| » Gas Dryer Tripping the GFI |
Model Number: FSG447GHSO Brand: Frigidaire Age: 5 - 10 years
I have a Frigidaire Gallery Gas Dryer, SN XD11813665. The Dryer starts and runs normally but soon (about 1-2 minutes) after the gas ignites the dryer kicks the GFI. When the GFI is reset, it will do the same thing again?
When its set on low heat for dedicates it runs fine and doesn't trip the GFI? Ads By Google Related Models |
It is not recommended by all major appliance manufacturers to use a GFI outlets for a large home appliances. I believe your dryer will work good and will be safe to use if you will use a regular outlet. You can read more about GFI's in one of our previous threads: dryer blowing gfi outlet
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
Thanks for you're response. Why would it not occur on the low temperature setting as well, especially since the dryer runs longer on the lower temperature to dry the clothes? |
Hi Andy,
I don't know why because it has to be tested and a regular meter maybe not good enough for such test. As long as a regular 15 amps circuit breaker would handle it there is nothing to worry about. Gene.
__________________
| Display Modes | |
| Frigidaire Gallery Gas Dryer - Tripping GFCI | cmoore64 | Dryer Repair | 2 | 08-07-2012 04:51 PM |
| maytag dryer tripping gfi | snooop | Dryer Repair | 6 | 06-22-2011 07:39 PM |
| Sears gas dryer tripping circuit breaker | dwawayne | Dryer Repair | 1 | 01-14-2011 09:17 PM |
| Dryer tripping the GFI | jilllagiglia | Dryer Repair | 0 | 10-14-2009 08:42 AM |
| Dryer keeps tripping | Alana | Dryer Repair | 1 | 06-03-2009 05:16 PM |
