Discuss
Maytag Neptune Elec Dryer Works Intermittent
 in
Dryer Repair
Dryer works randomly. It gets 120 volts to hi-limit thermostat and has only 7 volts on wire which connects to
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Neptune Elec Dryer Works Intermittent
  #1 (permalink)
Old 11-11-2012, 10:53 AM
Junior Member
benmiles is on a distinguished road
Default Maytag Neptune Elec Dryer Works Intermittent
Model Number: mle2000ayw   Brand: Maytag   Age: More than 10 years
Dryer works randomly. It gets 120 volts to hi-limit thermostat and has only 7 volts on wire which connects to the heater. I tested all components resistance and all passed except cycling thermostat which read 28,000 ohms. I replaced it. I get 120 volts from motor and everywhere I believe it should be up to the hi-limit thermostat. Since it tests 0 ohms, is there a problem with it or something else?
Ads By Google
Related Models
Maytag MLE2000AYW Stacked Laundry - Ele
Maytag MLE2000AZW Stacked Laundry - Ele
Maytag MLE23MNAUW Dryer - Ele
Maytag MLE23MNAYW Stacked Dryer - Electric
Maytag MLE23MNFYW Stacked Dryer - Electric
International MLE23PDAGW Dryer - Ele
Maytag MLE23PDAUW Dryer - Ele
Maytag MLE23PDAYQ Stacked Dryer - Electric
Maytag MLE23PDAYW Stacked Dryer - Electric
Maytag MLE23PDFGW Stacked Dryer - Electric
Maytag MLE23PDFUW Stacked Dryer - Electric
Maytag MLE23PDFYW Stacked Dryer - Electric
Maytag MLE23PDFZW Stacked Dryer - Electric
Maytag MLE23PDHGW Stacked Dryer - Electric
Maytag MLE23PDHYW Stacked Dryer - Electric
Maytag MLE23PDHZW Stacked Dryer - Electric
Maytag MLE23PRAYW Stacked Dryer - Electric
Maytag MLE23PRFYW Stacked Dryer - Electric
Maytag MLE23PRFZW Stacked Dryer - Electric
Frigidaire MLF303PGDA Frg(v1) / Gas Range
Frigidaire MLF303PGDC Frg(v1) / Gas Range
Frigidaire MLF303PGDD Frg(v2) / Gas Range
Frigidaire MLF303PGWA Frg(v2) / Gas Range
Frigidaire MLF303PGWC Frg(v3) / Gas Range
Frigidaire MLF303PGWD Frg(v4) / Gas Range
Frigidaire MLF311SGDA Frg(v1) / Gas Range
Frigidaire MLF311SGDC Frg(v1) / Gas Range
Frigidaire MLF311SGDD Frg(v1) / Gas Range
Frigidaire MLF311SGWA Frg(v2) / Gas Range
Frigidaire MLF311SGWC Frg(v2) / Gas Range
Frigidaire MLF311SGWD Frg(v2) / Gas Range
International MLG15MNAEW Dryer - Gas
Maytag MLG15MNAGW Dryer - Gas
Maytag MLG15MNAWW Stacked Dryer - Gas
International MLG15PDAEW Dryer - Gas
Maytag MLG15PDAGW Dryer - Gas
Maytag MLG15PDAWA Dryer - Gas
Maytag MLG15PDAWQ Dryer - Gas
Maytag MLG15PDAWW Dryer - Gas
Maytag MLG15PDAXA Dryer - Gas
Maytag MLG15PDAXQ Dryer - Gas
Maytag MLG15PDAXW Dryer - Gas
Maytag MLG15PDBGW Dryer - Gas
Maytag MLG15PDCXA Dryer - Gas
Maytag MLG15PDCXQ Dryer - Gas
Maytag MLG15PDCXW Dryer - Gas
Maytag MLG15PRAWW Stacked Dryer - Gas
Maytag MLG15PRAXW Stacked Dryer - Gas
Maytag MLG19PDAEW Stacked Laundry - Gas
Maytag MLG19PDAGW Stacked Laundry - Gas
Maytag MLG19PDAWW Stacked Laundry - Gas
Maytag MLG19PDAXW Stacked Laundry - Gas
Maytag MLG19PDBGW Dryer - Gas
Maytag MLG19PDCXQ Dryer - Gas
Maytag MLG19PDCXW Dryer - Gas
Maytag MLG19PDDGW Stacked Laundry - Gas
Maytag MLG19PDDWW Stacked Laundry - Gas
Maytag MLG19PDSAW Stacked Laundry - Gas
Maytag MLG19PNAWW Dryer - Gas
Maytag MLG19PNDWW Stacked Laundry - Gas
Maytag MLG19PRAWW Dryer - Gas
Maytag MLG19PRAXW Dryer - Gas
Maytag MLG19PRDWW Stacked Laundry - Gas
Maytag MLG2000AWW Stacked Laundry - Gas
Maytag MLG2000AXW Stacked Laundry - Gas
Maytag MLG23MNAWW Stacked Dryer - Gas
Maytag MLG23MNFWW Stacked Dryer - Gas
International MLG23PDAGW Dryer - Gas
Maytag MLG23PDAWQ Dryer - Gas
Maytag MLG23PDAWW Dryer - Gas
Maytag MLG23PDAYQ Dryer - Gas
Maytag MLG23PDFGW Stacked Dryer - Gas
Maytag MLG23PDFWW Stacked Dryer - Gas
Maytag MLG23PDFXW Stacked Dryer - Gas
Maytag MLG23PDHGW Stacked Dryer - Electric
Maytag MLG23PDHWW Stacked Dryer - Electric
Maytag MLG23PDHXW Stacked Dryer - Electric
Maytag MLG23PRAWW Dryer - Gas
Maytag MLG23PRFWW Stacked Dryer - Gas
Maytag MLG23PRFXW Stacked Dryer - Gas
Maytag MLG31PCAWQ Dryer - Gas
Maytag MLG31PCAWS Dryer - Gas
Maytag MLG31PCAWW Dryer - Gas
Maytag MLG31PCBWQ Stacked Dryer - Gas
Maytag MLG31PCBWS Stacked Dryer - Gas
Maytag MLG31PCBWW Stacked Dryer - Gas
Maytag MLG32PDAWA Stacked Dryer - Gas
Maytag MLG32PDAWW Stacked Dryer - Gas
Maytag MLG32PDBWA Stacked Dryer - Gas
Maytag MLG32PDBWQ Stacked Dryer - Gas
Maytag MLG32PDBWS Dryer - Gas
Maytag MLG32PDBWW Stacked Dryer - Gas
Maytag MLG33PDAWS Dryer - Gas
Maytag MLG33PDAWW Dryer - Gas
Maytag MLG33PDSWS Dryer - Gas
Maytag MLG33PDSWW Dryer - Gas
Maytag MLI7000AAW Small Appliances
Maytag MLI7500AAW Small Appliances
Amana MLMTK1 Misc / Accessory
International MLR1100AJQ Range - F/s Std Gas
International MLR1100AJW Range - F/s Std Gas
International MLR1110AJQ Range - F/s Std Gas
International MLR1110AJW Range - F/s Std Gas
International MLR1415AJQ Range - F/s Std Gas
International MLR1415AJS Range - F/s Std Gas
International MLR1415AJW Range - F/s Std Gas
International MLR4410BXH Range - F/s Std Gas
International MLR4410BXL Range - F/s Std Gas
International MLR4410BXT Range - F/s Std Gas
International MLR4410CXH Range - F/s Std Gas
International MLR4410CXT Range - F/s Std Gas
International MLR4451AJQ Range - F/s Std Gas
International MLR4451AJS Range - F/s Std Gas
International MLR4451AJW Range - F/s Std Gas
International MLR5755QDQ Range - S/c F/s Gas
International MLR5755QDS Range - S/c F/s Gas
International MLR5755QDW Range - S/c F/s Gas
Frigidaire MLSE62RFD0 Frg(v1) / Laundry Center
Frigidaire MLSE62RFD1 Frg(v1) / Laundry Center
Frigidaire MLSE62RFW0 Frg(v2) / Laundry Center
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Elec Dryer no power JohnGoubeaux Dryer Repair 9 07-19-2011 03:07 PM
Maytag elec dryer squeal xtexan Dryer Repair 1 02-22-2011 01:16 PM
Intermittent heater op on Kenmore elec dryer soonerdaev Dryer Repair 1 02-14-2010 02:26 AM
Neptune Washer only works when dryer is on! timbergeek Washer Repair 1 05-21-2009 02:41 PM
Maytag ELEC Dryer No Heat liquor driver Dryer Repair 4 05-17-2009 01:18 PM
