| » Maytag Dryer Timer Problem |
Model Number: MDG8000BWW Brand: Maytag Age: 5 - 10 years
We have a Maytag gas dryer Model: MDG8000BWW that it has a problem:
Switch Settings as follows: “Temperature” = Regular “Ultra Care” = Off “Press Care” = Off Timer Settings: (1) “Intellidry Wrinkle Free Press Care” = Setting pointer must be in a certain spot before the “Start” button will turn the dryer on. (2) “Intellidry Regular” = If pointer is set to “More Dry” the dryer starts fine but the cycle ends mid-way and the chime sounds but the clothes do not dry. If the pointer is then reset past the stopped point to “Less Dry” the dryer starts fine and the clothes dry but then the pointer continues past “Off”, the chime does not sound and the dryer does not shut off. We have to open the door to stop it. (3) “Time Dry” = We set the timer to 20 minutes, pressed “Start” and the clothes dried fine but once again but the pointer continues past “Off”, the chime does not sound and the dryer does not shut off. We have to open the door to stop it Please advise what should to to test components and/or parts I need to repair it. Thanks. Ads By Google Related Models |
Sounds like the problem is a bad timer.
- The timer Part number: 33001730 Here are the breakdown diagrams and Parts for Maytag MDG8000BWW Dryer - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| maytag timer problem | tomcolorado | Washer Repair | 5 | 02-02-2012 03:01 PM |
| Maytag Dryer Squeaking and Timer Problem | Bob M | Dryer Repair | 2 | 08-30-2011 02:24 PM |
| maytag timer problem | top00cat | Dryer Repair | 3 | 03-11-2011 06:05 AM |
| Maytag timer problem? | Aaron2010 | Washer Repair | 1 | 06-24-2010 02:20 PM |
| Maytag dryer timer problem | larryz | Dryer Repair | 3 | 06-21-2009 10:04 AM |
