| » Dryer over heating |
A model number may help others help you.
Can the unit be set to low heat and does this reduce the heat output? If not check for a grounded element. Unplug the unit and both wires to the coil. Check it with a meter, should be around 10 to 12 ohms. Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high all the time.
__________________
| Display Modes | |
| Dryer Heating Element wont shut off When Dryer vis off | scottxbonnie | Dryer Repair | 1 | 07-31-2012 02:39 AM |
| GE dryer electric overheating but not heating in dryer | Helpfulwife | Dryer Repair | 0 | 02-25-2012 10:34 AM |
| Dryer not heating and it's not the heating element | msearcy50 | Dryer Repair | 2 | 10-26-2011 01:14 PM |
| GE dryer stopped heating but dryer still works | picker1 | Dryer Repair | 1 | 04-07-2011 03:46 AM |
| Dryer not heating | indybob65 | Dryer Repair | 1 | 12-24-2009 12:55 PM |
