| » Estate dryer won't start, replaced thermal fuse still not working |
Model Number: EED4300VQ1 Brand: Estate Age: 1 - 5 years
I stopped the dryer midcycle to check to see if the clothes were dry and when I was done taking out the dry ones I went to restart the dryer and it wouldn't restart
Parts for Estate EED4300VQ1 Dryer - AppliancePartsPros.com See the attachment for the tech sheet. It could be a power problem as the motor runs off of 120 volts (L1 to Neutral) but the timer sues 240 volts (L1 to L2). You may have lost the Neutral so I would start by making sure the power is OK. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. Be careful as 240 volts is lethal !!!
__________________
If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. 4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset. There is a good STICKY at the start of this forum about it's use.
__________________
well all parts are checking out for continuity except for our 220 line, looks like we need to replace it
I am glad you found the problem.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
__________________
| Display Modes | |
| Replaced thermal fuse, now running VERY HOT | jc3 | Dryer Repair | 0 | 11-09-2011 06:05 PM |
| Replaced Thermal Fuse & Thermostat. Still won't work | Irishrose | Dryer Repair | 0 | 08-19-2011 10:53 AM |
| Replaced thermal fuse, still no power | danthepainterman | Oven Repair (including Ranges and Cooktops) | 0 | 04-03-2011 09:53 AM |
| Roper Dryer Won't Start - Replaced Thermal Fuse | ladodgersfan88 | Dryer Repair | 1 | 07-11-2010 11:09 PM |
| Dryer still won't start, have replaced thermal fuse and thermostat-fix | JRHeck | Dryer Repair | 2 | 06-17-2009 08:52 AM |
