Discuss
dyr runs doesnt heat
 in
Dryer Repair
My dryer doesnt heat checked voltage its 240 coming in checked continuity on heating element its 0.1 checked voltage going
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dyr runs doesnt heat
  #1 (permalink)
Old 11-16-2012, 01:48 PM
Junior Member
ausdoug is on a distinguished road
Default dyr runs doesnt heat
Model Number: aeq7000ego   Brand: Frigidaire   Age: 1 - 5 years
My dryer doesnt heat checked voltage its 240 coming in checked continuity on heating element its 0.1 checked voltage going into heater element its 75 volts the thermal fuse its closed and had 15 volts going in when the dryer is off and 0 when the dryer is running . dont know what else to check
Ads By Google
Related Models
Frigidaire AEQ7000EP0 Frigidaire/dryer
Frigidaire AEQ7000ES0 Frigidaire/dryer
Frigidaire AEQ7000ES1 Frigidaire/dryer
Frigidaire AEQB6000ES0 Frigidaire/dryer
Frigidaire AEQB6000ES1 Frigidaire/dryer
Frigidaire AEQB6000ES2 Frigidaire/dryer
Frigidaire AEQB7000EG0 Frigidaire/dryer
Frigidaire AEQB7000EP0 Frigidaire/dryer
Frigidaire AEQB7000ES0 Frigidaire/dryer
Frigidaire AEQB7000ES1 Frigidaire/dryer
General Electric AER05LHW1 Room air conditioner
Admiral AER1110AAH Range - F/s Std Ele
International AER1110BAH Range - F/s Std Ele
International AER1140AGH Range - F/s Std Ele
Admiral AER1150AAH Range - F/s Std Ele
Admiral AER1350AAH Range - F/s Std Ele
Admiral AER1350AAL Range - F/s Std Ele
Admiral AER1350AAT Range - F/s Std Ele
International AER1350AMH Range - S/c F/s Ele
International AER1350BAH Range - S/c F/s Ele
International AER1350BAT Range - S/c F/s Ele
International AER1360AGW Range - S/c F/s Ele
International AER1360BGW Range - S/c F/s Ele
Admiral AER1450AAH Range - F/s Std Ele
Admiral AER1450BAH Range - F/s Std Ele
Admiral AER2350AMH Range - F/s Std Ele
Amana AER4111AAW Frigidaire/air Conditioner
Amana AER4311AAW Range - F/s Std Ele
Amana AER5511AAB Range - S/c F/s Ele
Amana AER5511AAQ Range - S/c F/s Ele
Amana AER5511AAW Range - S/c F/s Ele
Amana AER5511ACB Range - S/c F/s Ele
Amana AER5511ACW Range - S/c F/s Ele
Amana AER5511BAB Crosley/dryer
Amana AER5511BAQ Range - S/c F/s Ele
Amana AER5511BAW Range - S/c F/s Ele
Amana AER5515QAQ Range - S/c F/s Ele
Amana AER5515QAW Range - S/c F/s Ele
Amana AER5515QCW Range - S/c F/s Ele
Amana AER5515RCW Range - S/c F/s Ele
Amana AER5710BAH Range - S/c F/s Ele
Amana AER5712AAQ Range - S/c F/s Ele
Amana AER5712AAS Range - S/c F/s Ele
Amana AER5712AAW Range - S/c F/s Ele
Amana AER5712AAZ Range - S/c F/s Ele
Amana AER5712ACW Range - S/c F/s Ele
Amana AER5712ACZ Range - S/c F/s Ele
Amana AER5712BAB Range - S/c F/s Ele
Amana AER5712BAW Range - S/c F/s Ele
Amana AER5712BAZ Range - S/c F/s Ele
Amana AER5715QAQ Range - S/c F/s Ele
Amana AER5715QAS Range - S/c F/s Ele
Amana AER5715QAW Range - S/c F/s Ele
Amana AER5715QCB Range - S/c F/s Ele
Amana AER5715QCS Range - S/c F/s Ele
Amana AER5715QCW Range - S/c F/s Ele
Amana AER5715RCB Range - S/c F/s Ele
Amana AER5715RCS Range - S/c F/s Ele
Amana AER5715RCW Range - S/c F/s Ele
Amana AER5722BAB Range - S/c F/s Ele
Amana AER5722BAQ Range - S/c F/s Ele
Amana AER5722BAS Range - S/c F/s Ele
Amana AER5722BAW Range - S/c F/s Ele
Amana AER5722CAS Range - S/c F/s Ele
Amana AER5725QAB Range - S/c F/s Ele
Amana AER5725QAF Range - S/c F/s Ele
Amana AER5725QAN Range - S/c F/s Ele
Amana AER5725QAQ Range - S/c F/s Ele
Amana AER5725QAS Range - S/c F/s Ele
Amana AER5725QAW Range - S/c F/s Ele
Amana AER5735QAB Range - S/c F/s Ele
Amana AER5735QAF Range - S/c F/s Ele
Amana AER5735QAN Range - S/c F/s Ele
Amana AER5735QAQ Range - S/c F/s Ele
Amana AER5735QAS Range - S/c F/s Ele
Amana AER5735QAW Range - S/c F/s Ele
Amana AER5815RCB Range - S/c F/s Ele
Amana AER5815RCS Range - S/c F/s Ele
Amana AER5815RCW Range - S/c F/s Ele
Amana AER5845QAB Range - F/s Std Ele
Amana AER5845QAF Range - F/s Std Ele
Amana AER5845QAN Range - F/s Std Ele
Amana AER5845QAS Range - F/s Std Ele
Amana AER5845RAB Range - S/c F/s Ele
Amana AER5845RAS Range - S/c F/s Ele
Amana AER5845RAW Range - S/c F/s Ele
Amana AES1350BAW Range - S/c S/i Ele
General Electric AES15DAV1 Room air conditioner
General Electric AES18DAM1 Room air conditioner
General Electric AES23DAR1 Room air conditioner
Amana AES3540BAW Range - S/c S/i Gas
Amana AES3760BAB Range - S/c S/i Ele
Amana AES3760BAQ Range - S/c S/i Ele
Amana AES3760BAS Range - S/c S/i Ele
Amana AES3760BAW Range - S/c S/i Ele
Amana AES3760BCB Range - F/s Std Ele
Amana AES3760BCS Range - F/s Std Ele
Amana AES3760BCW Range - F/s Std Ele
Amana AES5730BAB Range - S/c S/i Ele
Amana AES5730BAF Range - S/c S/i Ele
Amana AES5730BAN Range - S/c S/i Ele
Amana AES5730BAS Range - S/c S/i Ele
Amana AET-480 Range - S/c S/i Ddraft Gas
Amana AET-480A Range - S/c S/i Ddraft Gas
Amana AET-480B Range - S/c S/i Ddraft Gas
Amana AET-480C Range - S/c S/i Ddraft Gas
General Electric AET05LHW1 Room air conditioner
General Electric AET05LJG1 Room air conditioner
General Electric AET05LJS1 Room air conditioner
General Electric AET05LJW1 Room air conditioner
Amana AEU-516 Range - S/c S/i Ddraft Gas
Amana AEU-516A Range - S/c S/i Ddraft Gas
Amana AEU-516C Range - S/c S/i Ddraft Gas
Amana AEU-516D Range - S/c S/i Ddraft Gas
Amana AEU-516E Range - S/c S/i Ddraft Gas
Amana AEU-516F Range - S/c S/i Ddraft Gas
Amana AEU-516G Range - S/c S/i Ddraft Gas
General Electric AEV24DJH1 Room air conditioner
General Electric AEV24DKH1 Room air conditioner
General Electric AEW05LJG1 Room air conditioner
  #2 (permalink)
Old 11-17-2012, 02:30 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Parts for Frigidaire AEQ7000EG0 Dryer - AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodin...0ts_wd_EFS.pdf
See if you have any error codes.
Use a more sensitive meter scale. The heater should be approximately 13 ohms. Also disconnect one side of the heating coil when measuring it. This ensures that you do not read an alternate/parallel circuit path.
It is good practice to short your meter leads together before doing any measurements, this will tell you if there is a zero offset in the meter.
Be sure to unplug the unit.
I am not sure what you are doing here.
Is this referenced to ground /Neutral or across the heater?
Check from L1 to the High Limit Thermostat (left side on wiring diagram) with unit running in a heat cycle.
If you see 240 volts then the heater relay on the board is not closing for some reason.
Be very, very careful when running live voltage checks, 240 volts is lethal!!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer runs but doesnt heat up rwms113 Dryer Repair 4 12-18-2010 01:43 PM
Dryer timer doesnt move and doesnt heat? But turns on????Can you help me???? Slaughter31805 Dryer Repair 1 05-26-2010 04:48 AM
dryer runs but doesnt ignite and heat up ralphbrafa Dryer Repair 2 04-23-2010 07:34 AM
fan runs,compressor hot doesnt run mark f Refrigerator & Freezer Repair 4 03-17-2010 10:28 AM
Dryer doesnt heat but runs, timer isnt working either bridget Dryer Repair 0 11-03-2007 11:37 AM
