Discuss
WhirlPool Duet Fo1 Error
 in
Dryer Repair
My Whirlpool Duet Stem Dryer powers on and when you press the start button, you get a click, and then
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » WhirlPool Duet Fo1 Error
  #1 (permalink)
Old 11-13-2012, 12:29 PM
Junior Member
wellerons is on a distinguished road
Default WhirlPool Duet Fo1 Error
Model Number: WED9500TW1   Brand: Whirlpool   Age: 1 - 5 years
My Whirlpool Duet Stem Dryer powers on and when you press the start button, you get a click, and then it sits for about 30 seconds then you get another click and it diplays an F01 error. I turned off power at the circuit breaker for 30 minutes and turned it back on and the symptoms remained the same. I even read in one forum to diconnect the P4 plug from the control board that is mounted on the top of the dryer with the relay that clicks and then plug it in with the power off to just get it jump started and that did nothing either. I dissembled it following structions I found here and see the white module that is attached to the top crossmember with the relay that clicks and then opened up the front to expose the electronics control module assembly. Much to my surprise since I couldn't find the exact moddel I have on here it has 2 circuit boards in there. So now I am what as far as I can tell 3 possible options for the failure and no way to determine which one it will be. Any assistance would be greatly appreciated.
Related Models
Whirlpool WED9500TW1 ELECTRIC DRYER
Whirlpool WED9500TW2 ELECTRIC DRYER
Whirlpool WED9500TW3 ELECTRIC DRYER
Whirlpool WED9550WL0 ELECTRIC DRYER
Whirlpool WED9550WL1 ELECTRIC DRYER
Whirlpool WED9550WR0 ELECTRIC DRYER
Whirlpool WED9550WR1 ELECTRIC DRYER
Whirlpool WED9550WW0 ELECTRIC DRYER
Whirlpool WED9550WW1 ELECTRIC DRYER
Whirlpool WED95HEXL0 DRYER
Whirlpool WED95HEXL1 27" ELECTRIC DRYER
Whirlpool WED95HEXR0 DRYER
Whirlpool WED95HEXR1 27" ELECTRIC DRYER
Whirlpool WED95HEXW0 DRYER
Whirlpool WED95HEXW1 27" ELECTRIC DRYER
Whirlpool WED9600SU0 ELECTRIC DRYER
Whirlpool WED9600TA0 27" ELECTRIC DRYER
Whirlpool WED9600TA1 27" ELECTRIC DRYER
Whirlpool WED9600TA2 27" ELECTRIC DRYER
Whirlpool WED9600TB0 27" ELECTRIC DRYER
Whirlpool WED9600TB1 27" ELECTRIC DRYER
Whirlpool WED9600TU0 27" ELECTRIC DRYER
Whirlpool WED9600TU1 27" ELECTRIC DRYER
Whirlpool WED9600TW0 27" ELECTRIC DRYER
Whirlpool WED9600TW1 27" ELECTRIC DRYER
Whirlpool WED9600TW2 27" ELECTRIC DRYER
Whirlpool WED9600TZ0 27" ELECTRIC DRYER
Whirlpool WED9610XW0 27" ELECTRIC DRYER
Whirlpool WED9750WL0 27" ELECTRIC DRYER
Whirlpool WED9750WR0 27" ELECTRIC DRYER
Whirlpool WED9750WW0 27" ELECTRIC DRYER
Whirlpool WED97HEXL0 ELECTRIC DRYER
Whirlpool WED97HEXL1 27" ELECTRIC DRYER
Whirlpool WED97HEXL2 27" ELECTRIC DRYER
Whirlpool WED97HEXR0 ELECTRIC DRYER
Whirlpool WED97HEXR1 27" ELECTRIC DRYER
Whirlpool WED97HEXR2 27" ELECTRIC DRYER
Whirlpool WED97HEXW0 ELECTRIC DRYER
Whirlpool WED97HEXW1 27" ELECTRIC DRYER
Whirlpool WED97HEXW2 27" ELECTRIC DRYER
White Westinghouse WEF303PHDA White Westinghouse/electric Range
White Westinghouse WEF303PHDB White Westinghouse/electric Range
White Westinghouse WEF303PHWA White Westinghouse/electric Range
White Westinghouse WEF303PHWB White Westinghouse/electric Range
White Westinghouse WEF311SHDA White Westinghouse/electric Range
White Westinghouse WEF311SHWA White Westinghouse/electric Range
Frigidaire WEF322BADA Wwh(v1) / Electric Range
Frigidaire WEF322BADB Wwh(v1) / Electric Range
Frigidaire WEF322BADC Wwh(v2) / Electric Range
Frigidaire WEF322BADD Wwh(v1) / Electric Range
Frigidaire WEF322BAWA Wwh(v2) / Electric Range
Frigidaire WEF322BAWB Wwh(v3) / Electric Range
Frigidaire WEF322BAWC Wwh(v4) / Electric Range
Frigidaire WEF322BAWD Wwh(v2) / Electric Range
Frigidaire WEF322BEDA Wwh(v1) / Electric Range
Frigidaire WEF322BEDB Wwh(v1) / Electric Range
Frigidaire WEF322BEWA Wwh(v2) / Electric Range
Frigidaire WEF322BEWB Wwh(v2) / Electric Range
Frigidaire WEF322BEWC Frg(v0) / Electric Range
Frigidaire WEF322SADA Wwh(v1) / Electric Range
Frigidaire WEF322SADB Wwh(v1) / Electric Range
Frigidaire WEF322SADC Wwh(v5) / Electric Range
Frigidaire WEF322SADD Wwh(v3) / Electric Range
Frigidaire WEF322SAWA Wwh(v2) / Electric Range
Frigidaire WEF322SAWB Wwh(v2) / Electric Range
Frigidaire WEF322SAWC Wwh(v6) / Electric Range
Frigidaire WEF322SAWD Wwh(v4) / Electric Range
White Westinghouse WEF326GSA ELECTRIC RANGE
White Westinghouse WEF326GSB ELECTRIC RANGE
Frigidaire WEF350BADB Wwh(v1) / Electric Range
Frigidaire WEF350BADC Wwh(v1) / Electric Range
Frigidaire WEF350BAWB Wwh(v2) / Electric Range
Frigidaire WEF350BAWC Wwh(v2) / Electric Range
Frigidaire WEF350CASA Wwh(v0) / Electric Range
White Westinghouse WEF350ESA White Westinghouse/range
White Westinghouse WEF350ESB White Westinghouse/range
Frigidaire WEF350SADA Wwh(v1) / Electric Range
Frigidaire WEF350SADB Wwh(v1) / Electric Range
Frigidaire WEF350SADC Wwh(v3) / Electric Range
Frigidaire WEF350SAWA Wwh(v2) / Electric Range
Frigidaire WEF350SAWB Wwh(v2) / Electric Range
Frigidaire WEF350SAWC Wwh(v4) / Electric Range
White Westinghouse WEF351ESA White Westinghouse/range
White Westinghouse WEF351ESB White Westinghouse/range
White Westinghouse WEF351ESC WHITE-WESTINGHOUSE/RANGE
Frigidaire WEF352BADA Wwh(v1) / Electric Range
Frigidaire WEF352BADB Wwh(v2) / Electric Range
Frigidaire WEF352BAWA Wwh(v3) / Electric Range
Frigidaire WEF352BAWB Wwh(v4) / Electric Range
Frigidaire WEF352BEDA Wwh(v1) / Electric Range
Frigidaire WEF352BEDB Wwh(v1) / Electric Range
Frigidaire WEF352BEDC Wwh(v1) / Electric Range
Frigidaire WEF352BEWA Wwh(v2) / Electric Range
Frigidaire WEF352BEWB Wwh(v2) / Electric Range
Frigidaire WEF352BEWC Wwh(v2) / Electric Range
Frigidaire WEF357BADA Wwh(v1) / Electric Range
Frigidaire WEF357BADB Wwh(v1) / Electric Range
Frigidaire WEF357BADC Wwh(v1) / Electric Range
Frigidaire WEF357BADD Wwh(v2) / Electric Range
Frigidaire WEF357BAWA Wwh(v2) / Electric Range
Frigidaire WEF357BAWB Wwh(v2) / Electric Range
Frigidaire WEF357BAWC Wwh(v3) / Electric Range
Frigidaire WEF357BAWD Wwh(v4) / Electric Range
White Westinghouse WEF360ESB White Westinghouse/range
White Westinghouse WEF360ESC White Westinghouse/range
White Westinghouse WEF360ESD White Westinghouse/range
White Westinghouse WEF361ESA White Westinghouse/range
White Westinghouse WEF361ESB White Westinghouse/range
White Westinghouse WEF361ESC White Westinghouse/range
White Westinghouse WEF361ESD White Westinghouse/range
White Westinghouse WEF365BHDA White Westinghouse/electric Range
White Westinghouse WEF365BHDB White Westinghouse/electric Range
White Westinghouse WEF365BHWA White Westinghouse/electric Range
White Westinghouse WEF365BHWB White Westinghouse/electric Range
White Westinghouse WEQ332HS0 ELECTRIC DRYER
White Westinghouse WER111ES0 White Westinghouse/dryer
White Westinghouse WER211CES0 White Westinghouse/dryer
White Westinghouse WER211ES0 White Westinghouse/dryer
Whirlpool WERC3100PQ0 30" ELECTRIC FREESTANDING SELF CLEAN CONVECTION OVEN
Whirlpool WERC3100PQ1 30" ELECTRIC FREESTANDING SELF CLEAN CONVECTION OVEN
  #2 (permalink)
Old 11-14-2012, 02:14 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Whirlpool WED9500TW1 Dryer - AppliancePartsPros.com
The error points to the electronic control board (item 40 in the Cabinet Parts section).
I do not understand what the above means.
__________________
  #3 (permalink)
Old 06-14-2015, 05:38 AM
Junior Member
sjl127 is on a distinguished road
Default What it looks like.
Quote:
Originally Posted by denman View Post
Happend to me, here's the part and what it looks like underneath.
The relay "fried."
I wonder why?
  #4 (permalink)
Old 06-14-2015, 05:46 AM
Junior Member
Default
Quote:
The relay "fried."
I wonder why?
See the pictures.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet F11 FDL error codes kirstenrdh Washer Repair 5 02-18-2014 04:46 PM
Whirlpool Duet FH error rwazbill Washer Repair 0 05-09-2012 11:33 AM
Whirlpool Duet won't spin and has F20 error Teresamc Washer Repair 1 06-28-2011 06:15 PM
Whirlpool Duet dryer f 22 error vikemike Dryer Repair 1 01-08-2010 01:57 AM
Whirlpool duet F11 error kheda61 Washer Repair 1 06-09-2009 05:31 PM
