Discuss
Dryer quit, won't start again
 in
Dryer Repair
I've got to go to my mom's tomorrow to check out her dryer. It was running when all of a
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer quit, won't start again
  #1 (permalink)
Old 11-15-2012, 06:27 PM
Junior Member
RandyJ is on a distinguished road
Default Dryer quit, won't start again
Model Number: PYE2300AYW   Brand: Maytag   Age: More than 10 years
I've got to go to my mom's tomorrow to check out her dryer. It was running when all of a sudden it quit. At this point all I know is that it still will not start back up and is getting power on both legs of 220 volt outlet.
Just wondering what I should look for and if there is a troubleshooting routine (diagram) available that would help me pinpoint the problem really fast?
Ads By Google
Related Models
Maytag PYE2300AYW Dryer - Ele
Maytag PYE2300AZW Dryer - Ele
International PYE3200AGW Dryer - Ele
Maytag PYE3200AYW Dryer - Ele
Maytag PYE3200AZW Dryer - Ele
International PYE3300AGW Dryer - Ele
International PYE3300AKW Dryer - Ele
Maytag PYE3300AYW Dryer - Ele
Maytag PYE3300AZW Dryer - Ele
Maytag PYE3360AYW Dryer - Ele
Maytag PYE4500AYQ Dryer - Ele
Maytag PYE4500AYW Dryer - Ele
Maytag PYE4500AZW Dryer - Ele
Maytag PYE4557AYW Dryer - Ele
Maytag PYE4558AYW Dryer - Ele
Maytag PYET244AYW Dryer - Ele
Maytag PYET244AZW Dryer - Ele
Maytag PYET344AYQ Dryer - Ele
Maytag PYET344AYW Dryer - Ele
Maytag PYET344AZW Dryer - Ele
Maytag PYET444AYQ Dryer - Ele
Maytag PYET444AYW Dryer - Ele
Maytag PYET444AZW Dryer - Ele
Maytag PYG1000AWW Dryer - Gas
Maytag PYG2000AWW Dryer - Gas
Maytag PYG2200AWW Dryer - Gas
International PYG2300AGW Dryer - Gas
Maytag PYG2300AWW Dryer - Gas
Maytag PYG3200AWW Dryer - Gas
Maytag PYG3250AWW Dryer - Gas
Maytag PYG3300AWW Dryer - Gas
Maytag PYG3360AWW Dryer - Gas
Maytag PYG4500AWQ Dryer - Gas
Maytag PYG4500AWW Dryer - Gas
Maytag PYG4557AWW Dryer - Gas
Maytag PYG4558AWW Dryer - Gas
International PYGS244AWW Dryer - Gas
Maytag PYGT244AWW Dryer - Gas
Maytag PYGT344AWW Dryer - Gas
Maytag PYGT444AWQ Dryer - Gas
Maytag PYGT444AWW Dryer - Gas
Amana QDO-695 Range - S/c S/i Ddraft Gas
Amana QDO-695D Range - S/c S/i Ddraft Gas
Amana QDO-695E Range - S/c S/i Ddraft Gas
Amana QDO-695F Range - S/c S/i Ddraft Gas
Amana QDO-695G Range - S/c S/i Ddraft Gas
Amana QDO-695H Range - S/c S/i Ddraft Gas
Amana QDU-838 Range - S/c S/i Ddraft Gas
Amana QDU-838A Range - S/c S/i Ddraft Gas
Amana QDU-838B Range - S/c S/i Ddraft Gas
Amana QDU-838C Range - S/c S/i Ddraft Gas
Amana QDU-838D Range - S/c S/i Ddraft Gas
Amana QDU-838G Range - S/c S/i Ddraft Gas
Amana QDU-858 Range - S/c S/i Ddraft Gas
Amana QDU-858A Range - S/c S/i Ddraft Gas
Amana QDU-858B Range - S/c S/i Ddraft Gas
Amana QDU-858C Range - S/c S/i Ddraft Gas
Amana QDU-858D Range - S/c S/i Ddraft Gas
Amana QDU-858E Range - S/c S/i Ddraft Gas
Amana QDU-858G Range - S/c S/i Ddraft Gas
Amana QDU-878 Range - S/c S/i Ddraft Gas
Amana QDU-878A Range - S/c S/i Ddraft Gas
Amana QDU-878B Range - S/c S/i Ddraft Gas
Amana QDU-966 Range - S/c S/i Ddraft Gas
Amana QDU-976 Range - S/c S/i Ddraft Gas
Amana QDU-976A Range - S/c S/i Ddraft Gas
Amana QKO-661 Range - S/c S/i Ddraft Gas
Amana QKO-661B Range - S/c S/i Ddraft Gas
Amana QKO-661C Range - S/c S/i Ddraft Gas
Amana QKO-661D Range - S/c S/i Ddraft Gas
Amana QKO-661E Range - S/c S/i Ddraft Gas
Amana QKO-751 Range - S/c S/i Ddraft Gas
Amana QKO-751A Range - S/c S/i Ddraft Gas
Amana QKU-647 Range - S/c S/i Ddraft Gas
Amana QKU-647A Range - S/c S/i Ddraft Gas
Amana QMC811 Walloven - Std Mwave Ele
Amana QMD-800 Mwave - Family Size (60 Hz)
Amana QMD-800A Mwave - Family Size (60 Hz)
Amana QMD-800B Mwave - Family Size (60 Hz)
Amana QMD-800C Mwave - Family Size (60 Hz)
Amana QMD-800D Mwave - Family Size (60 Hz)
Amana QMD-800E Mwave - Family Size (60 Hz)
Amana QMD-800G Mwave - Family Size (60 Hz)
Amana QMD-810 Mwave - Family Size (60 Hz)
Amana QMD-810A Mwave - Family Size (60 Hz)
Amana QMD800 Walloven - Std Mwave Ele
Amana QMD800D Mwave - Family Size (60 Hz)
Amana QMD810 Walloven - Std Mwave Ele
Amana R-1 Range - S/c S/i Ddraft Gas
Amana R-1H Range - S/c S/i Ddraft Gas
Amana R-1J Mwave - Family Size (60 Hz)
Amana R-2 Range - S/c S/i Ddraft Gas
Amana R-3 Mwave - Family Size (60 Hz)
Amana R0-24-8 Mwave - Mounted Over Range/wo
Whirlpool R101
Whirlpool R1011
Whirlpool R1012
Whirlpool R1013
Whirlpool R1014
Whirlpool R121
Whirlpool R1211
Whirlpool R1212
Whirlpool R1213
Whirlpool R1231
Whirlpool R141A
Whirlpool R141A1
Whirlpool R141F0
Whirlpool R141G0
Amana R15 Misc / Accessory
Whirlpool R153
Amana R15A Misc / Accessory
Amana R15L Misc / Accessory
Amana R15LA Misc / Accessory
Whirlpool R183
Whirlpool R183A
  #2 (permalink)
Old 11-16-2012, 02:28 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts, includes a wiring diagram.
Parts for Maytag PYE2300AYW Dryer - AppliancePartsPros.com
Did you check that Neutral to L1 has 120 volts?
This is what runs the motor.
At the top on my list would be the thermal fuse (item 5 in the 05-Heater Parts section)
If you click on a parts picture a new page will open with more info on that part. This may be helpful to you.
Note: If you put the unit mid cycle timed dry and the timer advances then the thermal fuse is OK so then check the door switch and the timer contacts and finally the motor windings.
If the thermal fuse is blown you have to find out why it blew.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
__________________
  #3 (permalink)
Old 11-16-2012, 10:15 AM
Junior Member
Default
All fuses & thermostats appear to be good when checked with ohm meter. Looking at the wiring diagram I tried to jump the timer to get the motor to run but nothng happened. I jumped the purple to black on the timer... nothing happened. Is there a simple way to check the motor without having to remove it? I can deduct the wires to make the motor run, but would you confirm this by telling me which two wires to wire directly for a quick, simple test?,,, or just some way to check the motor without having to completely remove it? How about the timer?... any quick/easy way to check a timer? I have unnecessarily thrown away $100 replacing a timer before because somebody told me it was bad without testing. I'm not one to throw parts at something to try to fix it.
  #4 (permalink)
Old 11-16-2012, 10:43 AM
Senior Expert
APP Volunteer
Default
Try the following, print out the wiring diagram as it will help.
Short the meter leads together before you start so you can see if there is any zero offset.
Attach one meter lead to the Neutral on the power cord and leave it there.
Set the timer to mid scale timed dry, door switch closed.
Set your meter to the most sensitive scale.
Check to both sides of the thermal fuse both should be 0 ohms.
Check to "1" on the motor, should be 0 ohms.
Check to "S" purple on the timer, should be a couple ohms (the motor windings)
Check to "M" orange on the timer, also a couple ohms.
Check to "L" (probably black) on the timer, also a couple ohms
Check to L1 on the line cord plug end, also a couple ohms.
The above checks the motor circuit.
__________________
  #5 (permalink)
Old 11-16-2012, 01:52 PM
Junior Member
Default
Thanks denman. I checked as described except that I'm not able to get to the motor to check neutral to "1". The readings I got are
s- 2.0 ohms
m- 2.33 kohms
L-2.55 kohms
L1- 2.33 k ohms
not quite sure which is the cycling thermostat as I didn't see it labeled in any drawings. As I recall I already had checked the thermal fuse and got a "0.0000" reading.
So far, my best guess is a bad motor. Worst part is that I brought in an old Hotpoint which I discovered has a bad heating element and I have not been able to even rig the element to make it work temporarily by twisting the burned ends back together. THANKS!
  #6 (permalink)
Old 11-16-2012, 03:05 PM
Senior Expert
APP Volunteer
Default
OOPS!!!
Your readings up to "S" look OK.
But at this point I screwed up and should have told you that the Push to Start switch must be pushed for the other readings.
Note that the cycling thermostat does not matter as it is not part of the motor starting or run circuit
If the resistance readings are OK double check that you have 120 volts between L1 (black) and Neutral (white)
__________________
  #7 (permalink)
Old 11-16-2012, 03:52 PM
Junior Member
Default
black/L1 already checked. That's where I pulled power from to try to jump the timer attempting to get the motor to run by itself.(connected purple to black, L1). It was getting late so we had to leave. It's an hours drive for me so unless I can confirm it's a motor we'll have to wait another day. I do know the push to start part of the timer is functioning (confirmed with continuity test w/ ohm meter). I sure don't want to buy a motor if this thing doesn't actually need one. The symptom is simply that when you push the start button NOTHING happens. The timer motor doesn't appear to run though I have jumped power to it and I could hear it running with power applied directly.
I also checked by jumping directly from L1-black to orange with no reaction from motor.(extra spade to spade connector)
... as I recall, white, orange, & purple are the run circuits, green/ground, the other wires are for centrifugal switching of heating elements & timer.
  #8 (permalink)
Old 11-16-2012, 04:41 PM
Senior Expert
APP Volunteer
Default
I am not sure what you did here.
This will not start the motor.
The orange is not connected to the motor windings when the motor is at rest.
When at rest purple (connector 2 to B and A) connects in the run and aux (start) windings.
When the motor gets close to operating speed the centrifugal switch activates (connector 3 to 2/B) the aux winding is disconnected and the run winding remains connected.
This is done because if the aux winding is left in circuit the motor will overheat.
White is Neutral. On a 3 wire hook up this is also green/earth ground.
Orange is the run winding. It has 2 purposes . First it disconnects the aux (start) winding. Second it provides a parallel circuit path around the push to start switch. This lets you release the push to start and the unit motor keeps running.
The timer is not really switched in by the centrifugal switches.
The centrifugal switch in the lower right of the wiring diagram does switch in the heating element. This ensures that the element does not come on until there is air flow.
In auto modes the timer motor does get power through the heating coil when the coil is shut off so in a way the switch does effect the timer motor.
In timed dry mode the timer motor gets power direct from Neutral through timer contacts (B/TM) to L1.
__________________
  #9 (permalink)
Old 11-16-2012, 05:03 PM
Junior Member
Default
hmm... so, what I did by connecting L1 (black on timer) to S (purple) should power the motor and make it run? (Just trying to figure out which wires to jump to make motor run for testing puposes).
  #10 (permalink)
Old 11-16-2012, 05:17 PM
Senior Expert
APP Volunteer
Default
Yes it should have run.
As long as you are sure there is L1 to Neutral power then I would replace the motor.
Just strange that there is not hum/buzz when at least one winding measures OK.
Looks like the motor is around $175.00 so unless the unit is in very good shape I would scrap it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Estate Dryer just quit and wont start z71man_1996 Dryer Repair 1 10-27-2011 01:06 PM
dryer quit heating and water quit filling up on Maytag stackable oldrugrat Washer Repair 3 05-17-2011 05:00 AM
dryer quit wd45gto Dryer Repair 4 03-12-2011 04:06 AM
Dryer will not start - will power up, but when push the start button, will not start perduena Dryer Repair 0 07-12-2010 07:14 PM
Dryer Quit edcassell Dryer Repair 1 03-06-2010 01:48 AM
