Discuss
Dryer Replacement Motor W1041099 Won't Run
 in
Dryer Repair
just replaced original motor with new motor part #w1041099 on electric dryer de612. terminated per instructions as follows: REMOVED BLUE
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Replacement Motor W1041099 Won't Run
  #1 (permalink)
Old 11-12-2012, 09:45 AM
Junior Member
GPro is on a distinguished road
Default Dryer Replacement Motor W1041099 Won't Run
Model Number: DE612   Brand: Maytag   Age: More than 10 years
just replaced original motor with new motor part #w1041099 on electric dryer de612. terminated per instructions as follows: REMOVED BLUE JUMPER ON NEW MOTOR FROM TERMINAL 4 AND 1/4" PROTECTOR TAB & CONNECTED GRAY #50 (L1) TO 1/4" PROTECTOR TAB, RED (NEUTRAL) TO TERMINAL #5, BLUE #7 (L2 HEATER) TO TERMINAL #1, BLACK #54 (HEATER) TO TERMINAL #2, YELLOW #34 &#35 (PUSH-TO-START) TO TERMINAL #6. Tested the following with ohm meter: push-to-start PB, door sw, all 3 temperature switches (also using hot plate) - all working.
Don't know how to test timer but with power connected can hear it running.
How can i test motor independent from controls? Tried disconnecting all motor leads and using separate 110v power cord connected to 1/4" protector tab and terminal #5 where red neutral goes - nothing happened (also rotated shaft to engage centrifugal swithch while connected).
Ads By Google
Related Models
Maytag DE612 DRYER- ELE
Amana DE6151 WASHER-TOP LOADING
Amana DE6171 WASHER-TOP LOADING
Frigidaire DE620EXD1 Wwh(v1) / Gas and Electric Dryers
Frigidaire DE620EXD2 Wwh(v2) / Gas and Electric Dryers
Frigidaire DE620EXD3 Wwh(v3) / Gas and Electric Dryers
Frigidaire DE620EXW1 Wwh(v4) / Gas and Electric Dryers
Frigidaire DE620EXW2 Wwh(v5) / Gas and Electric Dryers
Frigidaire DE620EXW3 Wwh(v6) / Gas and Electric Dryers
Amana DE6230 WASHER-TOP LOADING
Amana DE6231 WASHER-TOP LOADING
Amana DE6260 WASHER-TOP LOADING
Amana DE6261 WASHER-TOP LOADING
Frigidaire DE640ADD1 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE640ADD2 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE640ADW1 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE640ADW2 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE640JDD1 Wwh(v1) / Electric Dryer
Frigidaire DE640JDF1 Wwh(v2) / Electric Dryer
Frigidaire DE640JDH1 Wwh(v3) / Electric Dryer
Frigidaire DE640JDV1 Wwh(v4) / Electric Dryer
Frigidaire DE640JDW1 Wwh(v5) / Electric Dryer
Frigidaire DE640KDD1 Wwh(v12) / Electric Dryer
Frigidaire DE640KDD2 Wwh(v12) / 27 " Electric Dryer
Frigidaire DE640KDD3 Wwh(v3) / 27 " Electric Dryer
Frigidaire DE640KDD4 Wwh(v3) / 27 " Electric Dryer
Frigidaire DE640KDD5 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE640KDD6 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE640KDH1 Wwh(v8) / Electric Dryer
Frigidaire DE640KDH2 Wwh(v11) / 27 " Electric Dryer
Frigidaire DE640KDH3 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE640KDH4 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE640KDW1 Wwh(v4) / Electric Dryer
Frigidaire DE640KDW2 Wwh(v10) / 27 " Electric Dryer
Frigidaire DE640KDW3 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE640KDW4 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE640KDW5 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE640KDW6 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE6420RW1 Frg(v1) / 27 " Electric Dryer
Frigidaire DE6420RW2 Frg(v1) / 27 " Electric Dryer
Frigidaire DE6420RW3 Frg(v1) / 27 " Electric Dryer
Frigidaire DE6500ADD1 Frg(v0) / 27 " Electric Dryer
Frigidaire DE6500AWW1 Frg(v1) / 27 " Electric Dryer
Frigidaire DE650ADD1 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE650ADD2 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE650ADD3 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE650ADW1 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE650ADW2 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE650ADW3 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE650EDD1 Wwh(v1) / Electric Dryer
Frigidaire DE650EDD4 Wwh(v2) / Electric Dryer
Frigidaire DE650EDD5 Wwh(v3) / Electric Dryer
Frigidaire DE650EDF1 Wwh(v4) / Electric Dryer
Frigidaire DE650EDF4 Wwh(v5) / Electric Dryer
Frigidaire DE650EDF5 Wwh(v6) / Electric Dryer
Frigidaire DE650EDH1 Wwh(v7) / Electric Dryer
Frigidaire DE650EDH4 Wwh(v8) / Electric Dryer
Frigidaire DE650EDH5 Wwh(v9) / Electric Dryer
Frigidaire DE650EDV1 Wwh(v10) / Electric Dryer
Frigidaire DE650EDV4 Wwh(v11) / Electric Dryer
Frigidaire DE650EDV5 Wwh(v12) / Electric Dryer
Frigidaire DE650EDW1 Wwh(v13) / Electric Dryer
Frigidaire DE650EDW4 Wwh(v14) / Electric Dryer
Frigidaire DE650EDW5 Wwh(v15) / Electric Dryer
Frigidaire DE650JDD1 Wwh(v6) / Electric Dryer
Frigidaire DE650JDF1 Wwh(v7) / Electric Dryer
Frigidaire DE650JDH1 Wwh(v8) / Electric Dryer
Frigidaire DE650JDV1 Wwh(v9) / Electric Dryer
Frigidaire DE650JDW1 Wwh(v10) / Electric Dryer
Frigidaire DE650KDD1 Wwh(v10) / Electric Dryer
Frigidaire DE650KDD2 Wwh(v6) / 27 " Electric Dryer
Frigidaire DE650KDD3 Wwh(v6) / 27 " Electric Dryer
Frigidaire DE650KDD4 Wwh(v6) / 27 " Electric Dryer
Frigidaire DE650KDD5 Wwh(v6) / 27 " Electric Dryer
Frigidaire DE650KDD6 Wwh(v6) / 27 " Electric Dryer
Frigidaire DE650KDH1 Wwh(v6) / Electric Dryer
Frigidaire DE650KDH2 Wwh(v5) / 27 " Electric Dryer
Frigidaire DE650KDW1 Wwh(v2) / Electric Dryer
Frigidaire DE650KDW3 Wwh(v4) / 27 " Electric Dryer
Frigidaire DE650KDW4 Wwh(v4) / 27 " Electric Dryer
Frigidaire DE650KDW5 Wwh(v4) / 27 " Electric Dryer
Frigidaire DE650KDW6 Wwh(v4) / 27 " Electric Dryer
Frigidaire DE651EDD4 Wwh(v1) / Electric Dryer
Frigidaire DE651EDD5 Wwh(v2) / Electric Dryer
Frigidaire DE651EDH4 Wwh(v3) / Electric Dryer
Frigidaire DE651EDH5 Wwh(v4) / Electric Dryer
Frigidaire DE651EDW4 Wwh(v5) / Electric Dryer
Frigidaire DE651EDW5 Wwh(v6) / Electric Dryer
Frigidaire DE6520AL1 Frg(v2) / 27 " Electric Dryer
Frigidaire DE6520AW1 Frg(v1) / 27 " Electric Dryer
Frigidaire DE661JDD1 Wwh(v1) / Electric Dryer
Frigidaire DE661JDH1 Wwh(v2) / Electric Dryer
Frigidaire DE661JDW1 Wwh(v3) / Electric Dryer
Frigidaire DE6900RW1 Frg(v1) / 27 " Electric Dryer
Frigidaire DE6900RW2 Frg(v1) / 27 " Electric Dryer
Maytag DE700 DRYER- ELE
Frigidaire DE7000ADD1 Frg(v2) / 27 " Electric Dryer
Frigidaire DE7000AWW1 Frg(v1) / 27 " Electric Dryer
Frigidaire DE700EDD1 Wwh(v1) / Electric Dryer
Frigidaire DE700EDD2 Wwh(v2) / Electric Dryer
Frigidaire DE700EDD4 Wwh(v3) / Electric Dryer
Frigidaire DE700EDD5 Wwh(v4) / Electric Dryer
Frigidaire DE700EDF1 Wwh(v5) / Electric Dryer
Frigidaire DE700EDF2 Wwh(v6) / Electric Dryer
Frigidaire DE700EDF4 Wwh(v7) / Electric Dryer
Frigidaire DE700EDF5 Wwh(v8) / Electric Dryer
Frigidaire DE700EDH1 Wwh(v9) / Electric Dryer
Frigidaire DE700EDH2 Wwh(v10) / Electric Dryer
Frigidaire DE700EDH4 Wwh(v11) / Electric Dryer
Frigidaire DE700EDH5 Wwh(v12) / Electric Dryer
Frigidaire DE700EDV1 Wwh(v13) / Electric Dryer
Frigidaire DE700EDV2 Wwh(v14) / Electric Dryer
Frigidaire DE700EDV4 Wwh(v15) / Electric Dryer
Frigidaire DE700EDV5 Wwh(v16) / Electric Dryer
Frigidaire DE700EDW1 Wwh(v17) / Electric Dryer
Frigidaire DE700EDW2 Wwh(v18) / Electric Dryer
Frigidaire DE700EDW4 Wwh(v19) / Electric Dryer
Frigidaire DE700EDW5 Wwh(v20) / Electric Dryer
Maytag DE701 DRYER- ELE
Maytag DE701W DRYER- ELE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer motor replacement mrblue Dryer Repair 0 06-15-2012 05:01 PM
Dryer motor replacement TBW Dryer Repair 1 09-23-2010 07:59 PM
dryer motor replacement feelix713 Dryer Repair 1 05-11-2009 07:03 AM
gas dryer motor replacement feelix713 Dryer Repair 0 05-10-2009 01:16 PM
Dryer Motor Replacement Help! Padme Dryer Repair 6 01-31-2008 10:35 AM
