Whirlpool LE6055XSW0 Residential Dryer
Whirlpool LE6055XSW1 Residential Dryer
Whirlpool LE6090XSW0 Residential Dryer
Whirlpool LE6090XSW1 Residential Dryer
Whirlpool LE6090XTW0 Residential Dryer
Whirlpool LE6098XSW0 Residential Dryer
Whirlpool LE6098XSW1 Residential Dryer
Whirlpool LE6098XTW0 Residential Dryer
Whirlpool LE6098XTW1 Residential Dryer
Whirlpool LE6100XSW0 Residential Dryer
Whirlpool LE6150XSW0 Residential Dryer
Whirlpool LE6150XSW1 Residential Dryer
Whirlpool LE6400XKW0 Residential Dryer
Whirlpool LE6400XPW0 Residential Dryer
Whirlpool LE6400XSW0 Residential Dryer
Whirlpool LE6405XPW0 Residential Dryer
Whirlpool LE6600XPW0 Residential Dryer
Whirlpool LE6600XSW0 Residential Dryer
Whirlpool LE6605XPW0 Residential Dryer
Whirlpool LE6605XPW1 Residential Dryer
Whirlpool LE6680XPW0 Residential Dryer
Whirlpool LE6680XSW0 Residential Dryer
Whirlpool LE6685XPW0 Residential Dryer
Whirlpool LE6685XPW1 Residential Dryer
Whirlpool LE6800XPW0 Residential Dryer
Whirlpool LE6800XSW0 Residential Dryer
Whirlpool LE6800XTG0
Whirlpool LE6800XTN0
Whirlpool LE6800XTW0 Residential Dryer
Whirlpool LE6805XPW0 Residential Dryer
Whirlpool LE6810XPW0 Residential Dryer
Whirlpool LE6810XSW0 Residential Dryer
Whirlpool LE6880XSW0 Residential Dryer
Whirlpool LE6880XSW1 Residential Dryer
Whirlpool LE6880XTW0 Residential Dryer
Whirlpool LE6880XTW1 Residential Dryer
Whirlpool LE7000XMW0 Residential Dryer
Whirlpool LE7000XMW1 Residential Dryer
Whirlpool LE7000XMW2 Residential Dryer
Whirlpool LE7000XPW0 Residential Dryer
Whirlpool LE7000XSW0 Residential Dryer
Whirlpool LE7000XTG0
Whirlpool LE7000XTN0
Whirlpool LE7000XTW0 Residential Dryer
Whirlpool LE7005XPW0 Residential Dryer
Whirlpool LE7010XPW0 Residential Dryer
Whirlpool LE7010XSW0 Residential Dryer
Whirlpool LE7080XSW0 Residential Dryer
Whirlpool LE7080XSW1 Residential Dryer
Whirlpool LE7080XTW0 Residential Dryer
Whirlpool LE7080XTW1 Residential Dryer
Amana LE7101LB DRYER- ELE
Amana LE7101WB DRYER- ELE
Amana LE7111LB DRYER- ELE
Amana LE7111LM DRYER- ELE
Amana LE7111WB DRYER- ELE
Amana LE7111WM DRYER- ELE
Amana LE7121LM DRYER- ELE
Amana LE7121WM DRYER- ELE
Amana LE7153LB DRYER- ELE
Amana LE7153LM DRYER- ELE
Amana LE7153WB DRYER- ELE
Amana LE7153WM DRYER- ELE
Amana LE7163LM DRYER- ELE
Amana LE7163WM DRYER- ELE
Whirlpool LE7680XMW0 Residential Dryer
Whirlpool LE7680XPW0 Residential Dryer
Whirlpool LE7680XSW0 Residential Dryer
Whirlpool LE7680XSW1 Residential Dryer
Whirlpool LE7680XSW2 Residential Dryer
Whirlpool LE7685XPW0 Residential Dryer
Whirlpool LE7685XPW1 Residential Dryer
Whirlpool LE7700XWW0 Residential Dryer
Whirlpool LE7760XWW0 Residential Dryer
Whirlpool LE7800XKW0 Residential Dryer
Whirlpool LE7800XKW1 Residential Dryer
Whirlpool LE7800XMW0 Residential Dryer
Whirlpool LE7800XMW1 Residential Dryer
Whirlpool LE7800XMW2 Residential Dryer
Whirlpool LE7800XPW0 Residential Dryer
Whirlpool LE7800XSN2 ELECTRIC DRYER
Whirlpool LE7800XSW0 Residential Dryer
Whirlpool LE7800XSW1 Residential Dryer
Whirlpool LE7800XSW2 Residential Dryer
Whirlpool LE7800XSW3 Residential Dryer
Whirlpool LE7800XW2 ELECTRIC DRYER
Whirlpool LE7805XPW0 Residential Dryer
Whirlpool LE7810XPW0 Residential Dryer
Amana LE8107L2 WASHER-TOP LOADING
Amana LE8107W2 DRYER- ELE
Amana LE8207L2 WASHER-TOP LOADING
Amana LE8207L3 WASHER-TOP LOADING
Amana LE8207W2 DRYER- ELE
Amana LE8207W2B DRYER- ELE
Amana LE8207W3 DRYER- ELE
Amana LE8217L2 DRYER- ELE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool cooktop staying on hmbsparks Oven Repair (including Ranges and Cooktops) 1 01-01-2015 02:06 PM
Whirlpool Dryer NOT staying hot! dmarconi Dryer Repair 1 07-30-2012 08:38 AM
Whirlpool Dryer NOT staying hot! dmarconi Dryer Repair 0 07-30-2012 08:19 AM
Whirlpool Gas Dryer not staying hot nlemay Dryer Repair 1 04-13-2012 01:04 PM
Electric Double oven not staying on paxterra Oven Repair (including Ranges and Cooktops) 0 08-06-2010 10:16 AM
