Discuss
Dryer Won't Start
 in
Dryer Repair
My dryer began to fail by not restarting if the door was opened in the middle of a cycle. The
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Won't Start
  #1 (permalink)
Old 11-14-2012, 12:30 PM
Junior Member
Paul Gibson is on a distinguished road
Default Dryer Won't Start
Model Number: LE8567W2   Brand: Amana   Age: More than 10 years
My dryer began to fail by not restarting if the door was opened in the middle of a cycle. The dial had to be turned to the starting position of a cycle and then it would run the entire cycle. Now it won't start at all. As the dial is rotated through the various cycles, at certain points a small motor can be heard operating and the dial then continues rotating under its own power, but no drying takes place and the drum does not turn.
The dial cannot be depressed to start a drying because it never pops out.
The light in the drum is responsive to pushing and releasing the switch lever so there is power to the machine and at least part of the switch works.
Ads By Google
Related Models
Amana LE8567W2 Dryer - Ele
Whirlpool LE8600XWN0
Whirlpool LE8600XWW0
Amana LE8607L2 Dryer - Ele
Amana LE8607W Dryer - Ele
Amana LE8607W2 Dryer - Ele
Whirlpool LE8650XWN0
Whirlpool LE8650XWW0
Whirlpool LE8860XWQ0
Amana LE9002 Dryer - Ele
Amana LE9012 Washer - Top Loading
Whirlpool LE9100XTN0
Whirlpool LE9100XTN1
Whirlpool LE9100XTW0
Whirlpool LE9100XTW1
Amana LE9107W Dryer - Ele
Whirlpool LE9200XWN0
Whirlpool LE9200XWN1
Whirlpool LE9200XWW0
Whirlpool LE9200XWW1
Amana LE9207L2 Dryer - Ele
Amana LE9207W Dryer - Ele
Amana LE9207W2 Dryer - Ele
Whirlpool LE9300XTN0
Whirlpool LE9300XTN1
Whirlpool LE9300XTW0
Whirlpool LE9300XTW1
Whirlpool LE9380XTN0
Whirlpool LE9380XTW0
Whirlpool LE9480XWG1
Whirlpool LE9480XWN0
Whirlpool LE9480XWN1
Whirlpool LE9480XWW0
Whirlpool LE9480XWW1
Whirlpool LE9500XTF0
Whirlpool LE9500XTG0
Whirlpool LE9500XTG1
Whirlpool LE9500XTM0
Whirlpool LE9500XTN0
Whirlpool LE9500XTN1
Whirlpool LE9500XTW0
Whirlpool LE9500XTW1
Whirlpool LE9520XTW0
Whirlpool LE9520XTW1
Whirlpool LE9680XWG1
Whirlpool LE9680XWN0
Whirlpool LE9680XWN1
Whirlpool LE9680XWW0
Whirlpool LE9680XWW1
Whirlpool LE9800XKW0
Whirlpool LE9800XKW1
Whirlpool LE9800XMW0
Whirlpool LE9800XMW1
Whirlpool LE9800XMW2
Whirlpool LE9800XPF1
Whirlpool LE9800XPG1
Whirlpool LE9800XPM1
Whirlpool LE9800XPN1
Whirlpool LE9800XPT1
Whirlpool LE9800XPW0
Whirlpool LE9800XPW1
Whirlpool LE9800XSW0
Whirlpool LE9805XPW0
Amana LEA10AW Dryer - Ele
Amana LEA20AL Dryer - Ele
Amana LEA20AW Dryer - Ele
Amana LEA30AL Dryer - Ele
Amana LEA30AW Dryer - Ele
Amana LEA50AL Dryer - Ele
Amana LEA50AW Dryer - Ele
Amana LEA60AL Dryer - Ele
Amana LEA60AW Dryer - Ele
Amana LEA80AL Dryer - Ele
Amana LEA80AW Dryer - Ele
Amana LEA90AL Dryer - Ele
Amana LEA90AW Dryer - Ele
General Electric LEB116GR1AD Electric range
General Electric LEB116GR1WH Electric range
General Electric LEB116GT1AD Electric range
General Electric LEB116GT1WH Electric range
General Electric LEB116GT2AD Electric range
General Electric LEB116GT2WH Electric range
General Electric LEB131GR1AD Electric range
General Electric LEB131GR1WH Electric range
General Electric LEB131GT1AD Electric range
General Electric LEB131GT1WH Electric range
General Electric LEB131GT2AD Electric range
General Electric LEB131GT2WH Electric range
General Electric LEB131GY1AD Electric range
General Electric LEB131GY1WH Electric range
General Electric LEB131GY2AD Electric range
General Electric LEB131GY2WH Electric range
General Electric LEB133GS1WW Electric range
General Electric LEB316GR1AD Electric range
General Electric LEB316GR1WH Electric range
General Electric LEB316GT1AD Electric range
General Electric LEB316GT1WH Electric range
General Electric LEB316GT2AD Electric range
General Electric LEB316GT2WH Electric range
General Electric LEB316GT3AD Electric range
General Electric LEB316GT3WH Electric range
General Electric LEB316GT4AD Electric range
General Electric LEB316GT4WH Electric range
General Electric LEB316GT5AD Electric range
General Electric LEB316GT5WH Electric range
General Electric LEB326GR1AD Electric range
General Electric LEB326GR1WH Electric range
General Electric LEB326GT1AD Electric range
General Electric LEB326GT1WH Electric range
General Electric LEB326GT2AD Electric range
General Electric LEB326GT2WH Electric range
General Electric LEB326GT3AD Electric range
General Electric LEB326GT3WH Electric range
General Electric LEB326GT4AD Electric range
General Electric LEB326GT4WH Electric range
General Electric LEB326GT5AD Electric range
General Electric LEB326GT5WH Electric range
General Electric LEB327GS1WW Electric range
General Electric LEB327GT1WW Electric range
  #2 (permalink)
Old 11-15-2012, 02:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello Paul,
Sounds like the problem is a bad timer. In order to find the correct part number and availability I need you to open the control panel and get all numbers from the original timer.
How many cycles are in the dryer: 3 or 5?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 11-15-2012, 07:16 PM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Hello Paul,
There are 5 cycles including 2 w/o heat. There are 3 separate numbers.
RSPC 502967
and Model 275BEF
and 5212A
Thanks so much.
Paul
  #4 (permalink)
Old 11-15-2012, 07:20 PM
Junior Member
Default
Quote:
RSPC 502967
and Model 275BEF
and 5212A
Thanks so much.
Paul
I should have added this is an Amana model #LE8567W2
  #5 (permalink)
Old 11-16-2012, 03:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Bad news Paul. Unfortunately 5 cycles timer is no longer available. The 3 cycles timer is still available but I'm not sure if they are interchangeable.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HOT POINT DRYER has power but start button doesn't start the dryer. HOT POINT Dryer Repair 2 08-01-2011 06:47 PM
Dryer wont start, sensing light just flashes when i hold down the start button! crsteilen Dryer Repair 0 03-28-2011 03:21 PM
Dryer wont start, sensing light just flashes when i hold down the start button! crsteilen Dishwasher Repair 0 03-28-2011 12:13 PM
Dryer will not start - will power up, but when push the start button, will not start perduena Dryer Repair 0 07-12-2010 07:14 PM
dryer start button flashing and not clicking to start dryer lawfamily Dryer Repair 0 06-21-2010 07:43 PM
