Discuss
help with gas dryer, no heat
 in
Dryer Repair
Kenmore 80 series Gas dryer runs, but no heat. It worked on Sunday, not on Tuesday, just like that. I
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » help with gas dryer, no heat
  #1 (permalink)
Old 11-10-2012, 05:49 PM
Junior Member
m.gehman is on a distinguished road
Default help with gas dryer, no heat
Model Number: 74832440   Brand: Kenmore   Age: 5 - 10 years
Kenmore 80 series
I replaced the ignitor and valve coils not knowing which was the culprit just hoping it would fix issue.
I used the following parts from AppliancePartsPros.com
AP3094138 (279311) Dryer igniter kit and bracket 1 $18.15
AP3094251 (279834) Dryer gas valve coil kit 1 $15.95
Cleaned the venting and lint build up. All good.
Still get proper gas to other appliances in house. No indication that gas line to dryer is kinked.
After replacing parts, dryer still runs, but no heat.
I popped open the Peep hole on front panel to watch. Don't see any glow or light for ignition?
Looking for advice on possible part number/description that could be relatively easy/cheap attempt at fixing.
Thanks. Mike
Ads By Google
Related Models
Magic Chef 7498VAD Range - S/c Mwave Gas
Magic Chef 7498VAV Range - S/c Mwave Gas
Magic Chef 7498VRA Range - S/c Mwave Gas
Magic Chef 7498VRV Range - S/c Mwave Gas
Magic Chef 7498VTV Range - S/c Mwave Gas
Magic Chef 7498VVV Range - S/c Mwave Gas
Magic Chef 7498XRA Range - S/c Mwave Gas
Magic Chef 7498XRW Range - S/c Mwave Gas
Magic Chef 7498XTA Range - S/c Mwave Gas
Magic Chef 7498XVA Range - S/c Mwave Gas
Amana 75A-1 Room Air Conditioner
Amana 75A-2 Room Air Conditioner
Amana 75A-256 Room Air Conditioner
Amana 75A-2M Room Air Conditioner
Amana 75A-3 Room Air Conditioner
Amana 75A-356 Room Air Conditioner
Amana 75A-556 Room Air Conditioner
Amana 75B-1 Room Air Conditioner
Amana 75B-2 Room Air Conditioner
Amana 75B-3 Room Air Conditioner
Maytag 75C Dryer - Gas
Amana 75D-256 Room Air Conditioner
Amana 75D-356 Room Air Conditioner
Amana 75D-556 Room Air Conditioner
Amana 75LA-20 Room Air Conditioner
Amana 75LA-2M Room Air Conditioner
Amana 75LA-2N Room Air Conditioner
Amana 75LD-2M
Amana 75S-256 Room Air Conditioner
Frigidaire 76-4232-00-14 Tap(v1) / Gas Range
Frigidaire 76-4232-23-14 Tap(v2) / Gas Range
Frigidaire 76-4232-45-14 Tap(v3) / Gas Range
Frigidaire 76-4232-57-14 Tap(v4) / Gas Range
Frigidaire 76-4232-66-14 Tap(v5) / Gas Range
Frigidaire 76-4667-00-01 Tap(v1) / Gas Range
Frigidaire 76-4667-00-02 Tap(v5) / Gas Range
Frigidaire 76-4667-00-03 Tap(v1) / Gas Range
Frigidaire 76-4667-00-04 Tap(v5) / Gas Range
Frigidaire 76-4667-00-05 Tap(v1) / Gas Range
Frigidaire 76-4667-00-06 Tap(v5) / Gas Range
Frigidaire 76-4667-00-07 Tap(v9) / Gas Range
Frigidaire 76-4667-00-08 Tap(v1) / Gas Range
Frigidaire 76-4667-08-01 Tap(v4) / Gas Range
Frigidaire 76-4667-08-02 Tap(v8) / Gas Range
Frigidaire 76-4667-23-01 Tap(v2) / Gas Range
Frigidaire 76-4667-23-02 Tap(v6) / Gas Range
Frigidaire 76-4667-23-03 Tap(v2) / Gas Range
Frigidaire 76-4667-23-04 Tap(v6) / Gas Range
Frigidaire 76-4667-23-05 Tap(v2) / Gas Range
Frigidaire 76-4667-23-06 Tap(v6) / Gas Range
Frigidaire 76-4667-23-07 Tap(v10) / Gas Range
Frigidaire 76-4667-23-08 Tap(v2) / Gas Range
Frigidaire 76-4667-32-03 Tap(v4) / Gas Range
Frigidaire 76-4667-32-04 Tap(v8) / Gas Range
Frigidaire 76-4667-32-05 Tap(v4) / Gas Range
Frigidaire 76-4667-32-06 Tap(v8) / Gas Range
Frigidaire 76-4667-32-07 Tap(v12) / Gas Range
Frigidaire 76-4667-32-08 Tap(v4) / Gas Range
Frigidaire 76-4667-66-01 Tap(v3) / Gas Range
Frigidaire 76-4667-66-02 Tap(v7) / Gas Range
Frigidaire 76-4667-66-03 Tap(v3) / Gas Range
Frigidaire 76-4667-66-04 Tap(v7) / Gas Range
Frigidaire 76-4667-66-05 Tap(v3) / Gas Range
Frigidaire 76-4667-66-06 Tap(v7) / Gas Range
Frigidaire 76-4667-66-07 Tap(v11) / Gas Range
Frigidaire 76-4667-66-08 Tap(v3) / Gas Range
Frigidaire 76-4960-00-01 Tap(v1) / Gas Range
Frigidaire 76-4960-00-03 Tap(v1) / Gas Range
Frigidaire 76-4960-00-04 Tap(v3) / Gas Range
Frigidaire 76-4960-00-07 Tap(v1) / Gas Range
Frigidaire 76-4960-00-08 Tap(v3) / Gas Range
Frigidaire 76-4960-23-01 Tap(v2) / Gas Range
Frigidaire 76-4960-23-03 Tap(v2) / Gas Range
Frigidaire 76-4960-23-04 Tap(v4) / Gas Range
Frigidaire 76-4960-23-07 Tap(v2) / Gas Range
Frigidaire 76-4960-23-08 Tap(v4) / Gas Range
Frigidaire 76-4967-00-01 Tap(v1) / Gas Range
Frigidaire 76-4967-00-02 Tap(v5) / Gas Range
Frigidaire 76-4967-00-03 Tap(v9) / Gas Range
Frigidaire 76-4967-00-04 Tap(v1) / Gas Range
Frigidaire 76-4967-00-05 Tap(v5) / Gas Range
Frigidaire 76-4967-00-06 Tap(v9) / Gas Range
Frigidaire 76-4967-00-07 Tap(v1) / Gas Range
Frigidaire 76-4967-00-08 Tap(v9) / Gas Range
Frigidaire 76-4967-00-09 Tap(v1) / Gas Range
Frigidaire 76-4967-00-10 Tap(v9) / Gas Range
Frigidaire 76-4967-00-11 Tap(v1) / Gas Range
Frigidaire 76-4967-00-12 Tap(v1) / Gas Range
Frigidaire 76-4967-00-13 Tap(v1) / Gas Range
Frigidaire 76-4967-18-04 Tap(v4) / Gas Range
Frigidaire 76-4967-18-05 Tap(v8) / Gas Range
Frigidaire 76-4967-18-06 Tap(v12) / Gas Range
Frigidaire 76-4967-23-01 Tap(v2) / Gas Range
Frigidaire 76-4967-23-02 Tap(v6) / Gas Range
Frigidaire 76-4967-23-03 Tap(v10) / Gas Range
Frigidaire 76-4967-23-04 Tap(v2) / Gas Range
Frigidaire 76-4967-23-05 Tap(v6) / Gas Range
Frigidaire 76-4967-23-06 Tap(v10) / Gas Range
Frigidaire 76-4967-23-07 Tap(v2) / Gas Range
Frigidaire 76-4967-23-08 Tap(v10) / Gas Range
Frigidaire 76-4967-23-09 Tap(v2) / Gas Range
Frigidaire 76-4967-23-10 Tap(v10) / Gas Range
Frigidaire 76-4967-23-11 Tap(v2) / Gas Range
Frigidaire 76-4967-23-12 Tap(v2) / Gas Range
Frigidaire 76-4967-23-13 Tap(v2) / Gas Range
Frigidaire 76-4967-32-01 Tap(v4) / Gas Range
Frigidaire 76-4967-32-02 Tap(v8) / Gas Range
Frigidaire 76-4967-32-03 Tap(v12) / Gas Range
Frigidaire 76-4967-32-07 Tap(v4) / Gas Range
Frigidaire 76-4967-32-08 Tap(v12) / Gas Range
Frigidaire 76-4967-32-09 Tap(v4) / Gas Range
Frigidaire 76-4967-32-10 Tap(v12) / Gas Range
Frigidaire 76-4967-32-11 Tap(v4) / Gas Range
Frigidaire 76-4967-32-12 Tap(v4) / Gas Range
Frigidaire 76-4967-32-13 Tap(v4) / Gas Range
Frigidaire 76-4967-66-01 Tap(v3) / Gas Range
Frigidaire 76-4967-66-02 Tap(v7) / Gas Range
Frigidaire 76-4967-66-03 Tap(v11) / Gas Range
Frigidaire 76-4967-66-04 Tap(v3) / Gas Range
Frigidaire 76-4967-66-05 Tap(v7) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 02:23 PM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 09:33 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
